Question about Toshiba Portege R100 Tablet PC
Toshiba R100 keyboard not working
I poured water into the keyboard by accident, and the keyboard doesn't work now, except for a few keys. System works fine though, just keys don't function.
Do I need to replace the keyboard? Would it be possible to find a matching keyboard and replace it ?
Thanks.
I did the same some two years ago, with the R100 on. I switched everything off, dismounted the computer body (not the screen)up to the last screw, and dried that sweet coffee from everywhere where I found it. Mostly this was the keyboard and mouse. The motherboard is luckily protected by some plastic sheet.
Regarding the keyboard, after disconnecting it from the motherboard, I washed it completely under flowing water and then let it dry for several days. In the meantime, I used a USB one. Since then, I used the same keyboard for two years until now, when it died, apparently rather from some motherboard-related reason than water. So I think - you may get a new keyboard, but if youre lucky, you may as well revive this old one.
Posted on Feb 09, 2009
  • 716 Answers
You Can Get A Replacement From The Company But As For Saving The Old One It Is Only Possible If You Didn't Have It On When You Spilled It. If It Was On It Caused The Board To Short Maybe Try Removing The Key Board Circuit Board And Putting It In A Big Dish Of Rubbing Alcohol. Scrub Well With A Clean Tooth Brush Then Remove And Let It Dry. This May Solve Your Problem. You May Only Fix A Couple Keys If You Do Though Then Repeat The Alcohol Scrub.
Posted on Jan 07, 2009
Portege R100 (Toshiba). I have not used this laptop in over a year and can not rem the bios password I'd set. Tried all I could think of. Is there any way to reset the password on this?
Hi,yes there is but you'll have to open the system up,if you have no prior I.T expertise I'd suggest you take to a qualified Technician,but if you do here is how:First remove the Battery,then uncouple the system taking of where each of the screws go to then locate the CMOS battery(small battery Lithium Ion mostly in the shape of a cent or smaller),it may be underneath the keyboard or just behind once the external cover is open.unplug it from the system for about an hour or two reconnect it,couple the system and boot,go to Bios,reset Date and Time and save,then exit.
Dec 31, 2010 | Toshiba Portege R100 Tablet PC
Toshiba R100 suddenly very slow(!)
I'd suggest sending it back to where you bought it, this sounds a lot like a factory problem and it should be covered under warranty.
May 27, 2009 | Toshiba Portege R100 Tablet PC
How to replace r100 keyboard? i took the bottom and then i don't know how to take the keyboard
Assuming this is the same style of case as the older Portege models, the bezel on the bottom of the keyboard or on top between the keboard and the display should pry off (although there might be a screw or two into it around the hinge on the top) separately- they cap tabs on the edges of the kbd, or screws.
Apr 13, 2009 | Toshiba Portege R100 Tablet PC
Toshiba Portege R100 CMOS/BIOS PROBLEM at startup.
I'd look at trying to replace the BIOS battery...
Check out this guide for dis assembly instructions :
http://www.irisvista.com/tech/laptops/Toshiba_Portege_R100/remove_system_board_1.htm
Feb 22, 2009 | Toshiba Portege R100 Tablet PC
Taking apart a Toshiba R100
Probably, could have some slide catches at the top edge of the keyboard instead, need a thin blade screw driver oh lift the keyboard. Some laptops mark the screws with the letter K in indicate keyboard screws, some keyboard screws may be hidden under the battery pack, CD/DVD drive.
Nov 11, 2008 | Toshiba Portege R100 Tablet PC
Laptop will not go in BIOS or boot up
We use these and several times I have had to pull the battery, disconnect the power cord and hold the power button for 30 seconds (count slow). After that, it boots fine.
Nov 10, 2008 | Toshiba Portege R100 Tablet PC
Toshiba portege r100
I believe if you download the pdf manual contained in the software here it may give you the answer as to what type of drive....
http://www.manualnguide.com/manual-get/6459/
Oct 17, 2008 | Toshiba Portege R100 Tablet PC
Every once in a while my keyboard doesn't work
The keyboard driver is part of the system driver pack. Ensure your drivers from Toshiba are up to date.
Jul 02, 2017 | Toshiba Satellite R15-829 Tablet PC
Keyboard
If you are getting the message after the beep that Press F1 to continue after the beep and your system is working fine in every manner except the keyboard, you might have your KBD corrupted. better to check it with authorised service center for Keyboard interface or the complete Keyboard.
Feb 04, 2008 | Toshiba Satellite R10-S802TD Tablet PC
3 KEYS OF KEY BOARD NOT WORKING AND S IS STUCK
You need to clean the keyboard. Blow it with air blower so that the paricles inside keyboard will be eliminated. If not work, then you disassemble the keyboard and clean the key one by one. afraid to do , then let the repairman do it for you or you can attach USB keyboard for the laptop.
Jan 16, 2008 | Toshiba Portege M400-S5032X Tablet PC
Toshiba Portege R100 Tablet PC Logo
806 people viewed this question
Top Toshiba Tablets & eReaders Experts
micky dee
Alun Cox
Are you a Toshiba Tablet and eReader Expert? Answer questions, earn points and help others
