Question about Frigidaire ATF6000ES Front Load Washer
Agitator drum only rotates in one direction
During wash and rinse cycles drum will turn for 10 sec± in same direction as spin; it pauses for sometimes 2, sometimes 10 sec, then continues again in the same direction; the most likely culprits seem to be timer, speed control, and motor, all of which are expensive so I want to replace to right one
  • ROBT KING Jan 17, 2009
    corrrection: The correct model number is fwtr445rfs0, not ATF6000ES
    New Friend:
Just fixed mine. The timer control dictates the direction of the spinning, not the speed controller. Replace your timer control and it should fix your problem. I picked on up on line for about 75$.
Posted on Apr 12, 2013
  • ROBT KING Apr 12, 2013
    Actually, the problem was that I had one lead on the timer plugged to the wrong tab. It was on 21B instead of 21.
  • Frigidaire Master
  • 1,527 Answers
Yeah it sounds like the programer has failed this part is expensive
shaun
Posted on Jan 18, 2009
Frigidaire topload washer inner drum not rotates during wash cycle
inner drum is not supposed to rotate . just the agitator .spin cycle is when that will rotate
Sep 28, 2016 | Frigidaire Washing Machines
Drum or basket rotates 3/4 turn one direction the pauses 10 seconds then rotates 3/4 turn the other direction during wash cycle. Does the same during spin cycle.
This is normal operation for the machine It is doing this to get detergent and water to all of the loaded cloths and also to balance the load for when it is washing and spinning
Nov 05, 2015 | Maytag MAH21PD Front Load Washer
Oko 72630. Why is it stuck on rinse cycle?
Could be several reasons:
- Selected the "Night cycle" program (means standing with the drum full of water, reason: too much noise in the spin cycle)
- Set to the "Rinse hold" (means standing with the drum full of water, reason: wrinkles on the clothes)
According to your description I think that this is not a failure otherwise error E20 will be appears on display.
Once the washing programme has come to an end, END illuminates on the programme progress display.
If RINSE HOLD was selected, the display beside the START/ PAUSE button flashes.
1. After a rinse hold, the water must first be pumped out:
- Either press the START/PAUSE button (the water is pumped out and the washing is spun according to the completed programme;
After the START/PAUSE button is pressed again, the spin speed can still also be changed during spinning), or
- Turn the programme selector to PUMP OUT and press the START/PAUSE button (the water is pumped out without spinning),or
- Turn the programme selector to SPIN or SHORT SPIN and press theSTART/PAUSE button (the water is pumped out and the washing is spun or gently spun).
At the end of this programme step, the END indicator will illuminate.
2. Open the door.
As soon as the DOOR indicator lights up green, the door can be opened.
Dado
Aug 15, 2015 | AEG Washing Machines
Limited agitation during wash cycle Load Sense OK
Possible that the program selected is an easy wash as this is meant for daily wash , less soiled clothes.
If however the same situation is present in all the cycles then the capacitor to the motor must be checked as it can reduce the speed of the motor.
Also check the belt , check for friction on the drum spindle and the motor.
Jul 22, 2011 | LG WT5001CW Washer
I have a maytag over capacity plus heavy duty 2 speed 10 cycle washer it fills with water fine you hear the motor kick in to girate but doesent spin or you put it on spin cycle it sounds like it is...
The motor is working, but the mechanism not engaged by the helix so the shaft can not move therefore no agitation or spinning. Motor is designed to turn 2 directions: clockwise and counterclockwise for agitation and spinning. Therefore there are 2 mechanisms to assist these tasks. The drain is control by a separate pump and it is still good also.
The tube has to be out to replace the helix for agitation and a part to engage with the spinning rotation to release the brake so the spinning function can work. These parts are cheap, but the the labor is not. Hope this can help
Jan 09, 2010 | Washing Machines
Washer makes a loud, pulsing, screeching noise with no spinning
With a manufacturing date of 7/15/97, your washing machine is clearly worn out.
Nov 07, 2017 | Whirlpool Washing Machines
Kicking out water during wash cycle - spin instead of agitation
Try these
  1. Check the drain hose, it should be at least as high as the top of the wash tub, about 38 inches.
  2. The drain hose must sit loosely in the house drain. Do not seal the air gap around the drain hose or a siphon will occur.
  3. Check the drain control lever
  4. Test the drain control coils
  5. Check the cam bar
pls rate my suggestion..
Jul 19, 2009 | Maytag LSE7806A Top Load Stacked...
Washing machine does not drain during rinse cycle?
Turn timer to rinse cycle. let fill up and agitate. when it stops agitating it should pause then start to pump water out. After about 2 minutes it should pause for 3-5 seconds then start again and spin. If it starts the first time and never stops it will just continue to pump but no spin. The 3-5 second pause allows the transmission to shift to spin. If it does not do this the problem is your timer. You may need to do this a few times to verify the problem.
If that is not the problem it is likely that you need a new clutch. You will need a technician to install a new clutch for you
May 17, 2009 | Whirlpool LSQ9600L Top Load Washer
Drum spinning during wash cycle
if when in the wash cycle the tub spins then the brake in the cluch assembly is worn and to be replaced. this holds the tub from moving when in the wash cycle. thanks tallpaul
Apr 14, 2008 | GE WBSR3140DW Top Load Washer
Frigidaire ATF6000ES Front Load Washer Logo
74 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
