Question about Microsoft LifeChat™ LX-3000 Headset
Headset transmits wave
Hi...
Please help me..
I can hear the person on the other line as well as she can hear me on the other line but the problem is my voice could not be heard sometimes and a very noisy wave can be heard on the other line...
Is it a problem with the internet connection, the settings of the headset, the headset itself or the computer itself?...
Please help.. I'm teaching online and this is the only source of my living..
Thanks
    Problem Solver:
  • 6 Answers
If you are hearing it on the speakers then it is possible the other computer's problem. If you are hearing it though the headset it could be a headset problem. Check your settings and try talking to a bunch of other people to assess the situation.
Posted on Feb 24, 2009
My hbs 850 headset apparently doesn't sound good to the person on the other side of the line. Volume is up. Any help?
The most important thing would be the position of the microphone. It needs to be close to your mouth, hopefully not under clothing. You need to speak clearly and perhaps a little slower for best results. The volume only helps your side, not your voice being transmitted. If that fails, it could be bad batteries. Lack of power to send your voice tends to garble Bluetooth. You would still hear fine because receiving takes a lot less power than transmitting. Let us know!
Mar 26, 2017 | Radio Communications
My voice does not transmit through the earpiece
Sounds like you have a problem with your microphone.
Please contact us.
Mark
Motorola Support
CONTACT US
Jun 04, 2014 | Motorola Mobility H710 Bluetooth Headset
I have a 2006 Goldwing with a Auto Com bike to bike communication system on it. It is tied into the OEM bike system. The bike did not have a CB on it so I installed one last year, but the problem that I...
Hi Walter,
When you're out riding with your mates, how close to the person you are trying to talk to is from you on the road?
If you are within 2 metres of the person you are trying to contact, neither they nor you will hear each other, keep at least 5 or more metres from each other and you should be able to chat with each other, remember that radio waves need room to move in before they are receiveable.
These units are low powered, that is to say no more than 1 watt rf output power, so the most distance that these radios can transmit to is about 5 kilometres line of sight only.
I hope this helps
Regards,
Peter
Feb 23, 2013 | Radio Communications
Dynex 18u headset not transmitting sound
Make sure your headset is properly plugged into the correct ports.
Make sure the volume is set to a medium level and is not muted.
Otherwise, I would recommend pursuing replacement options.
Feb 09, 2013 | Dynex - Universal Stereo Headset DX-18U
Static lines
when you hear static you lines on your cellphone it maybe the time to replace your earpiece, if you don't hear static lines when you use a headset then your earpiece is busted but if you still hear static lines while on your headset it means that something's on your surroundings that interrupts your signal it could mostly be a radio or a metal that could strongly blocks your radio wave. if this is helpful, please vote for me
Jun 27, 2011 | Nokia 3110 Cellular Phone
Problem for Plantronics CS50 Wireless Headset - I can hear the person on the other end when the configuration dial is set to 1,2 or 3. But th other person cannot hear me. When I set the dial to 4, others...
The following is a cut from Plantronics web site. I hope it helps, It's just possible you have missed a setting, such as the mute switch.
The CS50 has both transmit (how you are heard) and Receive (how you hear) controls on the unit itself.
The Master Transmit controls are the ABCD switch settings on the bottom of the base. A is the lowest and D is the highest setting. You can fine tune this setting with the Plus (+) and minus (-) buttons on the back of the base that are above and below the picture of the microphone.
The Master Receive setting is on the back of the base (below the picture of the microphone) there is a 1234 switch 1 being the highest setting and 4 being the lowest setting. You can fine tune this setting by using the volume control on the headset itself. This is the rocker volume wheel on the back of the headset (opposite of the microphone).
The headset volume control also doubles as a mute switch if you press it in, instead of rocking it back and forth.
There are also configuration settings on the left hand side of the base. This is a dark grey dial with a 1234 on it. There are notches to the right of this dial. Whatever number is lined up with the notches it what setting you are on.
This needs to be set to the clearest setting.
There is a silver button on the headset itself which is your “Talk button”. This is what you press to use the headset and or transfer the call from the headset back to the hand receiver.
There is also a switch on the right hand side of the base which is your the IntelliStand feature.
When the CS50 is used in conjunction with the HL10 handset lifer you can enable the IntelliStand feature.
The IntelliStand feature senses when the headset has been removed or placed into the CS50 base unit which automatically activates the Handset Lifter and enabling headset/handset mode to answer or end the call.
There is a switch towards the bottom on the right side of the base unit that will switch the IntelliStand feature On and Off.
Apr 11, 2010 | Plantronics PL-CS50 Professional Headset
Plantronics CS55. When using the wireless headset
Echo is usually caused by the transmit (speak) level on the unit being set too high.
1. First, try lowering the volume of the telephone. If you still hear an echo, adjust the volume of the headset itself.
2. The master transmit controls of the headset are the ABCD switch settings on the bottom of the base. A is the lowest and D is the highest setting.
3. You can fine tune this setting with the plus (+) and minus (-) buttons on the back of the charging base.
4. If this doesn't fix the echo, try moving the configuration dial on the left side of the charging base. The recommended setting for most phones is 1.
Jul 10, 2009 | Plantronics CS55/HL10 Wireless Office...
GN Netcom wireless headset volume adjustment
Transmit volume adjustment
Adjust the volume of transmitted sound according to personal preference.
To adjust the volume:
1. Make a telephone call and ask the person you are calling to assist
you.
2. Press the +/– buttons on the headset simultaneously for 2 seconds.
A beep will indicate when 2 seconds has passed.
3. Adjust the volume level by pressing the + or – button.
4. When the person you are speaking with fi nds the volume of your
voice appropriate, press the +/– buttons simultaneously for 2
seconds. This setting is now stored in the headset.
A Copy of the manual is avaliable at:
http://www.onedirect.es/files/GN%20Netcom-ES/GN%20Netcom%209120%20manual.pdf
You must have Adobe Reader to view it and the instructions are on page PDF page 3 or manual page 6. Adobe Reader is avaliable for download at:
http://www.adobe.com/products/acrobat/readstep2.html
May 21, 2008 | GN Netcom (9120-48) Wireless Headset
GN Netcom GN 9120 - can't hear
Hi There, I had the same problem with a headset one of our call centre reps were using. It's usually due to some one fiddling with the button. I got it working by removing the battery from the headset then resinked the headset to the base unit. Hope it works for you
Jan 30, 2008 | GN Netcom GN 9120 Professional Headset
Open Questions:
See all Microsoft LifeChat™ LX-3000 Headset Questions
Microsoft LifeChat™ LX-3000 Headset Logo
99 people viewed this question
Top Microsoft Radio Communications Experts
Adrian W
Adrian W
Level 1 Expert
Are you a Microsoft Radio Communication Expert? Answer questions, earn points and help others
