Question about HP Photosmart C8180 InkJet Printer
Hp c8180 printer ink system failure
I nk system has failed, unable tto print. error flashing light stays on
  • 404 Answers
Check your inkjets pullout ,put back turn off try again
Posted on Jan 07, 2009
  • 679 Answers
Check the cartages of your printer may be need to replace.
  • rockfixya
    rockfixya Jan 07, 2009
    check out the link :
    Thanks for using FixYa.
  • rockfixya
    from a link;
    Issue Cause:
    The is related to the physical condition or the All-in-One unit. However, I suggest you to perform the following steps.
    Solution 1:
    1. Press the On button to turn the printer off.
    2. Unplug the power cord from the back of the printer.
    3. Remove all the ink cartridges.
    4. Wait two minutes.
    5. Plug the power cord into the back of the printer.
    6. Press the On button to turn the printer on.
    7. Install the ink cartridges when prompted.
    If the error code does not display, the issue is resolved.
    NOTE: Clicking the links may give an error indicating it is invalid. If this occurs, copy the portion of the address on the remaining line(s) and paste it at the end of the address showing in your browser until the complete address is displayed in the Address box.
    Now, check the functionality, if the issue persists, please perform the below steps.
How do I fix ink system failure error message on a hp photosmart c8180 even though I have replaced all cartridges. Need to rest the system any ideas?
i love google.... usually:
Jun 24, 2014 | United Stationers HP Photosmart C8180...
ERROR 0xc18a0001 Ink system has failed Quite new
Try the link below. This error is related to air in the lines between the print head and the cartridges. It is quite common and HP are very aware of this.
I hope this helps. Regards GM
Apr 16, 2011 | HP Photosmart D7360 All-In-One InkJet...
Ink system failure
This is a very common problem if you use refilled cartridges or let your ink run really low. The "Ink System Failure" error is causes by air in the ink feed tubes. We have a step by step guide purging the air from the feed tubes posted on our web site. Go to our site at: , click on the printer repair link and then the HP link. Follow the steps and you should be back printing in no time at all.
I hope this helps, If so please rate our solution.
Corporate Computer
Jan 05, 2010 | HP Photosmart C5180 All-In-One InkJet...
HP Photosmart C8180 - Ink System Failure - Oxc18a0101
i had exactly this error message. Rang HP. They said it was a hardware failure, they couldn't fix over phone, would cost 2x cost of new printer to fix, but they offered me 20% discount on new printer if ordered over the phone.
But with some fiddling, problem now resolved. Here's what I did:
- press Red Eye Removal and Print Photos button together
- goes to Mfg Commands -> Enter Special Keys Combo. Press OK
- uaiux Support page (some code) -> click right arrow key until you get to System Configuration Menu - click oK
- should say hardware failure status - click OK
- says hardware failure status: Clear. Press OK to clear
- I clicked OK on this and system reset itself and problem was solved
Jun 24, 2009 | HP Photosmart C8180 InkJet Printer
ERROR 0XC18A0001
Press the On button to turn off the printer.
Unplug the power cord and universal serial bus (USB) cable from the back of the printer.
Wait for 30 seconds.
Plug the power cord back into the printer.
If Ink system failure does not display, the issue is resolved; reconnect the USB cable and resume using the printer.
If the previous steps have not cleared the message, let us update the printer Firmware and check.
Please click on the below provided web link :
Once you open that web link, please follow the steps provided below :
Installation Instructions
1. Disconnect all other USB devices from the PC.
2. With the HP Photosmart 8250 series printer directly connected to the PC, click on "FirmwareEnable_Release.EXE"
3. If the ink system failure condition returns contact HP to service the printer.
Note: Do not use this patch if there is any visible ink around the product. In this case contact HP to service the printer.
This should resolve the issue.
Good Luck!!
May 06, 2009 | Office Equipment & Supplies
These error codes indicate that the product has an internal condition. Solution one: Reset the product Use the instructions below to resolve the issue by restarting the product.
  1. Disconnect the Universal Serial Bus (USB) cable from the back of the product, but leave the product turned on.
  2. Open the cover of the product and remove the print cartridges.
  3. Close the cover and wait for the Insert Ink Cartridges message to display.
  4. Disconnect the power cord from the back of the product and wait for one minute.
  5. Reconnect the power cord. If the product does not automatically turn on, press the Power button.
  6. Open the cover and reinsert the print cartridges.
  7. Close the cover. If prompted, print a calibration page.
  8. Reconnect the USB cable, and try to print a print job from the computer.
Solution two: Service the product If you have completed all the steps listed above and are still experiencing a problem, service the product.
Oct 23, 2008 | HP Photosmart C8180 All-in-One InkJet...
Ink system has failed. Error:0xc18a0001 my printer is HP Photosmart C6280 All-in-One i have an Error massage (Ink System Failure)it says: ink system has failed. unable to print. refer to printer...
ok i got it...
Press and Hold the “Print Photos” &”Red Eye Removal” buttons. Release both buttons. Display should say”Enter Special Key Combo”
Press and release in sequence”Red Eye Removal”,”Print Photos”,”Red Eye Removal”
Display should say “Support” and display the FW rev: COxxFN0723BR (or something like that)
Press and release the right arrow button until the display says “System Configuration Menu"
Press and release the “OK” button.
Display should say “Hardware failure status: Clear. Press OK to clear”.
Press and release the “OK” Button. Message changes to “Hardware failure status Cleared. Press Cancel to continue”.
Press and release the “CANCEL” button as many times as necessary, so that, either the “Welcome to Photosmart Express” screen appears, or, the “Ink System Failure” screen appears. PLEASE DO NOT TRY TO PRINT AT THIS STAGE.
Using the Power Button, turn the unit OFF and unplug the power cable from back of the printer and wall outlet.
Wait 30 seconds for the power to get discharged and then plug the power cable into the wall outlet first and then into the back of the printer
Turn the unit on. The printer may display message “USE POWER BUTTON TO SHUTDOWN THE PRINTER” followed by “PRESS OK TO CONTINUE”. Press OK.
the printer will get ready as if it were starting perfectly for a first time, it will say something like: printer preparation occuring - do not interrupt
print a test page:
1) Load letter, A4, or legal unused plain, white paper into the input tray.
2) Make sure that the printer is on and loaded with unused plain, white paper.
3) Press Setup . The Setup menu appears.
4) Press the down arrow button to select Tools , and then press OK .
5) Press the down arrow button to select Self-test Report , and press OK . The self-test report prints.
if this doesn't work, i'd call hp support.
Oct 02, 2008 | Office Equipment & Supplies
HP Photosmart C8180 InkJet Printer Logo
135 people viewed this question
Ben Johnson
