Question about Water Heaters
Rinnai R94-LSi keeps turning off and beeps and blinks 12
I cant find owners manual only 6 months old
  • 700 Answers
Here is the link for the service codes for this unit. they will help you solve the problem. http://www.rinnaisolutions.com/troubleshooting/ErrorCode.html Good Luck
Posted on Jan 07, 2009
My Rinnai tankless water heater keeps tripping the breaker then when turned back on, it begins to beep and displays a code 12. What is causing this? It is new and this is the first time any code came.
Go to Rinnai and get a manual with the error codes... for example a shorted element will trip breaker... wiring problems can cause breaker to trip... anything that causes heat on wire to exceed amp rating of breaker will cause it to trip...
http://waterheatertimer.org/Water-heater-is-tripping-breaker.html
Sep 12, 2017 | Rinnai Water Heaters
Rennai
TAKE OUT THE ELECTRODES AND EMERY CLOTH THEM TO A SHINE. THEY GET A BUILD UP ON THEM NOT LETTING THE BURNERS RUN AT THEIR FULL CAPACIATY.
Sep 09, 2014 | Water Heaters
Rinnai RC98i Error 12 - Flame Failure
IF THIS UNIT HAS SPARK IGNITION THE IGNITORS ARE PROBABLY OUT OF ADJUSTMENT WHICH IS LIKE HAVING TO WIDE OF A GAP ON A SPARK PLUG . IF YOU MAKE GAP OF IGNITOR ELECTRODES APPROXIMATELY 1/8TH OF AN INCH APART IT SHOULD LIGHT AS LONG AS YOU ARE GETTING VOLTAGE FROM IGNITION COIL. CALL A SERVICE TECH
Dec 22, 2013 | Rinnai RC98i Tankless Water Heater 9.8 GPM...
I have a Rinnai tankless gas water heater and this things beeping and flashing 12 everytime we turn on the hot water the water will get hot but you have to wait for it to stop beeping
Error 12 is failed ignition - this can be caused by many things, but normally a low gas pressure, or no gas pressure upon ignition.
Try turning the hot tap on very slowly till till the control shows burner is lit. Then turn it on faster. If it stays going with no error, you might have a faulty regulator, not opening fast enough to meet demand. Especially common with lpg models,a lot rarer on natural gas.
Oct 27, 2009 | Rinnai Water Heaters
LC is the error code that you get when you have limescale buildup in the heat exchanger. You need to flush your heat exchanger. If you have the manual for your water heater, use it. The manual to mine is attached. The procedure for flushing it is covered on page 12. I suggest that you have a certified Rinnai plumber perform this task as it requires a ciruclating pump and some hoses that you need to connect to your water heater. If you don't perform this task, it is possible that you will need to replace your heat exchanger and this is not something covered by Rinnai's warranty.
Sep 21, 2009 | Rinnai Webstone The isolator EXP tankless...
This things beeping and flashing 12 everytime we
check the error codes on it by pressing the on off button for 2 seconds then while holding the on/off button press the up button this should display the last 9 error codes let me know what they are
Jul 28, 2009 | Rinnai Water Heaters
Code LC, I cleaned the filter, won't stop beeping
you need to flush out the rinnai. to do this you will need 4 gallons of white viniger & a circulating pump. #1 disconnect the power. #2 close both incoming & outgoing water valves under the unit. #3 conect a drain hose to the out going flush valve ( flush valves are under the unit & have brass caps) #4 connect pump outlet hose to ingoing flush valve. #5 put pump incoming hose & drain hose from outgoing flush valve in a 5 gallon bucket. #6 pour 4 gallons of vinager into the bucket. #7 open both flush valves. #8 turn on the circulating pump & let viniger pump in the incoming flush valve through the rinnai & out the outgoing flush valve back into the bucket for 45 min. #9 disconct pump from incoming side & close incoming flush valve.( don,t close outgoing vaves at this time) #10 put out going hose in empty bucket. #11 open incoming water to flush viniger out of unit. # 12 disconct outgoing hose , close outgoing flush valve & open outgoing water valve. #13 clean filter & turn on power.
Jul 08, 2009 | Rinnai Water Heaters
I am looking for a solenoid valve and sub-PC board for Rinnai 94 LSi tankless heater
There is a toll free number on the cover at the water heater.Call them and they will send you what you need.Or tell you where you can buy it.
Mar 23, 2009 | Rinnai Webstone The isolator EXP tankless...
My Rinnai R94 LSi stops sending hot water intermittently, resumes after a few minutes, no error message. Could it be water savers are reducing flow below the minimum necessary for the demand sensor? If so,...
II would think that the unit is going out on hil imit because there is not enough psi on the water coming in.Is this unit on well water or city?If it on well water you have run some cleaner in it every six months.L on the side of the heat or inside and there a toll free number to call talk to a tech.
Mar 07, 2009 | Water Heaters
Hooking up Tandem Rinnai R94 LSi
you will find a master controler at a electrical lighting and hardware store you have to be specific with the model and voltage/amprage rating. they will give you a schematic with the controler. .............please rate this ........thanks
Aug 30, 2008 | Water Heaters
Water Heaters Logo
680 people viewed this question
Top Water Heaters Experts
Donni Steen
Gil Shultz
Are you a Water Heater Expert? Answer questions, earn points and help others
