Question about Akai LCT2701TD Television
AKAI 27" LCD Power Supply - Replacing capacitors and diodes
Hi Bill,
This is in reference to the thread about the AKAI power supply:
http://www.fixya.com/support/t278524-lcd_television
First of all, thank you for the tips and hints! Second, I was wondering what you thought about replacing the bad capacitors with 35v 1000microF capacitors? Is that increasing the voltage too much overboard from the 16v originals?
Also, do you have any hints on getting the z3 zener diode out? It looks like it's under what looks like a heatsink - do I need to desolder the whole heatsink first?
Finally, is there anything else you can think of that can be causing the TV to fail to turn on. Mine just has the red light blinking, and I'm hoping that it will work after I replace the capacitors and diode, but in case it doesn't, I was wondering if you have any other words of wisdom. :-D
Thanks again!
Kris
  • mrkrypto13 Jan 14, 2009
    Bill,
    Thanks for the response. I did replace the three capacitors 18, 19, and 20 and even the zener diode z3, and the TV still doesn't power up - the red light keeps blinking as before. No other capacitors are bulging out.
    I'm not sure what to do next - I already invested the time in trying to fix it myself, and I would hate to give up now, but my lack of success has given me more doubt whether the TV will ever work again. I would hate to spend $70-$100 on a replacement power supply and have it not work. Is there anything else I could do to find the root of the problem? I have a multimeter, and I tried testing some other capacitors and resistors, but have been getting inconsistent readings.
    If you have any other possible hints, please send them my way. Thanks.
    Kris
  • 934 Answers
Kris,
You can always replace a lower voltage cap with a higher voltage just don't change the rating... In fact you could replace the 16v cap with a 400v cap if it would physically fit.
As far as replacing a zener under the heat sink, yes you'll probably have to remove the heat sink itself if it's blocking. And as for any words of wisdom - if your repair is unsuccessful try replacing the module. Shop Jimmy usually has them used if you don't want to spend full bore and order a new one.
Good Luck!
Bill
Posted on Jan 07, 2009
Power supply not switching
replace the regulators,check for change value resistors at the power supply section or resistors near the regulator.check for shorted diode and leak capacitors..also check the horizontal output v transistor..
Jul 16, 2010 | Akai CF2791 27" TV
Yet another Akai power supply
Any luck getting this fixed?Please let me know.Thank You very much!
Tyler
Jun 21, 2010 | Akai LCT2715 27 in. LCD Television
AKAI LCT2715 will not turn on gives blinking
This series of TVs has a famous issue with the power board (part number MLT166A or similar). Several capacitors and zener diodes burn out causing some resistors to burn as well. If you are capable of doing component level repairs check capacitors on the board and zeners Z2, Z3, Z4, Z5 and resistors around them. If you prefer to spend hundred bucks and simply buy the working power board for it - ebay is your answer.
Sep 06, 2009 | Akai LCT2715 27 in. LCD Television
Will not power on, blinking red "power on" light
The power supply might have a shorted/defective diode(s), blown resistors, capacitors if the light is blinking on the front of the LCD.
I repair these power supplies, write to jah2mil@hotmail.com if you need further assistance.
Jun 24, 2009 | Akai LCT2701TD Television
TV screen won't come up
The power supply board or inverter. The power supply board is the first step. Look for any capacitors that are puffed up. Replacing them should take care of the PS. Check to see if you have 24 volts going to the inverter. If you do PS is OK and the inverter is most likely bad...good luck
May 08, 2009 | Akai LCT2715 27 in. LCD Television
Lcd akai 2715 blinking red light
The solution at this point would be to get the power supply repair since new boards are not longer being manufactured. In about 95% of the time if the LCD doesn't power up or turns OFF by itself or need to be unplug for some time to make work again; those are the symptoms of a dying or defective power supply.
I service these power supplies, for more info write to jah2mil@hotmail.com
Nov 19, 2008 | Akai LCT2715 27 in. LCD Television
AKAI MLT168A Power Supply
If I give you the values of Z3, Z4 and Z5, would you return the favor by telling me what are the values for R104, R106, R107 and C17?
I have posted this request 5 times for 2 months and no body gave me an answer. Would you be willing to work with me? E-mail me s69joe@hotmail.com and use MLT168A-fixya as subject
Thanks
Sep 27, 2008 | Akai LCT2715 27 in. LCD Television
Akai tv wont come back on
Nothing......bad capacitors in power supply need replacing.....T.
Jul 16, 2008 | Akai LCT2716 27 in. LCD Television
Akai lct2721ad flashing red light
I would bet on the power supply....these (and other Akai LCD) are notorious for filter capacitors. Look for electrolytic capacitors with a dome-like bulge on the top of them. They are usually located at the top of the power supply board where the power output lines run out.
Hpe this helps you out....
Sep 23, 2007 | Akai LCT2721AD 27 in. LCD Television
Televison & Video Logo
794 people viewed this question
Top Akai Televison & Video Experts
Jaime Hernandez
Are you an Akai Televison and Video Expert? Answer questions, earn points and help others
