2005 Kia Sorento Logo
Posted on Nov 15, 2012
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Back windshield wiper won't turn on
danoyachtcap
Level 3:
Top Expert:
  • Kia Master 2,907 Answers
  • Posted on Apr 20, 2015
danoyachtcap
Kia Master
Level 3:
Top Expert:
Answers
2907
Questions
Helped
1275626
Points
52081
Here are some more common problems.
  • Motor:
The wiper motor is commonly replaced and was often not the problem. Don't replace the motor yet. maybe it's not the motor. It could be a fuse or something at the wiper switch. The wiper motor has two windings, fast and slow. The wiper switch sends a ground signal to each motor winding. More often, there are problems with the relay, or at the wiper switch, or in the cable to the motor.
  • Windshield Washer:
Don't be too quick to replace the washer pump. The problem is often just a clog in the sprayer heads. You can clean out the sprayer holes with a needle, some have two holes, so look closely. Hope this helps.
1 Related Answer
Mike Ceslow
  • 206 Answers
  • Posted on Sep 19, 2012
SOURCE: The wipers stop on the windshield when off & viarabel doesn't work
arms in wrong spot or motor control switch(-flat box connected to motor) dirty or bad
If you need further help, I’m available over the phone at https://www.6ya.com/expert/mike_9693b5ad75773352
2answers
Ihave a 2003 Ford Explorer & the windshield wipers won't stop working, with the switch turned off or even removed. The only way to stop them is to remove the battery cable.
Sounds like the park switch in the wiper motor is bad.Some manufacturers allwo you to change the circuit board seperately from the motor,sometimes they have to be changed as a unit
2answers
Windshield wipers won't shut off
Turn wipers to off then turn the car off. We have the same problem in our 1986 Pontiac parisienne brougham
1helpful
1helpful
Headlights won't come on
Multi function control switch has to be replaced.
2helpful
2answers
2helpful
Windshield wipers work when fuse is in but won't turn off unless you remove the fuse. Won't pass inspection. Help!
Check the relay relay maybe latched on. See if there is an identical relay in the box and swap them if problem goes away replace relay.
3helpful
Turn on windshield wipers but they won't turn off
The WS wipers in this truck are controlled by a central module that is called the GEM, this module can be scanned to find the fault wirththe wipers, it could be the GEM that is defective or the wiper motor is defective. It also controls the WS washers do they work?
4helpful
How can i turn off my windshield wipers on my 2004 trailblazer they won't turn off
There are only to things which could cause this.The wiper motor cover or the switch itself.Which is part of the multi-function switch.The cover is cheaper.It is located under the air inlet grill.The cover is on the wiper motor itself.There is a circuit board on here that causes this problem.It is the part you need to replace.Hope this helps.Good luck.
Top Kia Experts
ZJ Limited
ZJ Limited
Thomas Perkins
Thomas Perkins
Are you a Kia Expert? Answer questions, earn points and help others
