Question about Sennheiser PX 100 Consumer Headphones
Want to replace PX100 wires
I want to replace my px100 wiring with the iphone 3g headphone wires that have the  mic and audio controls built in. Essentially, I just need to open the ear pieces to solder the iphone wires in place. Any advice on how to open and reseal?
Just be careful, maybe try to find a guide to dissasembling the PX-100's - I had a pair go bad that I tried to open up and I mangled them somewhat - of course I wasn't being super careful, nor were they in great condition at that point. There's a lot of you tube vides about replacing the ear buds with other ear buds - it should be straight forward, minus the extra care for taking the PX-100's apart. Any concerns about impedance matching for the wires? Could this represent a degradation of the PX-100's sound if the wires are diff. impedance?
Posted on Jun 25, 2009
Digital scales weigh half of accurate weight
Recalibrate. If that does not take, then there is an issue with the scale. Try installing a new battery since a bad or weak one often results in erroneous readings.
Jun 28, 2017 | Health & Beauty
What colour wire does what with Samsung in ear earphones
This is an educated guess.
You should have 4 rings around your 3.5mm connector. From the tip to the base of the connector....
#1 - left audio - Black
#2 - right audio - Red
#3 - Ground - bare copper
4# - Mic/volume - green/brown
The wires for the left and right channels (pins 1 and 2) and the ground, (pin 3) should run from the connector through the volume control, to each ear piece. The mic/volume wire should terminate at that control. although it could connect to more than one place within the control.
You may be able to open the volume control, gently, and see which wire stops there and which continue on through.
I hope this gives you enough information to complete your project.
Dennis
Apr 22, 2014 | SAMSUNG EHS64AVFWE Stereo 3.5mm White...
What is difference between iphone and iphone 3g
  • 3G speed capability
  • The iPhone 3G includes a built-in GPS.
  • The 3G is a bit thinner at the edges and includes a headphone jack that is flush to the side.
. The iPhone 3G differs from the iPhone in that it used 3G networking and included built-in GPS for expanded location based mobile services, and new iPhone 2.0 software
, which included support for hundreds of third-party applications that were built with the iPhone SDK
Jan 14, 2013 | Apple iPhone Smartphone
I can hear my game and my friends but they cant hear me
This means your mic has a short in the wire or is broken somewhere. Im pretty sure the skull candy lowrider headphones don't have a built-in mic. If this is your problem than you need to buy a mic.
Jan 12, 2011 | Skull Candy Lowrider Headphones
I have a pair of Sennheiser PX100 which I bought in 2007, so out of warranty but in "as new" condition. I cannot believe that my cat has just chewed through one of the wires. Can my beautiful...
See my tip on replacing dodgy cables plugs on headphones. Just click my name. I doub't also they would have covered the cost of repair because of your cat even if in warranty!
Nov 27, 2010 | Sennheiser PX 100 Consumer Headphones
I am trying to replace the jack on my PX100's. I have a replacement jack and have worked out which colour wires to connect to the various pins. Problem is resin cored solder suitable for other electronic...
See my tip on headphones jack/cable problems. Also sometimes they put on a special coating on the wires. You have to scrape the wire or file it to remove it. Spit is also good at making the solder stick!
Aug 20, 2010 | Sennheiser PX 100 Consumer Headphones
IPhone 3GS: suddenly music only on the left
hi. i can help you. begin by cleaning out the little hole your ear buds plug into. Carefully clean the jack hole with a needle or a tough pick. It allowed me to remove a lot of cotton like dust. if that doesnt solve it go into your phone menu under audio settings and see if you have adjusted the balance to cause your problem.
also, You can try removing any debris that might be in the headphone jack by plugging and unplugging the headphones a few times.
If the issue is not caused by debris in the headphone jack, request repair/replacement of the Apple Earphones with Mic online here: https://selfsolve.apple.com/GetWarranty.do
You can also request service by making a reservation with a Genius here: http://www.apple.com/retail/geniusbar/or call AppleCare U.S. iPhone technical support at: 1-800-MY-IPHONE (1-800-694-7466)
Nov 10, 2009 | Apple iPhone 3G
Don't know how to hook them up
What a lovely daughter, how very nice of her,
here goes....straight for Mr. Koss
To Operate with AC Adapter
  1. Open battery compartment located at the back of both speakers and remove wires.
  2. Replace battery covers.
  3. Connect DUAL PLUG CONNECTOR on left speaker to right speaker at connection marked "TO LEFT SPEAKER."
  4. Connect remaining wire with 3.5mm plug to headphone jack on your audio source.
  5. Connect AC adapter (not included) to back of left speaker at connector marked "DC 6V." Plug remaining end of AC adapter into wall outlet. Be sure your AC adapter is built with the center pin as ("-") negative. Connect remaining wire with 3.5mm plug to the headphone jack on your audio source.
  6. Turn ON/OFF switch at back of right speaker to "ON."
  7. Set "INPUT SELECTOR" switch to audio source.
  8. Turn on audio source
  9. Adjust sound in the following ways: Turn volume control to desired level; push Bass Boost button located on right speaker to "ON" for added bass; push Treble Boost button on right speaker to "ON" for added treble
  10. Operating a microphone through your speakers require an additional 3.5mm plug to 3.5mm plug cable (included). Connect cable with 3.5mm straight plug to right speaker at input marked "MIC" on back of speaker. Plug the remaining 3.5mm L--plug into the mic input on audio source. Connect your microphone to the front of your speakers at "MIC" input (microphone not included)
Hope you have all of the skinny you need, good luck,
please leave a rating, thank you kindly
Apr 27, 2009 | Computers & Internet
Open Questions:
Sennheiser PX 100 Consumer Headphones Logo
1,194 people viewed this question
Top Sennheiser Audio Players & Recorders Experts
Michial Gueffroy
Vito Vacirca Jr.
Rob Beech
Are you a Sennheiser Audio Player and Recorder Expert? Answer questions, earn points and help others
