I have no power to window regulator, tried connecting motor to battery works fine, but I can't control window and lock through the control switch. I although could still control the passenger side window and lock. is it due to bad ground wiring or is it the power control box located in the drivers door. I tried changing the power control box but still won't work any easy fix....
Most likely you have a short in wiring harness, best thing to do is remove drivers side kick panel that cover next to your left foot while driving you should see a group of 15 to 20 wires wraped together that goes to the drivers door. once you find this grab a test light attach to a good ground remove some of the tape so you can see the wires check to see which ones have power by poking tester into the wires, write down the color code for wires that light up, then pull the power control box and check those same color coded wire when you find the bad one you can run a new wire from where you first checked it to just before the control box you can either solder or crimps then tape it up then the rest of the harness that you opened up as well. Good Luck
SOURCE: 2004 Jeep Grand Cherokee driver side power windows do not work
I had the same problem with now power to windows, mirrors and seat. The common soulution is the orange and or black wire in the boot have broken between the door and post.
SOURCE: Power window on 2001 chevy silvrado
Sounds like your gears are striped out inside the motor. I had the same problem on a car of mine. I just went to a parts store and bought the gear and took the motor apart and fixed it myself. It cost 18 dollars with tax.
Good Luck.
SOURCE: Camry 1996 automatic power lock doen't work, but windows work.
if you can here relays when unlocking/locking check for power at door lock actuators inside doors, if you have power on lock/unlock and good earth from connector actuators are faulty.
if no power on test light when operating check output from central door lock module while operating, none coming out of module then it might need replacing.
check 30Amp power fuse for main relay under bonnet (which goes to pin 8 white/blue on module)and 10Amp gauge fuse in cab(pin 1 blue/red on module),pin 15 is also power when relay is on(red/blue) with test light, and module/ actuators.
check outputs from module pin 3 & 4
blue/red
blue/black
that go to door locks
SOURCE: 2001 dakota passenger side power window not
it's probably a broken wire in the door jam on either the drivers sid or the passengers side.check the wires where the fold wher the door opens and closes
SOURCE: 2005 Chrysler Town & Country. Passenger side window problem.
HAVEK 1005 sounds right on track.... but also try this, usually works well for non functional power windows, specially Caravans.
NO COST PROCEDURE TO FIX IT:
1. Sit in vehicle, on seat next to problematic window
2. Ignition key is on
3. Door in question is opened (in case you closed it)
4. While door is open, press and hold power window button in desired window travel, keep button pressed !!
5. SLAM hard the door closed with one hand while other hand holds button as per #4.
6. Watch window operate as it should.
7. Repeat 3-6 if necessary, but usually the first try works!
NOW, for the naysayers that says you must replace power window motors etc, at $$$ cost because the above fix does not work, or is not long lasting fix, or less than a "professional fix".... Well then, when the window fails to operate again, apply same fix again at that time.
I have fixed my van this way numerous times (usually once a year), and to all local friends I recommend this fix too, likewise do the same and are happy with the solution.
For all types of power window problem and power windows not working,i suggest you to go through the help links given below.Click the link to go through its procedure to troubleshoot the problem :------
driver side power window problem?
http://technoanswers.blogspot.com/2011/06/driver-side-window-problem-on-mercury.html
Driver side power window
wont go up?
http://howtobyme.blogspot.com/2011/10/driver-side-power-window-wont-go-up-on.html
Power window problem
http://repairhelpcenter.blogspot.com/2012/01/pontiac-grand-am-power-window-not.html
rear door or window will
not open ?
http://technoanswers.blogspot.com/2011/06/rear-door-or-window-will-not-open-on.html
How to remove door panel, door window motor and regulator ?
http://technoanswers.blogspot.com/2011/05/how-to-remove-door-panel-door-window.html
Power windows not working after car wash?
http://howtobyme.blogspot.com/2011/11/power-windows-not-working-after-car.html
---------power locks, power window and power mirror not working?
http://howtobyme.blogspot.com/2011/09/power-locks-power-window-and-power.html
All power windows not working?
http://howtobyme.blogspot.com/2011/09/all-power-windows-not-working-on-2003.html
How to remove window motor and regulator on Volkswagen Car?
http://howtobyme.blogspot.com/2011/09/how-to-remove-window-motor-and.html
-------------Complete Diagnosis & Testing Power Windows?
http://repairhelpcenter.blogspot.in/2012/02/diagnosis-testing-power-windows.html
How to replace power window
motor in car?
http://schematicsdiagram.blogspot.com/2011/06/how-to-replace-power-window-motor-in.html
HOW TO REPLACE A POWER WINDOW SWITCH
http://schematicsdiagram.blogspot.com/2011/07/how-to-replace-power-window-switch.html
How to Replace a Window Motor
http://schematicsdiagram.blogspot.com/2011/07/how-to-replace-window-motor.html
HOW TO REPLACE A WINDOW REGULATOR WITH MOTOR
http://schematicsdiagram.blogspot.com/2011/08/how-to-replace-window-regulator-with.html
HOW TO REPLACE WINDOW RUN CHANNEL SEALS
http://schematicsdiagram.blogspot.com/2011/07/how-to-replace-window-run-channel-seals.html
http://schematicsdiagram.blogspot.com/2011/07/how-to-replace-window-regulator.html
-----------This will help.Thanks.
Driver side power window wont go up?
rear door or window will not open ?
How to remove window motor and regulator on Car?
How to replace power window motor in car?
Number 21 is for the door lock fuse and relay, its a 10 amp fuse.
Number 7 is for the body control module, its a 10 amp fuse.
The fuse panel is under back seat.If all fuses checked out ok,then its faulty drivers door module called as DDM.
Door ajar light stays on?
http://technoanswers.blogspot.com/2012/01/door-ajar-light-stays-on.html
