Question about GE WWSE5200B Top Load Washer
GE WWSE5200BWW Topload Problem
I have the above mentioned model, and of coarse I am 42 days out of warrenty. Washer seems to have the same noise in a few differant cycles of the wash. Best I can descibe it is if I put the washer on spin only, water drains completely, then when it attempts to spin (counter clockwise) It sounds like the motor is kicking in and out as it tries to spin. Huge draw on all the lights on that circuit also. The problem happens in several places during a whole wash cycle. It also seems to be a timed thing, because if I wait a few minutes, then it will go right to high speed spinning with no noise at all. Can anyone help? Chuck
  • 1 more comment
  • Anonymous Mar 06, 2008
    My washer was 4 years old when it started the same problem. When the motor attempted to engaged into a high speed it would humm and not spin. I ran the diagnostics (you will find the directions taped near the motor when you remove the front panel)( No special diagnostic tools needed). The diagnositic indictated the motor was bad and would not carry a load at high speed. I ordered a new motor and GE sent a motor with a capacitor within the wiring harness that attached to the exterior wall of the washing machine frame. They gave detailed instructions on how to adapt this new wiring arrangement to the original factory setup. The new motor solved the problem, but I believe GE realized the factory motor/capacitor set up was incompetent for the machine. They just choose not to stand behind it because problems usually do not occur until the unit was out of warranty. Poor quality, poor manufactures support, and business ethics on GE's part. New motor ($185-$220)
    The front panel removes easily. Take a 2 inch putty knife insert it between the seam at the top of the front panel and the top about 6 inches from the corner. You will find a clip there. Push the clip forward while pulling on the corner of the front panel. It will pop loose and come forward. Repeat this procedure on the other side and the whole panel will come forward and off. Easy access. You can change a motor in about 30 minutes or less and have the machine back running.
    Dave
  • Anonymous Apr 08, 2008
    i have the same problem with mine. should i dump it or fix it?
  • ffmc723 Dec 27, 2008
    I have the same problem with my P.O.S. I thought i could be the transmission but I guess the Motor sounds possible.
How do you run the diagnostics?  I could not find the instructions inside my washer.
Posted on Aug 21, 2008
  • 23 Answers
Sounds like the motor needs replaced pretty common on this unit..
Posted on Jun 02, 2007
Ge adora WHDVH626FWW makes clunking noises when spinning, bearings seem ok
Could be a broken Hub Spoke, My Kenmore broke at the spokesand bearing e.of drum,
Sears replaced all parts as the were still uder warrenty. Less than 10 years old, would have been over $1,000 cost otherwis.
Sep 30, 2012 | GE Wh12x10309 Heater for Adora Front Load...
I have a GE Top Load washer model # EWA 5600G. The washer idiot light indicates the washer is in the wash mode, however nothing is happening, tub is full of water, but no adigation....motor is not...
Hello, welcome to FixYa.
I understand based on your post you have a GE topload washer, model EWA5600G, correct ?
The most common problem which manifest in the manner you've described is the lid switch. I don't know what you've done aside from what you mentioned, "Tub spins freely, belt is on, motor is not running." but I'd suggest checking the switch.
The motor should only come on in the spin cycle if no water is present...if it is indeed full of water and ready to cycle then it will come on as well.
If you do not have motor action present at anytime no matter where the cycle is, I'd be suspicious of the lid switch. Have you tried by-passing the lid switch and testing it in spin ?
As you can see there are many possible scenario's that may prevent the motor from operating, a timer, a lid switch, a pressure switch and of course the motor itself. That's getting ahead of things though.
Let me know what results from by-passing the lid switch and perhaps that will get us moving forward again. Good luck.
Regards,
Macmarkus :)
Sep 08, 2011 | Washing Machines
I have a GE topload washer, I think the model # is WBSP1060T( there were three model # on the washer-VVSRV1040V & YVSR1040V were on there too) any way the water will not stop filling no matter what...
as to the filling issue this would either be the pressure switch or the hose that goes to the pressure switch to the tub has come off if you have any further questions message me back and please remember to rank this opinion it allows me to help others in similar situations Thanks Rick
p.s the starts agititating is normal when the lid closes it is engaging the lid switch
Mar 14, 2011 | GE WBSR3140D Top Load Washer
I HAVE A GE TOPLOAD WASHER MODEL#WSKS2060T1WB AND ITS LEAKING WATER I CHECKED THE HOSES AND THERE IS NO LEAKS IN THEM I DID NOTICE UNDER THE MACHINGE THAT THERE IS A SMALL HOSE THAT'S CONNECTED TO THE SIDE...
Take tub out, liner is cracked above motor do to off center load. Install new liner but cut fin off above motor before installing to stop this problem.
Oct 05, 2017 | GE WBSR3140DW Top Load Washer
GE topload washer occasional screeching noise during wash cycle
It sounds like it could be a brake pad that has broken and is partially rubbing against the brake frame.
Mar 07, 2009 | GE WJRR4170E Top Load Washer
GE topload washer Agitator
theres no nut and bolt,,only a cam or bell ..you have to roch agitator back and forth,,until it losens,,and pull up reall hard..or put your belt under agitator and yank up..onthejob
Jan 23, 2009 | GE WBSR3140DW Top Load Washer
Changing the belt on my GE washer
Take a 3inch plastic putty knife and slip it appx 2 inches from each side between the front panel and the top assy. There are 2 spring clips in this area. If you take a flashlight and look between the panels you can see them. When you pop off the panel it will come forward and lifts off the bottom clips freely. Install it by just setting in the bottom panel and pushing on each top side of the front panel.
Mar 31, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Frigidaire washer topload, Agitates but the tub spins
yes the problem parts of the transmission if your going to keep it have new transmission installed
Jan 17, 2008 | Frigidaire ATF6000ES Front Load Washer
GE WWSE5200B Top Load Washer Logo
183 people viewed this question
Top GE Washing Machines Experts
Marvin
Marvin
jimorris77
Sal De
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
