Question about Refrigerators
Trying to determine which is high side and which is low side
I need to refill my compressor with r12 but want to make sure I add to low pressure side. How can I tell?
  • 318 Answers
R-12 hasnt been used since 1994 and if you are sure, by looking on the model number tag, that yours does have r-12, then you need to find out where it is leaking out from. freon doesnt get weak, it will just leak from usually a corroded copper line.
the small line on your compressor is the "high" side and the larger line is the "low" side.
also r-12 is hard to find now but if you can get some then you might be able to buy some time until the freon leaks out again. i wouldnt plan on this unit working for much longer, but you might get by for awhile.
check the "heat exchanger" for signs of oil or corrosion. thats the most common place to find a leak. the heat exchanger looks like it has a small copper tube soldered right on to the larger tube, and is usually covered with a foam insulation sleeve.
Posted on Jan 07, 2009
    Sergeant:
  • 229 Answers
Usually the cap where you add will only fit the low pressure coupling also the caps covering the add spigots are labeled L and H - Low and High. If there isn't a clear way to go, Google the make and model # and add the search work diagrams and you should find a compressor diagram to help.
What kind of ac coolant does it have 134a or r 12 and where is the low pressure port for the ac located
Depends on the year. Cars in the early 90's used R12. Anything later uses R134a. The size of the charge ports will define the R134a port. An adapter is needed to fit on the charging hose. R12 requires no such adapter. Ther charging label under the hood will tell you what refrigerant is needed too. Since you failed to give enough information on what make and model car you have, a general answer for the location of the low pressure port will be given. On the compressor, the larger diameter hose connection is the low side. Connect there, or look for the drier/accumulator (Large diameter silver container near the firewall). Connect there. You will need to access the AC information label under the hood to determine how much freon to add to the system.
Mar 12, 2016 | AC Cars & Trucks
What is the gas pressure on both compressors on subzero 321
The pressure of the refrigerant in the systems vary depending on the temperature of the refrigerant gas and the type of gas used. So this is a question that can't be answered without a lot of additional information.
Mar 02, 2015 | Refrigerators
How to recharge recharge airconditioner
Hi, determine if your car uses R134 or R12 refrigerant. You will notice screw type connectors on the both the High Pressure Side and Low Pressure Side lines in models using R12 refrigerant. R134 compatible models have quick connect valves on both sides. Models made before 1995 may use the old R12 refrigerant. If this is the case, you must have your Chrysler's air conditioning system retrofitted to use R134 refrigerant. Mixing R12 and R134 refrigerants is dangerous and may cause damage to your vehicle. Check your air conditioning system pressure using an automotive air conditioning pressure gauge. Keep in mind that in order to get an accurate reading, the air conditioner has be turned on the coldest setting with maximum blowing power. Remove the Low Pressure Side port valve cap and set it aside. The location of the port varies, but it is usually in front of the engine block. Attach the refill hose to the port on the Low Pressure Side of the air conditioning system. The Low Pressure Side port is smaller the High Pressure Side port. Because the ports are different sizes, the refill kit hose should fit only on the Low Pressure Side port. Additionally, the High Pressure Side port will usually have a red cap or be marked with an H or the word High Allow the air conditioner to **** the refrigerant out of the can by slowly turning the valve on the refill kit hose. Pay attention to the way you hold the can. Most kits will have you hold the can upright when you recharge the air conditioning system. It may take as long as 10 minutes to empty a single can. Turn the valve to the off position and remove the refill hose from the port. Recap the port before closing the hood. Let the air conditioner stay on for at least 30 minutes. This allows the refrigerant to move throughout the entire system.
Take care
Aug 03, 2010 | 2006 Chrysler Town & Country
Air is not very cold on a rv roof top ac what tools are needed in recharge
You should have the manual for this unit handy and as far as recharging tools go. You only need a can of R134a *(if the unit is R12 you need to buy upgrade adapters since R12 is no longer sold) Run the unit and put the R134a filler line on the low pressure side of the compressor *(from manual...dont guess as trying to charge the high pressure side is VERY dangerous). Get the charge just into the Green zone on your charger and that is it! Try not to fill too high in the green zone....I know it sounds funny...but AC's usually work better when they have the low end of their optimum fill. R134a doesnt work as well as R12 so be sure you buy the R134a with cooling enhancers. Your local Autozone can guide you to the right filler/product combination.
Good luck and be careful!
Jun 30, 2010 | Dometic Rooftop RV Air Conditioner
Ac problem
the refill bottle shouuld never be attached to the high pressure side (high side) .. the connections are different to prevent that .. if you did manage to hook that up, there would be great danger of the bottle exploding ... so you can only hook the bottle up to the low pressure side (large piple) ... the retrofit kit should have included adapters for both high and low pressure sides ... the correct adaptor should fit the R134a refill bottle hose ... it should also fit the low pressure port (you may have to remove the valve in the old port (read instructions for that) .. if the adapter does not fit then you might check with a dealer or air conditioner supply house for a special adapter ... R134a and R12 are completely incompatable so make sure you have washed out the system and replaced the dryer and sometimes the hoses ... you cant have any of the old lube left in the system .. its generally a good idea to replace all rubber parts for the changeover .. you will need to pull a vacuum for a couple of hours before refilling .. .
Jun 30, 2010 | 1990 Ford Bronco
Where do you recharge the air cant find theplace to hook up the refill refrigerant
U SHOULD NEVER HAVE TO RECHARGE, IF YOU DO U HAVE A LEAK AND THAT NEEDS TO BE REPAIRED 1ST BEFORE A RECHARGE, THE SERVICE RECHARGE PORT IS ON THE INSIDE OF THE OF THE PASSENGER FRONT FENDER, U MUST GET AT IT FROM UNDER THE CAR, IT IS ON THE ACCUMULATOR AND NOT VISIABLE, U MUST FELL IT, VERY HARD TO GET AT, GO TO LINK BELOW FOR PICTURE
http://www.aircondition.com/tech/questions/5/
Jul 10, 2009 | 2001 Ford Focus
Low-pressure port I need identification
Basic AC system consists of Compressor pump (on engine), Condenser (front grill with radiator) and Evaporator (Firewall). Pump has two ports output (high pressure) and return (low pressure). Follow lines from pump. High side is usually between pump and condenser. Follow lines and find second port this will be low side (refill) port. Paint or replace port caps (red high, blue low). Also, refrigerant in system determines port size (R12 or R34).
Jun 24, 2009 | 2001 Chevrolet Malibu
Is the A/C low side port at the firewall, passenger side?
the low side ac valve, should have a blue cap. and is the smaller of the 2 valves. that smaller one is what you would need to use to refill the system..if you are planning on refilling the ac, make sure the bottle you get to refill with is the right fluid... some earlier cars still run on r12, and some run on r134a. if you are going to fill it, have the car running and then check the pressure before you add any fluid cause you will mess the system up adding to much... hope this helps you..
Jun 11, 2009 | 1999 Pontiac Grand Am GT
1993 buick century
Heater Control Module
May 31, 2009 | 1993 Buick Century
Insufficient cooling in my mercedes 300e 1989. When i hook the manifold gauge and turn on the AC, the low side pressure shows ~70psi and high side 200 - 230psi(low side pressure stays constans and high...
1989 year would indicate the system uses the Old CFC R12 refrigerant. 70 PSI equals about 70°F . This is not enough pressure difference to give you any cooling. Sounds like your compressor has bad valves. Replace compressor.
May 01, 2008 | Heating & Cooling
Refrigerators Logo
674 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
