FixYa.com
Tags:
TDK DA-3826 2-Disc CD Recorder
Lost the manual, can't get hooked up
posted by Fjords on May 28, 2007
I have a TDK DA 3826 2 disc recorder. I want to help my Dad convert his cassettes - many recorded live - onto CDs. I don't know how to wire from the cassette player output, to the CD burner and back to the amplifier (which is separate from the cassette deck) so we may listen and record.
Probably could do it if I still had the manual, but it got lost in one of my last 3 moves (military nurse - moves around alot). I don't have the remote either. But I do have all the cables.
I tried connecting the cassette output to the CD recorder input, then from the CD recorder output to the amplifier. I get no static, no music. With a blank disk in the recorder, when I hit the record button, the error message "No Audio" comes on.
The cassette player plays the tape. The CD recorder will play any pre-recorded CD through the amplifier. I don't know where I'm making the error(s).
Can you give me a recipe to follow? Thank you.
Ronni
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Best Solution
posted on Dec 09, 2007
Helpful (85)
wjkdgquej
Rank:Guru Guru
Rating: 85%, 63 votes
You need to use an audio CDr, data or computer CDr's will not work in this machine. I don't know this specific machine, but usually you select the input, then 'rec type' eg manual,1 track or 1 disc,then press record to get into record pause,start your source,then press play on the unit to start recording. To finalize, you press finalize then either the play or rec button to start the finalize process.
Was this solution helpful? Show your Appreciation by rating it:
Can you Help with these CD Players problems?
CD Players
Denon cd player
the display on the cd player... Answer This...
CD Players
cd changer d2b
hope to find philips cd changer... Answer This...
luis33798@hotmail.com
I have tdk-da-3826 and the slot... Answer This...
tdk cd recorder da-3826...
sometimes when i am recording,... Answer This...
TRACKING
how do you tracking each... Answer This...
Repair Service
Find CD Player Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
