Question about Jabra BT125 Headset
Can't pair Jabra BT125 with O2mini
I try to pair my Jabra BT125 with O2 mini according to the instruction but the O2 can't see the headset. i try several times. pls suggest me how to solve it.
    Sergeant:
  • 431 Answers
Check the bluetooth is in visible mode or not
Posted on Jan 08, 2009
I've just bought a Nokia E72 and seem to have problem pairing my Jabra bt125
Go to this site, and it will walk you through each step to connect your particular Jabra headset with your Nokia E72. Choose the headset, and then at the next page, choose your phone. Moving your mouse over each step will change the picture to what you should be seeing on your phone at each step.
http://jabra.pairx.co.uk/ Pls come back and let us know if this solved your problem.
Dec 14, 2009 | Jabra BT125 Headset
This is my first bluetooth and I'm having a problem getting my Jabra BT125 into discovery mode
The Jabra goes into discovery mode when the unit is off, and the power button is pressed for ten seconds, which passes the five second power on time.
At ten seconds the unit lights constant to state discovery mode is on.
See the manual on Pairing:
To download the PDF of the Manual click here. This is page 6.
Dec 12, 2009 | Jabra BT125 Headset
How do i program my jabra bt125 headset to my cell phone
taken from the manual found at
http://www.jabra.com/sites/Jabra/GNimages/Products/WirelessHeadset/BT125%20Black/Documents/User%20manual/BT125_UM_NA_EN_471.pdf
1. Put the headset in pairing mode
• Make sure the headset is off .
• Press and hold the answer/end button until a solid blue light comes on.
2. Set your Bluetooth phone to ‘discover’ the Jabra BT125
Follow your phone’s instruction guide. This usually involves going to a ‘setup,’ ‘connect’ or ‘Bluetooth’ menu on your phone and selecting the option to ‘discover’ or ‘add’ a Bluetooth device.* (See example from a typical mobile phone in fig. 3).
3. Your phone will find the Jabra BT125
Your phone then asks if you want to pair with it. Accept by pressing ‘Yes’ or ‘OK’ on the phone and confirm with the passkey or PIN = 0000 (4 zeros). Your phone will confirm when pairing is complete. In case of unsuccessful pairing, repeat steps 1 to 3.
Dec 04, 2009 | Jabra BT125 Headset
I cant pair my jabra bt125 with my nokia n97
This is one of the mistake commonly done by many people. First you need to pair. Let me walk you through. First, the headset has to be switched to pairing mode which is done by holding the on button for a while even after the headset is switched on. Then the bluetooth headset light will remain on. You switch on the phone bluetooth, search new device. Then select it and press the option for pairing. Read the instructions which come on the phone display and select accordingly. It will ask for passcode which is usually four zeros. Then it will get paired ask you whether to connect. You select connect and you are done.
Sep 02, 2009 | Jabra BT125 Headset
How to pair the jabra BT125 headset with personal computer to here songs without using head phones
hi vrajasekar20, thank you for using fixya.
to pair your jabra to a PC for headset use, you have to install the jabra PC Suite first and use it as your default sound input / output device.
The PDF file below will give you a step by step instruction on how to have it installed and working.
http://www.jabra.com/sites/Jabra/GNimages/Products/Adapter/A330/A330_FAQ_EM_EN_2838.pdf
Should you need more info on this matter,please do not hesitate to let us know.
regards,
voodoo
Apr 17, 2009 | Jabra BT125 Headset
Google g1 phone jabra bt125
Make sure the Jabra headset is set to pairing mode, otherwise the phone cannot find the headset. The manual should have instructions to set the headset in pairing mode. While the headset is in pairing mode, have the G1 search for the headset (Settings > Wireless Controls > Bluetooth Settings). When it finds the headset select it and type 0000 for the PIN code.
Apr 15, 2009 | Jabra BT125 Headset
Registering and pairing with the ps3
Go to PS3. Accessories Setting -> Manage Bluetooth Devices -> Register New Device**
** = You need to have Jabra BT125 in Pairing Mode. Hold the button for more than 10 seconds till it's a solid blue (initially turned off). Then detect it with your PS3.
If it asks for a password it's "0000"
Mar 23, 2008 | Jabra BT125 Headset
How to pair my Jabra BT125...
Instructions for the Jabra BT125 Bluetooth
For people who are having problems pairing their cell phone with their Jabra BR125 Bluetooth, here are a few simple steps:
First, make sure that the Jabra BT is off (the light should be off). If it's on, hold the flashing button until it goes off.
Second, turn your Jabra BT on. Continue holding your Jabra button (EVEN AFTER IT STARTS FLASHING). Hold onto it UNTIL YOU GET A SOLID LIGHT.
Third, as soon as you get a solid light try pairing up with your cell phone.
Fourth add your Jabra to your cell phone's Bluetooth list by having it search for the Jabra.
Fifth, the cell will ask for a passcode. The default passcode is 0000.
Aug 17, 2007 | Jabra BT125 Headset
Jabra BT125 Headset Logo
80 people viewed this question
Top Jabra Radio Communications Experts
TO Lady
Greg Cann
Greg Cann
Michael Vincent Cruz
Are you a Jabra Radio Communication Expert? Answer questions, earn points and help others
