Question about T-Mobile Sidekick ID Cellular Phone
Sidekick Id screen.
My Sidekick Id's screen is not lighting up, but the buttons lights up. I did went to settings and changed the brightness to 100%. But still no light showing on the screen, but i can still see pictures etc, but not at night. In the dark i cant see nothing except my buttons. How do I fix it?
  • Anonymous Jan 10, 2009
    My sidekick id backlight wont cut on anymore
  • Anonymous Jan 18, 2009
    My screen is also not lighting up.
At a t mobile company they have extra sidekick screens tell them your problem they will fix it they will wrap it for you or they put it on for you there
Posted on Jan 15, 2009
Sidekick Gekko Wont Turn On
try to charge phone battery in 12 volts dc
Jul 17, 2009 | T-Mobile Sidekick ID Cellular Phone
Sidekick id charger light comes on but phone wont the screen wont turn on but charger light is on
Sounds like you unit is not charging. The Sidekick ID's are notorious forthat. If you have a friend that has a sidekick ID or Sidekick 3, see ifyou can try their battery to make sure you phone is working ok.
If so, your best option is to get an external charger that has a sparebattery slot That way you can charge the battery outside the phone!They run about 25-30 dollars on ebay. an extra battery is a good idea so you can have one charger at all times.
Sidekick ID and Sidekick 3 External Battery Charger
Jun 29, 2009 | T-Mobile Sidekick ID Cellular Phone
No backlight
A couple things to try:
1st check the backlight settings
Turn on Backlighting and Control Brightness To use your device in dark environments, enable the automatic backlighting feature:
  1. From the Jump screen, press MENU t02003-15.gif then select Settings > Battery & Display.
  2. In the second group box, select the Turn on backlight when using device check box.
  3. Highlight, then select the Brightness slider to open it for editing. Roll the TRACKBALL right to increase brightness; roll the TRACKBALL left to decrease brightness. After you've made the adjustment, press the TRACKBALL to exit edit mode. t02007-55.jpg
  4. Select the length of time you want backlighting to stay on from the Turn off after pop-up menu.
  5. To use the device's light meter while the backlight is on, select the Use ambient light sensor check box.
  6. Press JUMP t02003-14.gif to return to the Jump screen and save your setting.
Now, when you press any button or key, or flip open the screen, backlighting will turn on for the set amount of time. Note that as long as you press a key or button before the set time elapses, the backlight will stay on.
Tips:
  • Even if you have not selected automatic backlighting, you can turn on backlighting at any time by pressing MENU t02003-15.gif + JUMP t02003-14.gif . The backlight will remain on for the time specified in the Backlight Turn off after pop-up menu.
  • When in key guard mode, you can turn on the backlight by pressing the RIGHT SHOULDER t02003-66.gif button.
If it still does not work, then you can try resetting the flex cable to the lcd.
Reseat the SidekickFlex cable
If that doesn't fix it then a new lcd assy will take care of the issue. they run about 45 dollars on ebay.
Sidekick LCD screens
Apr 26, 2008 | T-Mobile Sidekick® 3 Cellular Phone
Sidekick iD screen white
take out the battery blow it 15 times then blow the back of the phone 15 times your hardest then out the battery back into place and then the loading screen would show thats what happen to me i hope it works good luck
Mar 28, 2008 | T-Mobile Sidekick ID Cellular Phone
My sidekick id
Is the screen white or black?
If it is white you may be able to fix it, black maybe not.
The following instruction for a sidekick 3 but it is the same for a sidekick ID. Just reseat your lcd instead of installing a new one.
Sidekick 3 LCD Screen Only Replacement
Mar 23, 2008 | T-Mobile Sidekick ID Cellular Phone
Backlight on sidekick 3
Because your screen is broken and that can only be fixed if you have it replaced.
Jan 14, 2008 | T-Mobile Sidekick II
Sidkeick 3 backlight
Have you tried checking the Battery and Display settings from the main screen Settings menu? There is an option to enable or disable the backlight, as well as set the brightness.
There is also a setting called "Use ambient light sensor", which sets the backlight and keyboard light to only turn on if it is dark when you are using it.
Sidekick 3 screen problem
This procedure usally will fix a white screen on a sidekick 3 or a sidekick ID.
http://www.repairmysidekick.org/Fix-Sidekick-White-LCD-Screen
Try this before you replace the LCD
Dec 06, 2007 | T-Mobile Sidekick® 3 Cellular Phone
Screen light wont turn on
The problem may lie in the settings-->System-->Backlight-->Battery Power--> Make sure you check "Turn on backlight when a button is pressed...." I believe this is a firmware bug. Do the same for external power.
Jun 23, 2007 | T-Mobile Sidekick II
T-Mobile Sidekick ID Cellular Phone Logo
112 people viewed this question
Top T-Mobile Cell Phones Experts
Starnley Johnwells
Starnley Johnwells
Computer Repairing
Computer Repairing
Are you a T-Mobile Cell Phone Expert? Answer questions, earn points and help others
