Marantz rs2252 remote codes?? I lost the remote to the receiver and I'm trying to program a new Harmony. Even Logitech can't find the rs2252 in their database of known devices. HELP>>>>
SOURCE: no manual
Make sure you have audio out from TV plugged into receiver. I have both Logitech 520 and JVC. It could also be in your setup of the remote.
Posted on Apr 12, 2008
  • 6 Answers
SOURCE: Martantz SR 3000 - Are there any remote codes
Click here for Comcast Remotes Five Didgit Codes hope it works for you did for me.
Posted on Sep 10, 2008
  • 8 Answers
SOURCE: HARMONY 550 UNIVERSAL REMOTE
As far as I know you cannot, you will need it to be in the devices list online, or find somebody with the remote to program it.
You should also be able to get the company.. Yamaha to send you the codes or send them directly to Logitech to get them added to the database.
Posted on Sep 15, 2008
SOURCE: Marantz SR-18ex remote control number
If you mean the model number, that is: RC-18SR
Posted on May 15, 2009
SOURCE: Harmony 880 universal remote re-charging problem
I took the rubber feet off(4) from the underside of the cradle - removed the four screws and separated the top half of the cradle from the bottom. This exposes the two long thin charging arms and points All one piece). I then took some doubled sided tape, similar to what you use to put up temporary 3m picture hooks and cut four small pieces about 1/8th in square. Join two of the pieces back to back to make one piece (double original thickness), then raise one of the long charging arms gently and place the piece of double sided tape under the head of the arm (ie under the very end where the rounded point is, that sticks though the cradle when reassembled (there are two of these). Do this to the other arm.
Why - by inserting the doublesided tape you permanently raise the arms without bending them - ie they will now stay in that position and not bend out of shape, losing contact again . With the cradle reassembled, put the remote back in the cradle you will have more direct contact with the two charging pins. FIXED!!!!!!!! Good luck1
Posted on Jun 20, 2009
Need a remote for it
You can purchase this:
http://www.amazon.com/Logitech-Harmony-300i-Remote-Control/dp/B003IZFCFW/ref=sr_1_11?ie=UTF8&qid=1298870275&sr=8-11
It is a Logitech Harmony 300i remote. You can program it to use with your panasonic receiver, and can retain all functionality, just as if you had the real remote.
Feb 28, 2011 | Panasonic Audio Players & Recorders
I need the code for a Teac CD-X10i mini hi fi system
I can help you program your Logitech Harmony 520 remote for your Teac CD-X10i.
The Logitech Harmony 520 remote control is programmed through the Harmony Setup Software you can download from here.
Once installed, you will simply run the software, and select the devices you would like to control from menus. The software finds the right codes for you and loads them into your remote control.
I hope that helps.
_____________________________________________
Harmony 520 Manual Download
Logitech Harmony Firmware Update
Harmony Win Software Download
Logitech Harmony Safe Mode Fix
Harmony Remote Glow Light Fix
Aug 19, 2009 | Logitech Harmony 520 LCD Remote Control
I need to re-program my Harmony 520 for a new TV.
I can help you program your Logitech Harmony 520 remote.
I hope that helps.
Jun 07, 2009 | Logitech Harmony 520 LCD Remote Control
Compatible TVs
I can help you with your Logitech Harmony 550 remote control.
The Logitech Harmony 550 remote control is programmed through the
Harmony Windows Setup Software.
Once installed, you will simply run the program and select the devices you would like to control from menus. The software finds the right codes for you and loads them into your remote control.
I hope that helps.
Harmony 550 Manual Download
Harmony MAC Software Download
Jun 06, 2009 | Logitech Harmony 550 Remote Advanced...
Cannot add new 722 dishnetwork satellite box to remote
I can help you program your Logitech Harmony 520 remote for your Dish Network satellite box.
I hope that helps.
May 23, 2009 | Logitech Harmony 520 LCD Remote Control
I just bought a Harmony 670 Advanced remote, but no instruction manual. How do i program it to my TV and DVD? please help!
I can help you with your Logitech Harmony 670 remote control.
The Logitech Harmony 670 remote control is programmed through the
Once installed, you will simply run the program and select the devices you would like to control from menus. This program finds the right codes for you and loads them into your remote control.
I hope that helps.
Harmony 670 Manual Download
Mar 04, 2009 | Logitech Harmony 670 LCD Remote Control
Dog ate my sr3000 remote
get a logitech harmony, very easy to setup using computer.
Feb 28, 2009 | Marantz SR-3000
Cannot get DVD to play movies -
I can help you with your Logitech Harmony 890 remote control.
The Logitech Harmony 890 remote control is programmed through the
You can get a copy of the Harmony 890 Manual by clicking here.
I hope that helps.
Harmony 890 Manual Download
Feb 02, 2009 | Logitech Harmony 890 LCD Remote Control
Lost manual to remote i have the codes i just cant remember what to do its an rca universal remote controls six devices
I can help you with your Harmony One Remote Control.
You can Download the Harmony One Manual here.
The Logitech Harmony One remote control is programmed through the Harmony Setup Software you can download from here.
I hope that helps.
Harmony One Manual Download
Jan 24, 2009 | Logitech Harmony One LCD Touchscreen...
Aug 25, 2008 | Logitech Harmony 550 Remote Control
78 people viewed this question
 Grubhead
Grubhead
