Question about Nikon COOLPIX L18 Digital Camera
This card can not be used...screen display
What to do when my screen camera display it, I already check the card and is OK in my PC.
What should I do?
  • 45 Answers
Hi albam',
first of all backup your data form the card. then format it in ur pc using fat file system. then try to use it in ur camera.
good luck!
Posted on Jan 07, 2009
When I turn the camera on the screen is black. It shows the menu display ok and it will display pictures already taken but it is not possible to take pictures as the screen is just black..
Two things there, first... could be a problem with the viewer screen, or, second choice could be a problem with the CCD sensor or go to bad; in both cases this isn't a job that you could solve yourself; this wrong include distorted images or abnormal colors, scratchy purple lines, blank or black pictures, and/or black videos with good sound being recorded on the camera's flash card.
I suggest check THIS LINK for additional details in this previous solutions for an Defective CCD (Charge Coupled Device) and next contact your Canon service.
I strongly suggest (taking into consideration the age of your camera) to evaluate the cost of repair versus the cost of a new camera with similar features, before making a final desicion.
Hope this helps; check it and keep us updated..
Aug 15, 2011 | Canon PowerShot SX130 IS Digital Camera
It displays a card error message when i insert an sd card.help please.
You have to check out that if your camera support your SD card(type, capacity size ) or if there is real something wrong with the card. Using a card reader insert to PC and see if the card can be read, if it's OK, formatting it by PC then insert it back to camera and see if the problem can be solved. Else, If the card can't be read by PC you only have to change it.
Apr 27, 2011 | Cameras
Screen displays "card locked" and
Look at your memory card. SD cards have a slide switch along one edge. The position farthest from the contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card. If the switch is already in the proper position, slide it fully the other way and then back again.
Mar 29, 2011 | Samsung S860 Digital Camera
Will not recognize the PC. USB cable OK. Memory
Use a card reader to download your pics...works every time.
Mar 28, 2010 | Panasonic Lumix DMC-FZ28 Digital Camera
When switched on, display reads "In synchronized monitor mode"
Cycled through display options, still couldn't get viewfinder image. Checked images already on card, and they showed OK, so screen operating properly. Went back to viewfinder mode, got lots of horizontal lines across screen. Realised I could do no more, so took camera to shop it was bought from, who checked it and said it had an electronic problem that needed professional repair facility, so camera has gone for an estimate of repair cost.
May 07, 2009 | Ricoh Caplio R4 Digital Camera
Memory card error
When purchasing memory cards for cameras, you must specify HI SPEED. Low speed cards error out all the time.
Is this the original that came with the camera?
Jul 21, 2008 | Canon PowerShot SD600 Digital Camera
FAULTY DISPLAY
check ur ram. also reseat the video card.
Dec 05, 2007 | Computers & Internet
BAD VIDEO CARD
The only thing u can do is to change ur graphic card
Nov 28, 2007 | Computers & Internet
Help
Yes and in several methods as below listed. Since your posting refers to a generic problem for all digital cameras and not only an Olympus FE-230, some of the settings may have a different nomenclature or button name.
1. When you download pictures to you PC, rather than copy, select move; or
2. If you want to erase one picture at a time from the camera - press on the power button, then menu button, once menu is displayed, arrow down/up, you will be asked to erase the picture displayed, select yes/no by up/down, then press OK (menu button); or
3. If you want to erase all contents of the memory card of the camera - press on the power button, then menu button, once menu is displayed, arrow right, down to select card, right to select card setup, right to enter card setup, arrow down to select format or erase all, OK. Erase all just erases the files, format erases all and re-initialize the memory card; or
4. Remove memory card from camera and insert into a memory card reader attached to USB of your PC. The memory from the camera will be treated as a removable device and you can view, move, copy, delete/erase, format. This option seems to be most effective in viewing all contents under Windows Explorer with the view setting set to Thumbnail.
5. Connect the camera via the supplied cable to any USB port of your PC. The camera will be treated as a removable device and you can view, move, copy, delete/erase, format. This option seems to be most effective in viewing all contents under Windows Explorer with the view setting set to Thumbnail.
Specifically for an Olympus FE-230:
1. Press the < or > buttons to display the picture you want to erase;
2. Press the trash can button (bottom right);
3. Press the UP button to select [YES], press OK;
or
To erase all:
1. Press the MENU button to display the top menu in playback mode;
2. Select [ERASE], [ALL ERASE], and press OK;
3. Select [YES], and press OK
Hope this be of help/idea. Pls post back should you need additional information.
Good luck and kind regards.
Nov 08, 2007 | Cameras
Nikon COOLPIX L18 Digital Camera Logo
57 people viewed this question
Top Nikon Cameras Experts
Steve
Jeff Marcus
Are you a Nikon Camera Expert? Answer questions, earn points and help others
