Question about Taylor Biggest Loser 7206 Electronic Cal Max Scale ()
Taylor CalMax scale won't weigh anything
My Taylor Calmax scale worked for many weeks. Then when I attempted to program users, it went wrong. Now the scale just shows 00.00 when we get on it and then it shuts off. I tried taking out the batteries to 'reset' it but.... still not working
    New Friend:
Scale won't weight after resetting.
Posted on Dec 04, 2012
SOURCE:
F1xer
  • 415 Answers
SOURCE: Taylor Model 7314 Lithium Scale: Scale
Try stepping off the scale when you get an error message wait 5-10 secs then step back on, remember to stand still when the scale is giving a reading
Posted on Aug 15, 2010
SOURCE: Err 1 message on Taylor Lithium Elec Scale model 7346
This is a reply I received from Taylor customer support. I have followed this procedure enough times to wear out the original battery and still get the Err 1 message. You may have better luck.
Thank you for your e-mail. The reboot below may clear the error from
your scale. You may need to do this several times to completely reboot
the system. Please let us know if you have any questions or continue to
display the Error.
1. Remove the battery from the scale
2. Set the scale on the floor without the battery in place.
3. Stand on the scale for 10 seconds (still without the battery)
4. Carefully replace the battery without turning the scale on.
5. Using only one foot, tap the scale or apply just enough pressure to
turn on the display. (It should show dashes or zero's) IMMEDIATELY
REMOVE YOUR FOOT.
6. Let the scale turn off
7. Step on the scale for a weight reading
Regards,
Linda DLT
Consumer Relations
Taylor Precision Products
& Salter Housewares
2220 Entrada del Sol, Suite A
Las Cruces, NM 88001
Toll free - 800-289-0944
866-843-3905
Direct - 575-526-0944 ext 3172
Posted on Jun 24, 2009
SOURCE: taylor 7530 scale wont turn on,i have new batteries
Basically, the frisbee comment is on the mark. I called Taylor. a nice person walked me through a calibration exercise: take batteries out; stand on scale for 7 sec.; get off; put batteries back in (assuming they are still good); step on scale and if it reads ---- step off again, then back on to weigh yourself. My scale's display was blank, not -----, so they said calibration was unsuccessful & so I mailed it back to the NM address on the bottom. It just fits w/ padding diagonally in a USPS flat rate box. Waiting to see if they replace it (lifetime warranty).
Posted on Feb 08, 2009
SOURCE: We have a Taylor 7542 Bathroom Scale. I need to
I called Taylor; the Model 7542 take a 3v CR2032 battery available at Walgreen's, CVS, WalMart, etc.
Posted on Jun 29, 2009
  • 39 Answers
SOURCE: how do i program the taylor body fat scale
From the Taylor web site
http://www.taylorusa.com/faq-scales
The easiest way to program the scales is to pull the manual up for the scale and follow the directions. The procedure does vary according to the scale.
In general the procedure is to tap the power or set button until it brings up the height and then hit the arrow keys until you get to the correct height. Hit the power or set after each entry usually height, age, gender, athlete mode. It will then beep and you will need to hit the arrow up until you see 1 (this is the memory number) tap the set or power and it will beep again. The scale is now programmed.
The general recall procedure is to hold the power or set button down for 2 seconds (or tap the up arrow) until the memory number goes up. Then just tap the power or set and it will beep. Then step on the scale to get the information. The weight will be first, then running zeroes, then thefat%, and finally water%.
Posted on Jan 21, 2010
Testimonial: "The website does not have a manual. Using 'search' or site map produces nothing. Another problem: scale reads only in cm and kg. Won't cycle to ft/lb."
Taylor Scale 7558 quit working replaced batteries with CR2032 still won't work. How do I restart this scale. Thanks
Try to reset the electronics to factory defaults. If unsuccessful unit is fubar since repair not cost effective.
Sep 24, 2017 | Taylor Health & Beauty
I have a 5744 a little over 1 year old. When you step on the scale the only thing that shows is "00" . It was working fine until today. Tried changing batteries and got the same results.
If display shows 00 - it is Initialization error. To clearthis error, step off the scale. Press on the platform. The display will show"----, then "0000", and turn off. Finally repeat the measurement. Hope this will help you. Good Luck.
Sep 14, 2011 | Taylor Health & Beauty
My scale was giving me wild weights for about a week and then stopped working. I relpaced the batteries with new ones and made sure that they are both positive side up. Now scale will not turn on. I've...
Please test the sprint where compartiments batteries and clean very well with contacts cleaner contacts.
2) tIGHT THE Spring with plyer for Good contacts.
3) see if there are some wires loose positive -rED OR BLACK -negatives
Blessing
cuadra2016@yandex.com
cell+whatsApp: +50588611441
Jan 24, 2018 | Taylor ELECTRONIC CALMAX SCALE
The taylor lithium electronic scale says 00 and then ERR. there is no ERR2. should i change the batteries? it never said lo.
If you get an "Err" or "Error" message, you will need to step off of the scale, wait a few seconds and then step back onto the scale.
Aug 10, 2010 | Taylor & Digital Scale Lithium Scale
My scale starts out with 7.2 instead of 0.0
try removing battery if this does not work you have a faulty weight sensor
May 10, 2010 | Taylor 5757 Digital Glass Body Fat Scale
How can I fix the Taylor LIthium Scale?
take it to were you got it or instuctions show u
Feb 09, 2010 | Taylor "TAYLOR" 73304072 LITHIUM BATH...
Taylor scales model 7314 lithium scale instructions/manuel need
Have you tried to email Taylor Customer Help and Support?
They are very useful. They can guide you through problems, provide you with instructions and might send the user manual via email.
I hope you get this fixed. Scales are very tricky!
Oct 25, 2009 | Taylor Health & Beauty
Error message
Try this, I have the same problem and I just got off the phone with Taylor, this is what they told me to do and my scale is now working again.
1. take the battery out.
2. put the scale on a flat, hard surface
3. stand on the scale for 10 seconds
4. put the battery back in, be careful not to touch any buttons or turn the scale on
5. put the scale back on the flat, hard surface
6. put one foot on the scale and apply pressure until the display comes on
7. take your foot off of the scale
8. wait for the the display to go blank
9. now stand on the scale to weigh yourself.
This worked for me. Hope that it works for all of you.
Dec 29, 2008 | Taylor Dgtl Body Fat Scale
Taylor chrome scale
Here is a link to Taylor.
If you have all the information you will be able to get your manual (model number is all you need):
http://www.taylor-company.com/service/resources/literature.htm
Hope this helps.
Good Luck
Apr 16, 2008 | Ice Cream Makers
Taylor Biggest Loser 7206 Electronic Cal Max Scale () Logo
2,535 people viewed this question
Top Taylor Health & Beauty Experts
Lynnette Kinsman
rebecca curry
Are you a Taylor Health and Beauty Expert? Answer questions, earn points and help others
