Question about Haier HD451E Dehumidifier
Does not dehumidify at all
My dehumidifier runs well, it is only 1 year old,it worked great last year. This year the fan runs and the humdity sensor works, but there is no water at all in the basin. Do you have any solution to my problem? It also doesn't look like anything is clogged, it is just not dehumidifying. Thank You.
  • Ronald Smith May 29, 2007
    it was wintered in a warm basement! should i check the freon.
  • 883 Answers
Was it wintered in a warm or a freezing area-which? freezing storage is bad news for these. it somehow makes all of the freon leak out
Posted on May 29, 2007
  • Marty marty Jun 01, 2007
    yes, it may have leaked out, but the cost (mostly labor) may be close to buying the whole unit
  • 78 Answers
SOURCE: Forgot my username cant log into laptop, help
Posted on Sep 22, 2014
Where can I buy parts for my dehumidifier?
Humidity Sensor Replacement Part 1 of 2 - YouTube
? 12:34
www.youtube.com/watch?v=fWmupgWoduU
Sep 22, 2012 - Uploaded by John Hinkle Part 1 of 2: A totally amateur do-it-yourself video of replacing a humdity sensor (Danby part # DB95-01036A ...
Sep 27, 2015 | Dehumidifiers
Dehumidifier fan
Please get the manual from http://www.maytag.com/support/manuals_literature.jsp
and make sure the settings are correct or adjust the settings.
Let me know if you need anything else.
Thank you,
Ekse
Jun 23, 2008 | Maytag M7DH65B2A Dehumidifier
My dehumidifier runs and the refrigerator or cooling unit turns on, but no water comes into the bucket? Last year it was running fine? fans run and the humidity level is high in the basement
There are many reasons why a dehumidifier willnot work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrongwith their dehumidifier
Dehumidifier is running but no water is in bucket
heatman101
Jun 09, 2011 | LG LHD45EL Dehumidifier
My small inexpensive dehumidifier stopped working, its trying to start but just can't. I have never cleaned it, lost the instructions. 1 yr. old it worked great all this time . Thanks Johnny L. PS its...
There can be many reasons why a dehumidifier willnot work or collect water.
http://www.fixya.com/support/r4662409-dehumidifier_running_but_no_water_in
heatman101
Sep 17, 2010 | Eva-Dry EDV1100 Petite Mini-Dehumidifier...
Fan runs, seems to work ok... but not pulling water out of the ai
There are many reasons for a dehumidifier tto not work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrong with their dehumidifier.
heatman101
Apr 16, 2010 | GE AHK40LK Dehumidifier
My Haier dehumidifier Model #39R171E is operating intermittently. The bucket is not full - power is on - temp in room says 59- do I increase the humidity to get it to work? Have a large amount of water in...
If your carpet is wet ... like mine was ... the best thing to do is bite the bullet and get the carpet out of your basement or where ever it is ... so your dehumidifier has a chance.
You reduce the % on the machine to reduce the humidity in your room. You should probably also get some fans going.
I have removed my carpet and padding and everything that I can reasonably remove from the room. I have 4 fans going and 2 dehumidifiers and two sump pumps. I also keep the windows open in the day time because it is more dry outside than in the basement. I have heat in the basement which I run at night. My goal is to save my house from damage due to moisture. It will be a good month for the electric company, that is for sure.
I'm sorry you are in this perdiciment ... I'm sorry for me too. My carpet was less than a year old and we have not had any water in the basement for 30 years.
Mar 03, 2010 | Haier HDN655E Dehumidifier
The dehumidifier runs all day but there is only a little water being produced. We have humidity set at 35%, and the actual readings are much higher. This is only a year or so old. The last machine worked...
coolant may be low - warranty should be 5 years
If the room temperature is close to 60, the coils may be frozen (completely encased in ice). If this is the case, move it where the water can drain off - about 1 gallon which may NOT run into the drain bucket.
I out mine over the floor drain.
Turn off and it will defrost over night.
Only specially made dehumidifiers work below a room temp of 60 degrees (the temp of a basement in winter).
Does it need to be running? A digital humidity sensor from Radio Shack is cheap and may tell you the humidity is OK - only 50% or less.
Dec 10, 2009 | Fedders A7DH45B2A Dehumidifier
My dehumidifier fan runs but is not taking any moisture out of the air. It is not very old. Last year it worked great.
More than likely you have developed a refrigerant leak. The cost of a diagnosis alone from a technician is almost at the price of a new one. Leak test and repairs will put you over the cost of new.
Oct 04, 2009 | Fedders A7DH45B2A Dehumidifier
Dehumidifier running but no pulling any water from the room
Check float switch some of the unit have afloat switch hooked to the unit. Next check the condenser coilsThey do get stopped up cat,dog hair and just plain get dirty vaccuum them out and try unit. Rusty
Jun 12, 2009 | Bionaire BDQ24 Quietech Dehumidifier
Kenmore 580-51650000 dehumidifier
It is more than likely the compressor is not running, only the fan.
It seams that the humidity sensor is flaky on these units. You can,
operate the unit, by opening up the dehumidifier and unplug the sensor from the main board. The unit will cycle on and off and remove the water from the air.....good luck
Apr 21, 2008 | Kenmore 54501 Dehumidifier
Haier HD451E Dehumidifier Logo
307 people viewed this question
Top Haier Dehumidifiers Experts
Evan Benson
Evan Benson
Bill Long
bigdaddyd2
Are you a Haier Dehumidifier Expert? Answer questions, earn points and help others
