FixYa.com
Tags:
Unitech Handheld
Barcode reader (by 2 users)
posted by tdhofstrom on May 28, 2007
I am having trouble with a barcode reader I purchased from Keenzo earlier last fall. It is not reading the whole barcode number, about one out of 7 or 8 scans. If the barcode number is 00014567, it might read 00000014 or 00000001 and sometimes it puts the letter J in there! It has done this on different types of barcodes, new ones, old ones, ones generated by different companies, etc. I have tried cleaning the glass, but that doesn't seem to help. Is there something I can do to it without sending it in? Is is still under warranty? MS330
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
1 Other User Has The Same Problem
Comment by croberts55, posted on May 24, 2008
I have Unitech Barcode Reader MS331-1G Scanner. It will read the barcode, but I don't know where the reading is going. I have a billing company I need it to go to and also Quickbooks 2008.
Solution #1
posted on Nov 17, 2007
Not Rated (0)
diazphi
Rank:Wiz Wiz
Rating: 79%, 206 votes
This is a setting issue of your barcode scanner, the only way to solved the issue is to find the manual and look for the settings that are most likely what you need to display and send data.
Please rate me solved if you like my solution.
Best regards,
Philip
Was this solution helpful? Show your Appreciation by rating it:
Can you Help with these Barcode Scanners problems?
Barcode Scanners
CD / DVD player not listed as...
R40 Thinkpad - 4 years old -... Answer This...
Barcode Scanners
samsung ser 6500 11
I have a samsung 6500 II in my... Answer This...
Barcode Scanners
ba falcon
my car would not start after... Answer This...
Barcode Scanners
FALCON 320 Image is reversed
Client says that the image... Answer This...
Barcode Scanners
Problems when I try to install...
I get to install it but When I... Answer This...
Repair Service
Find Barcode Scanner Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
