Service command update shows on tele' screen every 15 seconds
Every 15 seconds the set top box service command shows on the television screen and says update now is recommended or exit
Hello downloaded software upgrade for set top box and problems solved
Posted on Jan 07, 2009
Have deleted all services!!
Go to settings and select factory default settings.
Aug 01, 2012 | Hitachi Televison & Video
Tip
How to shutdown your computer very fastly in microsoft operating systems.
step 1: click start menu button
step 2: click on the 'run' button
step 3: in the box that appears,type in the command ''shutdown -t 01"
the computer will start shutting down in 01 seconds
Note: By changing the value after the letter 't' in step three, u can set timer to shutdown for the specified value
for eg: the command ''shutdown -t 15" will set the timer for shutdown to 15 seconds.
on Jun 19, 2011 | Computers & Internet
Black rectangular box shows on screen
This is simple: set in the closed caption menu (some cable boxes also have it) called TEXT. Look in the menu and turn it off first in the set and also in the box used if used for signal.
Odd feature and never really took off--designed so some channels like PBS etc could broadcast text.
Apr 01, 2012 | Proton Televison & Video
The TV turns on but cannot find a signal (as has been normal when swictching to HDMI inputs). Usually it takes a second and the Cable or FIOS signal shows on screen. As of today, the images never comes...
Tries tv and cables boxes uplug,replug it back like about an hour later for the tv resetting itself back to the factory setting and those pay boxes updated it softwares.Take the HDMI cable plug it in into another tv HDMI hub.Tv should have signal and work again.
Feb 17, 2011 | InFocus ScreenPlay 61" Rear Projection...
Sharp LC37D44U Power LED was flashing green. TV would turn on, channel indicator shows in upper right corner, sound good, but screen would be black. Channel indicator disappears but screen is still...
I had the same problem. all the service reset would only make the display come on for a few second with no "k" on the screen - only the channel would show up. I purchased a complete set of board for the lcd on ebay, and started swapping them one by one. The inverter boards were the culpret. Tele working 100% since that board swap.
Nov 16, 2010 | Sharp Aquos LC37D44U 37 in. LCD HDTV
MY SCREEN IS BLANK MY TV IS NON HDMI AND SO WAS
  • Have your ps3 in standby mode (red light).
  • Now, press and hold the power button in the front down. Your ps3 will beep twice. Let it go almost exactly after you heard the second beep.
  • Wait 10-15 seconds. A display will show up, and just answer yes to all!
Dec 30, 2009 | Sony Playstation 3 (PS3) Console
Have philips42'hdt.vi,m in australia
You'll have to set up these channels after getting your STB, so yeah, YES.
Mar 25, 2009 | Philips 42PF9731D37 42 in. HD-Ready LCD...
Connecting my laptop to my samsung tele
Most common problem is the VGA cable. Make sure you have the 15 pin VGA Monitor cable.
1. Switch off the TV & Notebook
2. Connect the VGA cable to the TV and Notebook.
3. Switch on the Notebook. Set the resolution to 800 x 600 Pixels (Go to Control Panel - Adjust Screen Resolution). Then go to Advanced settings and set 'Screen Refresh rate' as 60 hz in the Monitor tab,
4. Switch on the TV. Go to Source button from the TV remote and select PC as input source. Alternatively, you can go to 'Menu' and select 'PC' as input source. If the connection is made properly, PC option will NOT be GREY anymore.
5. Press Fn + F5, F6, F7 (depending on which Notebook brand you have)
Jul 08, 2008 | Samsung LN-S4051D 40 in. LCD Television
Rf2 outlet from sky hd box
on your sky remote
services
0 1 select
make sure the rf is set to on
Remember the channel rf number,
go to your television the link is to.
go to menu then setup and then manual tune
select the channel you want to view sky on. normally channel 6 on your analogue
then go to Channel type in whatever the rf setting was on your main sky box then press save.
that is your telly sorted out. if you have a magic eye connected at the link end you should see a red led light lit up.
if not remove the magic eye and connect it straight into the back of your sky box RF2
just to make sure that the eye is not at fault.
hope this helps
ill check in a day or two to see if you need more help.
Cheers
Little Dish Fitter
Nov 14, 2007 | Samsung LE32R41BD 32 in. HD-Ready LCD...
Viewsonic N3246W
does it only ghost on the channels that showing football only?
Apr 19, 2007 | ViewSonic N2750w 27 in. HD-Ready LCD...
Televison & Video Logo
37 people viewed this question
Top Televison & Video Experts
