Question about Bosch WFE 2021 Front Load All-in-One Washer / Dryer
BOSCH washing Machine WFE 2021
After a few mins on a 40 degree wash (fills with water) it just stops, to continue you have to press the start button again, the heater is working fine, the M/C then seems to go all the way through the wash !! Any ideas please ?? Thanks
  • Anonymous Mar 14, 2014
    program not working after water his filled in bosch washing machine
  • Anonymous Mar 16, 2014
    will not light up when i press button to continue wash
Just curious about the water temp...you said "40 degree wash"...isn't that extremely cold water? Usually tap water is around 55 at the lowest.
anyway, here's a hunch. the washing action (with shaking of machine) is unlocking the start switch relay...but this method of electrical starting is too old school for this washer...but still worth a try? locate the start switch circuit and "jumper" out the start switch.
Posted on Jul 29, 2008
Sorry nothing to do with conditioner rinse, the M/C stops after a couple of mins into the wash cycle, when pressing the start button again it often goes through the program heating, rinsing & spinning.
Posted on May 30, 2007
  • 883 Answers
Perhaps it is waiting for user to add fabric softener? how it got in this mode?
Posted on May 29, 2007
  • Marty marty May 31, 2007
    just curious about the water temp...you said "40 degree wash"...isn't that extremely cold water? Usually tap water is around 55 at the lowest.
Bosch WF2001 washes only 30 degrees programmes
We had this problem and it turned out in our case that the hot water inlet filter was blocked. The pump wasn't receiving any hot water into the machine so wouldn't start on anything except a cold (30degree) wash.
We turned off the the hot water tap on the plumbing at the back, disconnected the inlet pipe from the machine, then put the end of the pipe in a bucket and turned the water back on, and saw loads of sediment spurted out.
We ran it until we'd filled the bucket, then turned the tap off, emptied the bucket down the drain, then disconnected the hose from the plumbing and cleaned the hose separately (there's a gauze at the plumbing end of the hose so make sure that's clean).
Then get some pliers and where the hose attatches to the machine there's a filter that you can pull out. Clean this out. In our case this was completely blocked with limescale sediment etc.
Reconnect everything, check it's all tightly fastened etc. then turn the tap on the plumbing back on - turn it on to a hot wash, press start ...and in our case it all worked a dream again.
All this info is in the manual if you've got one, but I thought I'd write it out in case you've got this problem and don't have the manual.
Ahhhhh... cleeean washing again! Hope this works for you. Happy go laundry!
Mar 04, 2010 | Bosch Washing Machines
Hello! How can I get the instructions manual for
You're in luck -
http://www.bosch-home.co.uk/
click on "download product manuals"
click on "click here to download product manuals" - this will open a new tab or window.
Enter WFE2021EE/01 and click on Go.
results are in spanish, but I expect you'll be ok with that.
Aug 03, 2009 | Bosch WFE 2021 Front Load All-in-One...
Bosch WFE 2021
I suggest that you check the brushes in the motor for wear.
Remove rear panel, remove drive belt, undo bolts securing motor, unplug motor lead and earth wire.
Lever motor back, keeping hold of it, and remove.
Check the brushes, they are at the opp end to the motor pulley, if there is less than 8mm left, then replace brushes.
I would also check the pump filter, and clean if req'd.
Please rate my fixya solution.
Thanks.
Feb 08, 2009 | Bosch WFE 2021 Front Load All-in-One...
Flickering display panel Boschwfe 2021
It may be the door interlock that is faulty. This is the cheaper solution however it maybe the the electonic board. In any case it needs the attention of a bosch Technician. Cross your fingers its the door interlock.
0417362396 Melbourne metro Area
Regards Sam
Jan 05, 2009 | Bosch WFE 2021 Front Load All-in-One...
Bosch Washing Machine WFE 2021
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} The 03 error code is the drain. Disconnect the drain hoses and check for blockages. If no blockage "time" the drain interval. If it's more than 6 minutes it's the pump. Also make sure you're using the correct type of soap so the ball check valve on the bottom of the outer drum isn't getting fouled with excessive suds. Also disconnect the drain hose from your house plumbing and let it free flow on it's own. This will tell you if the blockage is in your plumbing and not in the machine.
Jul 29, 2008 | Bosch WFE 2021 Front Load All-in-One...
Bosch WFE 2021 machine does not complete wash...
Check your exit hose spigot, it may be clogged. This is if your filter is all clean. There should be air for passage in the standpipe behind. Your hose should not fit airtight into the standpipe and neither too deep into it. Snaking out your standpipe would be good too.
Jan 04, 2008 | Bosch WFE 2021 Front Load All-in-One...
Bosch wfk2201 washing machine
Contact Bosch through their web site. They offer solutions to some problems if yours is no listed send them an email.
Jan 01, 2008 | Bosch WFE 2021 Front Load All-in-One...
Fault code 01
this is actually a fault code error code 1 not one minute check your manual as codes different on some machines from memory i think 1 is a filling fault this machine uses fuzzy logic if water fill takes longer than 4 mins (low pressure) machine stops can be restarted by pressing start button.
see if machine will complete just a rinse cycle.
good luck
Oct 04, 2007 | Bosch WFE 2021 Front Load All-in-One...
Bosch WFE 2021 Front Load All-in-One Washer / Dryer Logo
444 people viewed this question
Top Bosch Washing Machines Experts
Marvin
Marvin
Craig Butler
Craig Butler
Carmen Mikulic
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
