Question about Biostar NF325-A7 Motherboard
Drives - size
The 20 gb hard disk on PC has four partitions, C, D, E, F each of 20 gb.
Windows XP home service pack 2 updated to service pack 3 is installed on C:
1. Could you explain the step by step procedure to proportionately increase the size of C drive by reducing the sizes of the other three drives?
2. Can this be done without formating drive C and reinstalling windows XP?
    Problem Solver:
  • 4 Answers
Resizing partitions is easy with the right tools, and near impossible without them. You will want to first
get a good hard disk imaging program along with an external hard drive (some drives come with imaging software bundled with the drive) a few examples would be Norton Ghost, Acronis True Image, Dantz Retrospect, Powerquest Drive Image and so on. There are even some good freeware and Open Source alternatives. By imaging your c: drive to a USB external drive you can safely edit your hard drive partition tables and then put everything back with no reinstalling Windows or losing any data. You will need to have a bootable recovery CD on hand when it comes time to restore the image from the USB drive to your system drive. I would suggest that you first copy all files you want to keep from the d: e: and f: partitions to the c: partition, then image the c: partition by itself to external drive. Take note of the c: partition type I.E. FAT32 or NTFS. Make a bootable utility disk (Ultimate boot CD available from Filehippo.com for free) is one, an emergency boot floppy from Windows 98, ME, NT will work also. Boot with it and run FDISK to delete extended drive letters D E F and then their partitions and then delete the C: partition and finally create the C: partition with all available space and make it active. Replace the utility boot disk with the recovery boot cd, restart the computer and run the image recovery to restore everything back to your now 80gig system drive.
Posted on Jan 07, 2009
HP xw 4400 will not recognize my hard drive when trying to install OS Windows XP Prof.
Windows XP had a hard time recognizing hard drives larger than 127 GB. The best solution is to install Windows XP with service pack 2 or 3 already slipstreamed. Otherwise, you are going to have to partition your hard drive with at least 1 partition of 127 GB or smaller.
Dec 08, 2012 | HP xw4400 Workstation PC Desktop
How can I partition disk drives on windows xp home edition?
Try this application. Its free and its windows 8 compatible. also the app. has gained good rating on cnet.
Sep 17, 2012 | ASUS Eee PC 1000H Laptop
How do I make 4 partition on a 40GB hard disc. What are the proceedings.
Boot up with the Windows XP installation CD
Follow the screen instructions -
Delete the existing Partition.
Create a new Partition (1st) but do not make it the maximum partition size - enter 1/4 of the maximum size.
Create another Partition (2nd) make this the same size as the 1st Create another Partition.(3rd) make this the same size as the 1st
Create another Partition (4th) make this the remaining max. size.
Format the Ist Partition Full NTSF (not quick format)
You can now proceed to install Windows on the 1st Partition.
After Windows XP has been installed and the computer's device drivers, go to Control Panel - Administrative Tools - Disk Management then allocate a drive letter to each of the Partitions then NTFS Format each of the Partitions.
Now each of the Partitions should indicated as Healthy.
Create
Dec 09, 2011 | Samsung (SP0411N) 40 GB Hard Drive
I want to format my pc and fix xp service pack 2.how can i will be able to do this???
Hi, before you format your hard disk, make sure you have saved all important files that you like to keep on an external drive, for example a USB Stick. Formatting your hard disk will destroy all data.
If you want to format and reinstall Windows XP do the following:
Insert your Windows XP CD. Restart your computer. Your computer should then automatically start from the CD and show the Windows XP Setup.
In Windows Setup you can choose the partition on which you want to install Windows. There you can also format the partition, before installation. To do this, just follow the directions that are shown.
Jul 12, 2010 | Computers & Internet
Why does my pc freeze when playing flash and 3d games i already updated all my driver but still i cant play any games, i crashed!!!! i cant even run the direct3d test in dxdiag, lately error message i...
well the problem is you graphics card is a lttle bit old now and the driver update doesn't work properly for that i my self personnel used a fx 5200 card and when i updated to a news drive i couldn't even played the game that work properly before in your situation you have not mention the driver version you updated to i thing it is 1xx.xx please uninstall the current driver and go back to a 9x.xx or 8x.xx version driver give an google search for nvidia driver archive,or try softpedia good luck please update me with your progress
Apr 10, 2010 | Microsoft Windows XP Home Edition
My brand new seagate hard drive is showing on 120 gb space on partition time?
it means your hard disk have 120 gb capacity, you can make partition according to your requirement.
Apr 02, 2010 | Seagate 500GB Barracuda ES.2 SATA 3Gb/s...
Computer sees drive as Generic USB Device
Hi Brian, It certainly sounds like either your drive enclosure or the drive itself has some failed circuitry. You can try moving the drive into a new enclosure, if you're not sure how, take it to a local computer shop and have them transfer it into a new enclosure and test it for you. If it works in the new enclosure, you're done! If not reply back here by adding a comment with your country and city and I'll pass along a recommendation for somewhere to send the drive for data recovery. Chris
Jun 05, 2009 | Cavalry Storage EXTHD 500G|CAVA U2&ESATA...
My Hard Drive is 250 GB but I only see 137GB
Windows xp has a max Hard drive limit of 137GB, so what you see is totally right.
Windows XP did not support 48-bit LBA for ATAPI disk drives, which is what larger drives needs.
The service packs do address the problem but you need to have a copy of windows xp which includes at least service pack 1 on the installation.
The problem is when you install from your original disk, it doesn't include the service packs, so by the time you have got the system up and running the hard disk space has already been allocated.
Bios update wont help
controller card won't help either
Possible solutions:
If you can get hold of a new version of XP which includes at least service pack 1, you can re-install with this disk and it should find all your hard disk space
or
You can do what is called 'slipstreaming', this is when you burn the original XP disk and the service packs together on one disk, but it does take a bit of working out.
here are a few links which may help you more:
http://lifehacker.com/386526/slipstream-service-pack-3-into-your-windows-xp-installation-cd
http://support.microsoft.com/kb/303013
hope this al least sheds a little light on the problem
Bri
Feb 02, 2009 | PC Chips MB PCCHIPS M863G V5.1C w/XP2400+...
I`m unable to install windows 98 in seagate 80 gb ide barracuda hdd
For W98, if you create the bootdisk from within windows, you will need to go here to download the newest version of FDISK.EXE then copy it to the bootdisk, allowing it to overwrite the older version. This way you will have support for larger harddrives.
FDISK LIMITATION WITH 64GB DRIVES:
Why does FDISK not recognize my disk (or RAID array) which is larger than 64GB?
There is a bug in Microsoft's FDISK under Windows 95B, 98 and 98SE that can be corrected by downloading a newer version. See Knowledge Base Article Q263044 for more information.
http://support.microsoft.com/default.aspx?scid=kb;EN-US;q263044
When you use Fdisk.exe to partition a hard disk that is larger than 64 GB (64 gigabytes, or 68,719,476,736 bytes) in size, Fdisk does not report the correct size of the hard disk.
The size that Fdisk reports is the full size of the hard disk minus 64 GB. For example, if the physical drive is 70.3 GB (75,484,122,112 bytes) in size, Fdisk reports the drive as being 6.3 GB (6,764,579,840 bytes) in size.
NOTE: This hotfix is not designed for 48-bit logical block addressing (LBA) hard disks, and it is not supported on hard disks larger than 137 GB. However, even if the drive is physically larger than 137 GB, if you create partitions smaller than 137 GB, this FDISK.EXE version will work correctly. (THE FORMAT COMMAND WILL SHOW THE DRIVE AMOUNT IN DOS TO BE OFF THE MARK, BUT WILL BE CORRECT WHEN YOU GET INTO WINDOWS ITSELF)
Direct English Version download:
http://download.microsoft.com/download/Win98/Update/8266R/W98/EN-US/263044USA8.EXE
This package installs the updated Fdisk.exe to the Windows\Command and Windows\Options\Cabs folders, on a computer running Windows 98 or Windows 98 Second Edition. If you are starting a computer from a Windows 98 Startup Disk in order to partition and format the hard disk, you should copy the updated Fdisk.exe from the Windows\Command folder to the Startup Disk, replacing the original Windows 98 or Windows 98 Second Edition version of Fdisk.exe on the Startup Disk.
Dec 25, 2008 | Seagate Barracuda 7200.7 ST380011A 80 GB...
Only 100gb of my 200gb hardrive are showing
Welcome to the wonderful world of windows disk size limitations.
What you are running into is the Windows 137GB Capacity Barrier AKA the 48-bit Logical Block Addressing Support for ATA (IDE), Serial ATA or ATAPI disc drives.
In English this means windows will only “acknowledge” between 127 and 137 Gig of a disk drive without some updates.
In most cases after he latest Service Packs are installed, any additional gigabytes will show up as unallocated space on the drive and you can create a second partition with the Windows disk management tools. Unfortunately this will mean that you have 2 partitions on the drive (if you placed your os on the drive or partitioned it before the updates were installed.).
If this is a secondary drive (in other words your OS is on a different disk drive), install all of the system updates first, you should then be able to format the entire drive as one partition.
Dec 20, 2008 | Seagate (ST3100203U2-RK) (ST3100203U2RK)...
Biostar NF325-A7 Motherboard Logo
99 people viewed this question
Top Biostar Computers & Internet Experts
Jayburt
David
David
Jerry Umali
Are you a Biostar Computer and Internet Expert? Answer questions, earn points and help others
