Question about Pentax Optio 50 Digital Camera
The lens won't go out!
Today when i turned the camera on to take a picture, i attempted to turn it on..then i heard a sound like the lens is moving out of the camera( like it regularly does) but in this case, all it did was make a sound then say "lens problem" then shut off. But this makes absolutely no sence becausei haven't dropped the camera, or have water near it or anything like that.. i really dont want to have to pay because the camera is not mine and i dont want to bring it to a shop
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Pentax Master
  • 102,366 Answers
Try the procedures in this tip.
Posted on Aug 24, 2012
  • 67 Answers
SOURCE: lens error 0x02110000
This is a common problem with with cameras with retractable zoom lens .
Heres a few thing you should try :
Fix #1: Remove the batteries from the camera, wait a few minutes. Put a fresh set of batteries back in (preferably rechargeable NiMH 2500mah or better) and turn the camera on.
Fix #2: Remove the batteries, then remove the memory card. Then install the new batteries, when you turn it on it should come back to life. If you get another type of error message this may mean you don't have a memory card installed, so turn it off, slip in the memory card and turn it on one last time.
Fix #3: Insert the cameras Audio/Video (AV) cable, and turn the camera on. Inserting this cable ensures that the camera's LCD screen remains off during the start process. Thus extra battery power is available to the camera's lens motor during startup. This extra power can be useful in overcoming grit or sand particals that may be jamming the lens. If the AV cable doesn't fix the lens error by itself, consider keeping this cable installed while trying fixes 4, 5, and 7 as a means to provide extra help to these fixes. But note that I DON'T recommend keeping the cable installed during Fix 6 as you may damage the AV port while tapping the camera. Reinsert the cable only AFTER tapping the camera.
Fix #4: Place the camera flat on its back on a table, pointed at the ceiling. Press and hold the shutter button down, and at the same time press the power-on button. The idea is that the camera will try to autofocus while the lens is extending, hopefully seating the lens barrel guide pins in their slots.
Fix #5: Blow compressed air in the gaps around the lens barrels with the idea of blowing out any sand or grit that may be in there jamming the lens. Other variations include blowing with a hair dryer in “no heat” setting, or sucking the gaps with a vacuum (careful with this one). TO AVOID THIS PROBLEM AGAIN : Keep away from dust, dirt, grit, sand and any camera bag that has loose fibres (clean it before use).
If this helps you, please vote...thankyou and good luck!
Posted on Jul 28, 2009
simplemitch
  • 752 Answers
SOURCE: Pentax Optio 50 Digital Camera Lens Error
Not really, it sounds like the lens has been bumped while it was extended. Unfortunately, the "buzz" you hear is the gears stripping one another. The only fix is to have the lens assembly replaced, which usually costs upwards of $200. I see this problem at least 3 times a week in my shop.
Posted on Oct 27, 2007
SOURCE: Pentax Optio M20
When the camera is turned on, the lens extends, makes a slight buzzing sound and then retracts and the camera turns off.
Posted on Feb 20, 2008
  • 11967 Answers
SOURCE: the lens doesn't open when we turn on the camera
Fixing a Lens Error on a Digital Camera
This has to be THE most common failure mode for a digital camera. Some common error messages that might show up on the LCD's of cameras with this problem include “E18 lens error”, or “lens error, restart camera”. Some cameras might show nothing at all, but merely make a beeping noise as the lens goes out, then in, then the camera shuts off. Sometimes the lens won't even move.
The problem is actually quite common throughout all camera brands. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended. Believe it or not, one BIG contributor to lens errors is using a camera case. Sand, gunk, case fibers, etc... accumulate at the bottom of the case. These materials love to cling to the camera by electrostatic build-up from the camera rubbing against the side of the case (especially those cases with soft fibrous intreriors). Once these materials work their way into the lens mechanism, that's all she wrote. I have many Canon's, and NEVER use a case for this very reason.
A camera owner that suffers this problem may have no recourse for having the camera repaired. Many camera makers will not honor repairing this problem under warranty as they claim it is due to impact damage to the camera, or sand or debris getting into the lens gearing mechanism (neither of which is covered under warranty). The quoted repair cost is usually close to or more than what the camera is actually worth.
Fortunately, about half the cameras that suffer this failure can easily be fixed by one of the following methods. None of these methods involve opening the camera, although some have potential to cause other damage to the camera if excessively done. If the camera is still under warranty, before trying any of these, please please first contact your camera's maker to see if they'll cover the repair, or to determine how much they'll charge for the repair. Who knows, you might get lucky. But if they quote you a number that's higher than the value of your camera, you may want to consider the following methods.
The methods are listed in the order of risk of damaging your camera. Thus make sure you try them in the listed order. And remember, these fixes (especially #6 and 7) should only be considered for a camera that's out of warranty, who's cost of repair would be excessive, and would otherwise be considered for disposal if unrepaired:
Fix #1: Remove the batteries from the camera, wait a few minutes. Put a fresh set of batteries back in (preferably rechargeable NiMH 2500mah or better) and turn the camera on. If that didn't work, try pressing and holding the Function or OK button while turning the camera on.
Fix #2: Remove the batteries, then remove the memory card. Then install new batteries, and turn on the camera. If you get an Error E30, it means you don't have a memory card installed, so turn it off, slip in the memory card and turn it on one last time.
Now we're entering into the realm of potentially damaging your camera in conducting the fix. There is definitely some risk here, so take care when conducting the following two fixes.
Fix #6: Repeatedly tap the padded/rubber usb cover on a hard surface with the intent of dislodging any particles that may be jamming the lens. Other variations include hitting a side of the camera against the palm of your hand. A lot of people have reported success with this method. HOWEVER, there is also some potential for damaging or dislodging internal components with this method, such as unseating ribbon cables, or cracking LCD screens.
Fix #7: Try forcing the lens. More people have reported success with this method than with any of the other methods. HOWEVER, there's obviously some potential for damaging your camera by using this method. Variations include gently pulling, rotating, and/or twisting the lens barrel while hitting the power button. Attempt to gently straighten or align the barrel if it's crooked or twisted. Another variation includes looking for uneven gaps around the lens barrel, and then pushing on the side of the lens barrel that has the largest gap (note pushing the lens barrel all the way in is NOT recommended as it may become stuck there). While doing any of the above, listen for a click that indicates that the lens barrel guide pins may have reseated in their guide slots. If you hear this click, immediately stop and try the camera.
Posted on Jan 01, 2010
rajdeepdutta
  • 2517 Answers
SOURCE: My Pentax K100D has suddenly stopped working. It
Hi there as per your mentioned sound or noise is says that the problem create by your camera lens guide pin. Its damaged or dislocate. So i also suggest you to visit the service center. Thanks.
Posted on Apr 03, 2010
Lens froze position
I've just got the same problem, don't know what to do!
May 04, 2013 | Nikon COOLPIX L810
My kodak camera turned on but now will not close lens will not retract just get beeping noise
Hello
My name is miss Jelin, i am looking for a new friend i saw your profile today and became interested in you,i
will also like to know you the more,and i want you to send a mail to my email
address so i can give you my picture for you to know whom l am.Here is my email
address (Jelinbaby39@yahoo.co.uk)
I believe we can move from here.I am waiting for
your mail to my email address (Jelinbaby39@yahoo.co.uk) Remember the distance, color or age
does not matter but love matters allot in life Please reply me with my email
Jelin
Apr 21, 2012 | Kodak Cameras
Camera will not turn ON. I changed the batteries but still no change.
Things to check first for a camera that won't turn on are battery contact points, and micro switches that are located on the battery and memory card doors. Troubleshooting tips on other things that need to be checked may be seen here. These tips won't work for every case, but they're worth a try.
Jun 24, 2011 | Kodak EasyShare M530 Digital Camera
I have a Sony AX Digital 100 Camera. I used it yesterday and everything worked fine. Battery is fully charged. Tried to use it today and it won't start. I have taken the battery in and out and even...
Does there is something happened when you turn on the camera? If you can heard sound made by the len or the camera try to open but turn off in a second? If so, there is something wrong with the lens, and this how to fix camera lens error will be helpful. Else, if the camera are without any reaction you can check it the joint of the camera to battery is well.
May 20, 2011 | Cameras
My kodak M1063 fell while the lens barrel was out,i tried putting it off so that it will go in but it didnt move.So decided to push it in myself thinking it will come out when i put it on.Now,the lens...
Hi, Unfortunately it sounds like the camera is beyond repair. When a camera's dropped like that there's a 50/50 chance that a mechanism in the lens has been broken and it's repairable. From the sounds of yours though, the fact that it won't come back out when you turn the camera on, it sounds like you're better off getting a new camera.
May 12, 2011 | Kodak EASYSHARE M1063 Digital Camera
Three beeps when i try to turn it on
i had the same problem a while back. I fooled around with my camera lens a bit and it turned out that one side of the lens was sticking out a bit. I pressed down on this and pushed the power button and it worked. The next time I turned it on the same thing happened but if you keep doing the same thing it should work.
Hope this helps!
Aug 21, 2009 | Samsung L100 Digital Camera
Not able to tke pictures
turn off and turn on the camera. then try to put force on the lens. once you hear a snap do the same with the second lens. then turn it on. if it does not work take it to the store as to which you bought it from
Feb 06, 2008 | Sony Cyber-shot DSC-W50 Digital Camera
I can not take pictures
update, possible solution..
I pulled the batteries for 24 hours, attempting to force a reset of the camera. Today it worked, took pictures and zoomed just fine. I shut it off after about 10 pics and turned it back on and back to the start... Took the batteries out for a few minutes and put it back in and back in business. Hope this helps at least get SOME functionality out of it. This won't serve as a long term solution for me, but perhaps will lead towards a full answer.
Dec 17, 2007 | Olympus Camedia D-540 Zoom Digital Camera
3040--Lens cap on when camera turned on
There is no way either of you or a tech can fix this problem without taking the camera apart. Sounds to me like the worm or drive gear is stripped or displaced...probably a 10 cent part...unless you have the ability to do this type of work...its best left to the techs.
There is a risky thing to do...and that is...perhaps its just "jumped" the gear...so it grinds when it attempts to move either in or out....you may be able to manually turn the lens and "click" it back into place. Gently turn it all the way right...then all the way left.
I would want to look inside first before I do anything else...it may be an easy fix...taking it apart will be the not so easy thing.
Nov 16, 2007 | Olympus Camedia C-3040 Zoom Digital Camera
Sony Cyber-shot DSC-S500
First listen closely to the camera as you turn it on. Does it make any sound at all? If is makes a grinding or whining sound, something is jammed, probably the lens. If there is no sound, you may a blown fuse. This is rather tricky soldering to do and if you are not familiar with this sort of work, I would not suggest it be attempted at home.
Mar 26, 2007 | Sony Cyber-Shot DSC-T5 Digital Camera
Pentax Optio 50 Digital Camera Logo
24 people viewed this question
Top Pentax Cameras Experts
Geoff Hone
Vuk B
Damen Wong
Damen Wong
Are you a Pentax Camera Expert? Answer questions, earn points and help others
