Question about Shure SM58 Professional Microphone
Shure sm58 mic does not have full power
I have to open the control on my peavey amp completely open to get enough volume.
  • 3 Answers
You should consider a microphone with more power to get the volume you need. I can personally recommend the CAD C195 Cardoid Condensor microphone. It has great output. The only downsidefor most people is that they don't have phantom power. This is what gives the mic its boost. In order to get the most out of any micrphone, you need to have a preamp, an equilizer, and an output. The output is your PA system that drumbanger mentioned.
But since you are using a Peavey, here is my strong recommendation. Get a mini preamp, and hook it up to your Peavey. You can use a Behringer 2mic mixing board for your preamp. It's small, and it can sit right on top of the Peavey.
XENYX 1002
http://pro-audio.musiciansfriend.com/product/Behringer-Xenyx-502-Mixer?sku=631262
CAD C195
http://pro-audio.musiciansfriend.com/product/CAD-C195-Cardioid-Electret-Condenser-Microphone?sku=270775
The reason why I suggest the two-mic XENYX 802 and not the 1 channel 502, is that the 1 channel doesn't have phantom power.
In order to connect the XENYX to your Peavey, this is all you need. You can get one at radio shack for pretty cheap.
http://accessories.musiciansfriend.com/product/Mogami-Pure-Patch-RCA-to-14-Mono-HiDefinition-Patch-Cable?sku=339031
Posted on Mar 22, 2009
    Genius:
  • 1,199 Answers
Sorry! this is normal because the mic needs to be used with a PA system
to get the full effect and volume out of it!
Posted on Jan 07, 2009
Trouble with the Shure SM58 Mic.
Hi Ian,
i think the problem is with recorder or recording volume setting.
please check.
regards.
nuwan
Jan 10, 2014 | Toshiba Computers & Internet
Shure PGX2/SM58 Power Button
Unscrew the cartridge from the top. Slide a screw driver down inside to pop off the switch cover. Remove the large "c" clip to remove the circuit board.
Mar 27, 2012 | Shure PGX-2 Wireless Handheld Microphone...
No sound
The SM58 needs to be connected to a mic input. A guitar amp is expecting a much louder signal then what a mic can put out.
Dec 31, 2011 | Shure SM58 Professional Microphone
Shure SM58 A singer has joined me with her own SM58 ,i have to turn the volume up much higher on mine ,with a more muffled sound .This is causing a prob .The PA is a Yamaha Stagepas 300
Please get the microphones checked seperately If there is an impedance difference orr if the coil is damaged then this difference of sound is possible.
So just check it out or else replace the mic.
Sep 13, 2010 | Shure SM58 Professional Microphone
I have two Shure sm58 mics that simply will not work...I do not know where to begin. How should I trouble shot?
If these are wired SM58 mics, they will probably need to be sent to Shure for repairs. The cost to repair is less than purchasing a new one, and they will usually just send you a new mic.
Aug 28, 2010 | Shure SM58 Professional Microphone
Shure sm58 mic stopped working ...
Check the wire connections where the xlr cable connects.
Apr 12, 2010 | Shure SM58 Professional Microphone
Shure sm58 just started outputting very low volume. It has been working fine with our system for years. Tried other sm58 mics on the same mic cable with same system setup and no troubles. There is still...
Check your wire connections inside the mic where the xlr cable connects to the mic. Hopefully your mic has never been dropped as this will damage it. The sm58 is pretty much indestructible, so check your cabling that you use, try a different channel.
Apr 04, 2010 | Shure SM58 Professional Microphone
What is name of battery cover on shure sm58?
If you have the regular 'ol sm58 hard wired mics, there are no batteries.
Mar 01, 2010 | Shure SM58 Professional Microphone
Where to buy a the swivel adapter for shure sm58 and shure wireless lx2 sm58
You can buy the swivels from Beyer, they have several sizes.
In my opinion he best you can get.
Regards,
Gerard
Jan 05, 2010 | Shure (LX287CC) Professional Microphone
Mic feedback. I sing on a shure beta 58 mic, into a 350 watt peavey amp, into 2 - 200 watt peavey speakers. My band is loud, and I simply cannot get my mic loud enough for them to hear me, without constant...
It sounds as though you are pointing the peavey at the band in a practice situation? If so make sure that each speaker is at about 60 degree angle to either side of the back of the mike (you facing the speakers), most mics reject feedback when the the user is directly in front of a monitor, but Beta 58s' tend to feedback more in that situation. Alternatively (if it is a practice room situation), why not place the speakers behind the band at 60 degrees each and turn to face the band.
Mar 12, 2009 | Peavey AMPLIFIER, 1000 WPC, DDT, 8/4/2...
Shure SM58 Professional Microphone Logo
475 people viewed this question
Top Shure Audio Players & Recorders Experts
Michial Gueffroy
Ben Armstrong
Vito Vacirca Jr.
Are you a Shure Audio Player and Recorder Expert? Answer questions, earn points and help others
