Question about HP Pavilion zd8000 Notebook
HP Pavilion zd8000 wont turn on, just blinks on and off
I was attempting to reset the BIOS on this laptop by removing the battery. when i put it back together and pressed the power button, the power button led comes on and stays on, all the other lights blink on and off, as well as the fan, the hard drive (making a wheezing sound) all blink on and off repeatedly and the only way to make it stop is to unplug it and take out the battery. Please help.
  • 4 more comments
  • arnold jackson
    arnold jackson May 29, 2007
    yes, the watch battery, but I now have a bigger issue now, the one about the power blinking on and off. this happened before i even got to the battery
  • arnold jackson
    hello???
    are you stilll there????
  • arnold jackson
    i was thinking the same thing @boot floppy, except that theres nowhere to put a floppy disk.
    What I initially wanted was to remove the password prompt to login to the system. I have a cd for it but its old and didnt take. I was thinking to put it back in and see, but even the dvd player blinks, so when you ask if anything works, ill say no, they all blink on and off. I am about to try to boot w/the cd again though.
  • arnold jackson
    no, it does the same thing
  • arnold jackson
    arnold jackson May 30, 2007
    I cant even get to where I can hold down any keys to do anything as my display doesnt come on. The IT guy at my job said the I/O things look to be messed up. I did disassemble three times, but I never did anything when I did the 1st time.
  • arnold jackson
    arnold jackson May 31, 2007
    Thank you very much for your support!
    Do I get the same model or any unit? Can you tell me why you think it is the BIOS chip with everything it is doing, and what I should be aware of?
They are trash period and even though its an old post I feel the need to complain about this model.. Video circuit issues, Adapters, And charging circuit problems are coming out of the woodwork for these monsters.. If you go to www.hpnotebooksettlement.com you will find out who we are and how we got involved.. (Althogh we are not listed).. (Better this way..
Ken
Posted on Jan 13, 2008
  • 883 Answers
Are you referring to a small coin-cell sized battery mounted to a circuit board or the main system battery?
Posted on May 29, 2007
  • 1 more comment
  • Marty marty May 29, 2007
    if the "power blinking on and off" problem came before the BIOS issue, then the problem lies on the power input section of the main board. The battery was just a desperate attempt to fix the power issue, I am assuming. Does anything at all work? Try placing a boot floppy disk in the drive and turn it on.
  • Marty marty May 30, 2007
    last attempt: try holding down F2 key or Delete key (depending on BIOS type to enter BIOS setup screen. if no success, then disassemble and try to reverse everything that got the laptop to this state
  • Marty marty May 31, 2007
    ok, search ebay for an AS-IS unit for $5 and part-swap the BIOS chip.
Sun Microsystems SPARC Enterprise T2000 OBP Firmware password reset how to ?
By "firmware" I assume that you're meaning "BIOS" here?
Not specifically familiar with SPARC or Sun software but... Pull the power cord, remove the CMOS battery, press the power button a few times...then put it all back together again after a few minutes.
That generally resets the password on any BIOS.
Apr 24, 2014 | Sun Microsystems Computers & Internet
No post sounds
Try resetting the BIOS,
1) Turn off the Laptop, remove the battery and unplug the power cable, press the power button to such the remaining power out.
2) Remove the centered back cover panel (square/rectangular section) to expose the internal board (DONT TOUCH ANYTHING)
3) Locate the cmos battery on the internal board (a medium sized battery coin (silver))
4) Remove that battery coin, turn over the laptop, plug in the power and start it up, after it says that the BIOS has been reset, turn it off.
5) Turn off the Laptop, remove the battery and unplug the power cable, press the power button to such the remaining power out.
6) Turn back over the laptop, put in the battery coin and screw the panel back onto the laptop, making sure its pressed in and is flush with the rest of the body. Put back in the screws for the panel.
7) Turn on the laptop.
It should not beep and work fine.
Dec 17, 2012 | Everex StepNote VA4103M Notebook
Lost power during bios update
This is a state your BIOS corrupted. Re-installation may not be successful. Need to re-program the chip with original BIOS.This process is technical and need expertise in that. I really don't know a BIOS reset will work for you. There is some steps you can try
Remove laptop battery and power cord. Press and hold the power button for 2-3 minutes. Put back battery and plug in power cord and start.
Remove the CMOS battery and all power in sources(laptop battery& AC adapter) and short the two terminals in the CMOS battery holder with a screw driver or similar thing. Then put back everything and press power button. I am not sure that these steps will bring your system into a working state.
try these steps before going to a re-programming
Hope this helps
Dec 11, 2012 | Dell Inspiron 8600 (8600-4Q11S51) PC...
Network adaptor has exclamation mark in bios
The first thing I would try is a hard reset. Remove the battery, AC, hard drive if you can and memory sticks. Now hold down the power button 30 seconds. Now put one stick of memory and the AC not the battery back on and power up. If you get to the "no bootable device" screen then put it all back together and try again. After hibernation sometimes it gets "stuck" and a hard reset is needed.
Feb 05, 2012 | Computers & Internet
Need to reset the bios password on my dell xps m140 laptop.
You would have to reset the whole bios to default which maybe something you cannot do. The only other method would would be to take the laptop apart and remove the battery that keeps the motherboard BIOS memory powered. It should look like a large watch battery. Remove for 5 to 10 seconds, and replace. Then put the laptop back together and that should reset the BIOS, password and all.
Apr 27, 2011 | Dell Inspiron XPS M140 Notebook
My compaq is not turning on. when i press the on button only the cd drive starts
Hi, it is more than likely a moherboard issue.
I had an MSI notebook with a similar problem, pressing the power button multiple time when turning on solved it temporarly.
You may also try resetting the bios (remove battery, unplug, remove backplate => remove small battery for about a minute then put back together).
If everything fails then you could try replacing the motherboard.
Mar 13, 2011 | Compaq Presario 700 470024-192 Notebook
Cant operate bios after reformatting the unit
If you cannot operate the BIOS, the best way is to reset the CMOS battery which require a very good technician to tear down the unit. Here are the steps:
Turn off laptop
remove cables and battery
Press and hold power button for 5 secs.
Remove screws in the edges of the laptop
Remove Hard drive, Optical Drive and Power supply fan
Press the CMOS battery (circle shaped silver coating) upwards so that it would disengage and put it back in...
Put back the Hard drive, Optical Drive and Power supply fan
Put back screws in the edges of the laptop
Put in cables and battery
Turn on laptop and the BIOS will be reset successfully...
Jan 09, 2011 | ASUS A8HE-4P017C (90NNVA4115384CAL301) PC...
Bios reset on a acer aspire 1640z
To reset the bios in a laptop you need to unplug the power supply and remove the battery. Once you do that press and hold the power button for 45 seconds then put the battery back on and plug it in and then try starting it. Everything in the bios will be reset to the factory.
Good Luck
May 04, 2009 | Acer Aspire 1640Z Notebook
I have any chance to reset on power password?
You have to search for the button 3202 battery, remove it temporarily then start it again. please dont 4get your rating. Thanks
Jan 25, 2008 | HP Compaq nc6120 Notebook
HP Pavilion zd8000 Notebook Logo
1,113 people viewed this question
Top HP Computers & Internet Experts
Alun Cox
pankaj rautela
pankaj rautela
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
