Question about Refrigerators
Can't find water filter on kenmore side refrigerator
Model no. 363.58775890. I've been searching for this filter for years. The water continues to have white particles in it.
  • 115 Answers
There is not a filter on that model to get one you will have to pur a inline filter behind the refrigerator please rate
Posted on Jan 07, 2009
I have a Kenmore side-by-side ultrafresh refrigerator model # 5255210, serial# SM0649567. I cannot find the water filter. Where is the water filter located on this refrigerator ?
Owning 1 of these refrigerators will require you to replace the water filter from time to time, in order to keep the water fresh and the refrigerator running efficiently. Kenmore refrigerators are made by Amana, Frigidaire, GE, LG, and Whirlpool, so it is important to find out which manufacturer made your Kenmore refrigerator, in order to make sure you order the right part. Kenmore refrigerators use filters that are located in the bottom, front panel of the refrigerator. Details can be found on WiKi how to change a water filter on a Kenmore Refrigerator.
May 24, 2016 | Kenmore Refrigerators
Kenmore side by side refrigerator water dispensor will not shut off
Your water control valve is defective and will need to be replaced. Even though you hear the electrical part of the valve turn off the mechanical part of the control valve is stuck open causing water to continue to flow. What is your model number? Kenmore model numbers look like this example=> 312.234567 If you can find your model number I will show you the replacement part number, Thanks Sea Breeze
Nov 29, 2012 | Kenmore 18.3 cu. ft. Top Freezer...
I saw your response to another Kenmore frig and I have a similar problem I want to ask you about. I have a Side-by-side Kenmore frig(model 106.9555722) that we've had for 16 years!! Other than r
I have seen this one other time in all my years of appliance repair and changing out the "water inlet valve" corrected the problem. I don't have an answer to why it did, but it did. Here is the valve for your unit.
After you change the valve be sure to purge the water line for a good 5 - 10 mins to get all the nasty water out. Keep me posted!
Nov 24, 2012 | Kenmore Side by Side Refrigerator
I have a Kenmore side by side, model # 106.57032601 that I bought 4 years ago. The ice maker suddenly quit working. The refigerator/freezer work fine otherwise and I continue to have water from the...
Is your ice tray filling with water? If not, then I would suspect the water inlet valve (http://www.searspartsdirect.com/partsdirect/part-model/Kenmore-Parts/Refrigerator-Parts/Model-10657032601/0582/0165000/K0607002/00012?blt=06&prst=0&shdMod=10657032601 - Item 10)
If it does fill with water, but does not eject the ice cubes to start a new cycle, I would suspect the ice maker motor(Item 37). BUT if it is the motor, that part costs $91.22 and you can replace the entire ice maker (Item 100) for $157.95
Jul 10, 2011 | Kenmore Refrigerators
Kenmore side by side refrigerator Ice maker not working
Found out we still had a warranty/service contract on it. Contacted SEARs and I explained problem to technician. Scheduled house call is Friday.
Apr 14, 2009 | Kenmore Refrigerators
Kenmore refrigerator water dispenser problem
SORRY TO SAY THIS BUT IT SOUND LIKE YOU HAVE BLACK ALGEA IN YOU WATER SYS WHICH IS GOING TO REQUIRE A TECH TO REPLACE ALL THE TUBING IN YOUR WATER INLET SYS TO GET RID OF IT. GOOD LUCK AND CONTACT APPLIANCE SERVICE CO. P.S. DON'T DRINK THE WATER OR USE THE ICE IT WILL CAUSE MEDICAL COMPLICATIONS
May 30, 2008 | KitchenAid KSRS25IL Side by Side...
I have the opposite problem
You may have air in the system. When you actuate the dispenser it opens an electric valve in back to start the flow of water. When you release the dispenser air in the system expanding will cause the water to continue to flow until the pressure equalizes.
May 21, 2008 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Water dripping on GE Fridge model TFX24ZR
check your water filter. water preasure is important in the operation of the water valves. if the filter is ok replace the valve. water filter should be changed at least once every year.
Sep 10, 2007 | GE (PSS26MSRSS) Side by Side Refrigerator
Refrigerators Logo
89 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
