http://majorgeeks.com/ASUS_Update_Utility__d4435.html
ASUS Update Utility - an utility that allows you to save, manage and update the motherboard BIOS
The ASUS Update is an utility that allows you to save, manage and update the motherboard BIOS in Windows® environment.
The ASUS Update utility allows you to:
· Save the current BIOS file
· Download the latest BIOS file from the Internet
· Update the BIOS from an updated BIOS file
· Update the BIOS directly from the Internet, and
· View the BIOS version information.
You need an Asus motherboard in your system.
Rules for Safe BIOS update:
1. For safety reasons, always use the most updated BIOS utility!
2. Do not overclock the system/CPU during BIOS update!
3. Load "Setup Default" in BIOS menu before BIOS Update.
4. Make sure you have "Administator" privilege on your Windows system (WinNT4/2000/XP).
5. Close all application programs under Windows.
6. Disable any existing Anti-Virus applications in the system.
7. Reboot the PC after the BIOS update is complete.
8. Switch on the PC and load "Setup Default" in BIOS again.
Hope this helps
Updating the BIOS with the Intel® Express
BIOS Update Utility
With the Intel Express BIOS Update utility you can update the system BIOS while in
the Windows environment. The BIOS file is included in an automated update utility
that combines the functionality of the Intel® Flash Memory Update Utility and the ease
of use of Windows-based installation wizards.
To update the BIOS with the Intel Express BIOS Update utility:
1. Go to the Intel World Wide Web site:
http://support.intel.com/support/motherboards/desktop/
2. Navigate to the D946GZIS page, click "[view] Latest BIOS updates," and select the
Express BIOS Update utility file.
3. Download the file to your hard drive. (You can also save this file to a removable
USB device. This is useful if you are updating the BIOS for multiple identical
systems.)
4. Close all other applications. This step is required. Your system will be rebooted at
the last Express BIOS Update window.
5. Double-click the executable file from the location on your hard drive where it was
saved. This runs the update program.
6. Follow the instructions provided in the dialog boxes to complete the BIOS update.
I'm sorry, didn't wrie that, it would hard to help that way.
I was updating bios under vista with the latest flash for windows on the Fujitsu website and the program started, and really fast the completion line was finished and the pc was black, didn't do anything else.
Completely dead, I can't even boot to bios. No lights no nothing.
I took the motherboard battery and leave it there, ill try today to put it back and search for the CMOS pin, but its hard because I can't see much.
What do you think I can do?
looks like totaly dead due to wrong BIOS upgrade, you can make it alive if you get BIOS chip from same laptop, you can buy dead motherboard on eBay and resolder BIOS chip, or you can rewrite BIOS to your BIOS chip using programmer or if your chip is dead you can buy new clean BIOS chip and write firmware with programmer
