Question about Panasonic PT-50LC14 50" Rear Projection HDTV-Ready Television
No picture or sound
Have a panasonic pt60dl54j,had a new lamp installed several months ago. I have no picture or sound now, green led is on and flashing. Does anyone knows what trouble is.
  • 37 Answers
First unplug the unit let it cool down ....plug it back in then reset the counter....press (-) volume on the tv and while holding down press the pip/split button on the remote and that should reset the counter...
Posted on Mar 12, 2009
Tv turned off by itself, red light came on. when i turned it back on if had a flashing green light the turned solid green, there was sound but no picture, it turned off again within 2 minutes of turning it...
Tv probally needed a new tv projection lamp.This tv has not been change it projection lamp like 1 1/2 or 2 years already?Tv been on and used it like 4 or 5 hours everyday?Yes,than the tv flashing or solid on green LED light is on have a word "LAMP" written on it tv bazel frame?Yes,tv 100% require a new tv projection lamp replacement.
Aug 31, 2011 | Mitsubishi WD-73737 73 in. HD-Ready TV
I have a Panasonic PT-52LCX66 television that I bought just over 4 years ago. I have replaced the bulb for the second time just 3 months ago and now the set will just shut off after about 3 minutes of...
Tv making and have clicking sounds as tv shutdown as lights flashes?Yes.The board that call the Ballast board might be dying and dead soon.This Ballast board job responsible only are to ingnite the tv projection lamp only.
Jun 30, 2011 | Panasonic PT-52LCX66 Projection Television
When you turn of the TV the POWER indicator flashes green for several minutes. The TV never comes on. After the several minutes of the POWER indicator flashing green, it stops, I hear a click and the...
A continuous flashing red light with the word LAMP on it would definitely mean you're going to need to spend a few bucks on a new lamp....or for a few more, upgrade to a TV from this century that doesn't require lamp changes :)
May 11, 2011 | Panasonic PT-52LCX66 Projection Television
Have green spot on left third of picture.
is it an LCD rear projection? Then it is the light engine. Confirm it with a tech visit and then buy another set. The light engine costs as much as a new set.
May 05, 2010 | Panasonic PT-52LCX65 44" HDTV
When turned on green light flashes and no picture
Check the Lamp if no picture, audio may be present. Screen is completely dark. Lamp LED flashes 2X every 5 seconds, Power LED flashes GREEN for 140 seconds then flashes RED.
Check the ballast if no picture, audio may be present. Screen is completely dark. Lamp LED flashes 3X every 5 seconds, Power LED flashes GREEN for 140 seconds then flashes RED.
Dec 24, 2009 | Panasonic PT-50LC13 50" Rear Projection...
Panasonic PT-43LC14
The TV shutdown error code can help you with this problem. If the power led flashes green for 2 Min's then red. The Lamp led should flash red 1-2-3 or 4 time every 5 Min's. These are error codes that may point you in the right direction to you problem.
May 24, 2009 | Panasonic PT-43LC14 Television
No picture
ballast is not striking the lamp and needs replacing
Jan 10, 2009 | Sharp XR-10X Multimedia Projector
Turns on and off green LED flashes until TV turns back on.
this is a symptom of a bad lamp. for some reason it won't spit out a lamp error. shaking up the lamp will sometimes fix temporarily but you will find replacing to be the answer. if your tv has a fan error, you will get 4 red blinks.
Dec 09, 2008 | Sony Grand WEGA KDF-60XS955 60" Rear...
Panasonic PT-50LC14 50" Rear Projection HDTV-Ready Television Logo
124 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
