Question about Comfort-Aire RADS-151 Air Conditioner
Comfort aire A/C Rads 101-A EE light
After plugging in the A/C unit, I get an EE on the display and the unit will not run. I do not have the manual.
  • 105 Answers
Possible faulty control electronics. Call a repairman.
Posted on Jul 15, 2007
Trying to find a compressor relay for my unit.
typically you replace the board. i doubt you will find a another relay to solder in unless you can find a old one to rob parts off.
Aug 18, 2015 | Comfort-Aire RADS-253 25,000 BTU Window...
Panasonic CWXC203EU the unit is flashing error code EE and only when you unplug it shuts off the control do not work blows s a littlle cold air but after a shor time it shuts off
Hi.
EE means energy efficiency. hen EE is displayed there can be a defective thermistor or insufficient ventilation.
The following works on some A/C system: "When EE is displayed, press "energy save" and "zone control" simultaneously for about 5 secs"
Try also testing the system in auto mode, check ventilation and if possible test thermistor by reading impedance with a multimeter.
If when EE is displayed the unit also becomes non-responsive and does not turn off, then the problem may also be a defective controller board. Other parts, included the ones mentioned before, must be tested before replacing the control module.
Regards.
Ginko
Aug 11, 2011 | Heating & Cooling
I get a EE code on the display. What is it?
Hello
EE is a high pressure error code. The unit may be to small for the room deppending on what temp it is outside.If its over 95.f The a/c is probably overworked.
One way to solve this would be to cool down the coils outside.Spray water lightly on the outside of the unit too cool it down which will bring the pressure down also.
Jul 20, 2011 | Maytag M6W12W7A Air Conditioner
My air conditioner just shut down like it has no power but the outlet has power. Is there a reset button or something? It's a Comfort Aire Model RAD-151-B
Many window units now have a GFCI plug. If the power cord, where it plugs into the wall, is huge, it should have a reset button on the face or side of the plug.
If not, then a power fuse on the control panel has blown, or the control panel has died.
Aug 14, 2010 | Comfort-Aire RADS-151 Air Conditioner
What is the EE message on the DuoTherm Comfort Control Center?
It means that an error has occurred. If you have a 4 button comfort control. Follow these steps to reset:
To initiate a RESET, do the following in the order
listed:
1) Turn control on to ensure annunciator data and light are present. If data and light are present, continue to next step. Depress MODE switch to activate annunciator light.
Simultaneously depress the bottom two buttons (temperature UP and DOWN) and hold.
While holding these buttons down, depress the MODE button once and release.
Release the two buttons previously held down. Depress the MODE button once again.
At this time the light should extinguish, and the mode should register “OFF”. If not, repeat these steps.
Retest system ensuring that all functions are present
and operational.
If you have the five button comfort control. Turn the unit off and hold down the mode and zone buttons together. While holding them down, turn the thermostat back on. Hold the buttons down until an FF appears on the screen. Release the buttons and the display should return to normal. If not, try it again.
Jun 30, 2009 | Dometic Rooftop RV Air Conditioner
Wont turn on. EE on display
It's probably the control board inside the control panel. I had the same problem and it moisture shorted out the board. You can order a new one from Sears Parts for about $45
Jun 09, 2008 | Maytag M6Y12F2A Air Conditioner
RV Dometic AC Comfort Control Double EE Problem
I have a dometic duo-therm. The unit works great and fan blows strong and both high and low work., but air is coming out of the ceiling unit rather than the duct work. The bedroom unit works OK, but the air is strong out of one duct, and not much comes out of the others. The front unit only has air coming out on the A/C unit and none out of the ducts.
Mar 24, 2008 | Dometic Rooftop RV Air Conditioner
EE in the display window
Hi, I have been trying to get in touch with a service rep to find out but unable to get one. They wanted proof that I had purchased a unit. Its possible that your receptacle is not polarized right. By that I mean the two wires may need switched on the receptacle or maybe it doesn't have a good ground. You may want to try temporarily using an extension cord and try another plug. Most things will run good on receptacles wired wrong but with a computerized AC it may be seeing a fault. If you still need help I think the best way to find out would be for you too contact the store that you bought the unit from and make it their responsibility to find out what the EE stands for. If they cant, get the unit replaced and try again. If you do get hold of a service tech # from Maytag, please send it to me at kstfas@yahoo.com Hope this helps. kstfas
Aug 27, 2007 | Maytag M7Y10F2A Air Conditioner
Comfort-Aire RADS-151 Air Conditioner Logo
443 people viewed this question
Top Comfort-Aire Heating & Cooling Experts
Marvin
Marvin
Cesar Quant
Cesar Quant
ray gallant
Are you a Comfort-Aire Heating and Cooling Expert? Answer questions, earn points and help others
