Question about GE Washing Machines
Washer will not spin load just drains the water.
When you start a load it adds the water but the unit never moves on the inside. It will go throung the whole cycle with even moving the clothes around and washing them. It also smells like something is burning. I think the motor went out, how do I know whats wrong.
  • mich10_2000 Jan 07, 2009
    Thank you for the help.
    Genius:
  • 1,199 Answers
This is your washers rubber belt (the smell of burning!) the belt that drives the washers barrel broke and needs replaced (I think your moter is fine!) replace belt inside of washer!
Posted on Jan 07, 2009
    Genius:
  • 3,422 Answers
If your washer won't spin, check these:
It doesn't pump or spin
It pumps, but doesn't spin
It spins only with the lid closed
It doesn't pump or spin If it doesn't pump water out or spin, check to see if the motor is running, then proceed as follows:
  • Ifthe motor is running, your washer probably has a frozen pump pulley ora broken pump belt. To check the pulley, remove the pump from thewasher and try to rotate the pulley manually. If it doesn't turnfreely--if it's frozen or stiff--replace it. If the pump belt is brokenor looks quite worn, replace it--but be sure to check the pump pulleybefore you change the belt.
  • If the motor isn'trunning, the lid switch may be defective. If so, the washing machinecan't spin and may not function at all. The switch is inside thewashing machine main housing near the door frame. Often you have toraise or open the top or front of the washing machine to get to theswitch. If it's defective, you need to replace it.
It pumps, but doesn't spin If your washer pumps out the water but doesn't spin, check these:
  • Thelid switch may be defective. If it is, the washing machine doesn'tspin. The switch is inside the washing machine main housing near thedoor frame. Often you have to raise or open the top or front of thewashing machine to get to the switch. If it's defective, you need toreplace it.
  • The motor coupler may be broken. ManyWhirlpool®-manufactured washers use a small, relatively inexpensivemotor coupling. It's plastic and rubber and is mounted to the shaft ofthe motor on one side, and to the transmission on the other. Over time,the coupler wears out and fails. You may need to replace it.
  • Abelt may be broken. Many washing machines have one or two belts. If abelt is broken or badly worn, you need to replace it with a genuinebelt from the manufacturer. (Some washing machine belts are designedwith special characteristics not found in automotive belts.)
  • Theclutch may be worn. If your washer is a GE, it may use a clutch to comeup to the proper spin speed. As the clutch wears out, it may preventthe unit from spinning well or at all. If the clutch is worn, you needto replace it. For this job, you probably want to hire a qualifiedappliance repair technician.
  • The drive motor may bedefective. Many washer brands use a reversing motor. For agitation themotor runs in one direction, for spinning and draining, the other. It'spossible for a motor to burn out in one direction and continue tooperate in the other. If this happens, you need to replace the entiremotor.
  • The transmission may not be shifting properly.Older washers produced by Whirlpool® have a transmission with anelectro-mechanical shifter. If the shifter becomes even partiallydefective, the unit may drain the water but not spin. This is a complexsystem, if your washer has a shifter problem, you may want to hire aqualified appliance repair technician to repair it.
  • Thespin bearing or basket drive may be worn or seized. These componentsallow the inner tub to spin freely inside the outer tub. When this isthe problem, you usually hear a loud sound during the spin cycle. Calla qualified appliance repair technician.
It spins only with the lid closed Forsafety, washing machines are made so that they spin only with the lidclosed. The lid switch prevents the spinning action when the lid is up.
Didn't drain. Won't spin.
Hi Kat, let's see if I can help your with this. The washer will not spin when it senses water inside so we'll start first with the drain. When the machine was finished washing, did you hear the drain pump attempting to discharge water? Try selecting the "Spin Only" or "Rinse and Spin" cycle, you should be able to hear whether or not the drain pump is attempting to operate. If you do hear it running, but the water is not draining, it is possible that the drain filter is clogged. If you need instructions on how to clean the filter let me know. Otherwise, we'll move to the next step.
Mar 07, 2015 | Samsung WF203ANW Front Load Washer
My Asko washer model number WL6511XXLPP will not spin it is draining what's the problem
All front load unit must lock the door and drain all the water prior to spinning. If your filter inside the drain pump is clogged this unit will not spin. At the bottom of the washer is a door, open this door and unscrew the plastic cap. *This is the lowest spot on the washer, so this will hold water, be prepared for water* After you clean this out, run a rinse only cycle and re-test unit, if the unit fails to pump out completely, replace the pump. Good Luck
Aug 04, 2014 | Washing Machines
Started filling, made a loud noise, stopped filling immediately, door wouldn't open. I tried everything to get it to open. Running the spin cycle finally got the door open at the end of the cycle, though...
The washer drain the water if you put on spin. all electronically controlled washer won't unlock the door and or spin if there's water inside the water has to be drained out first.If the basket didn't move(no motor movement) and it finished the cycle, POSSIBLE problem is the motor control board. Motor Control Board 00436461
Nov 22, 2017 | Siemens WFXD5200UC Front Load Washer
Just recently moved & had washer in storage for about 4 months during summer. The washer will add necessary water then just as the wash cycle is about to start it goes from 38 minutes to 4 minutes on...
does it drain the water??? most coommon prob with this unit is faulty pump/ item in pump preventing proper drain, if it thinks theres water in or too much water in it will automatically try to drain and do nothin else, drain motor might have siezed form sitting as well, that why yo ned to check to see if water is actually draining out.
Oct 13, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
Frigidaire top loader washer won't drain
The timer has went bad in your front load washer.Thats the reason why the unit is not draining properly. If you move the timer manually to spin will it pump the water out? if it works that way then the timer is bad for sure. You should go for a replacement.
Thank you !!
May 31, 2010 | Frigidaire ATF6000ES Front Load Washer
Can I reprogram a front load GE washer so I can add a drain and spin cycle that this machine does not have?.Sometimes my clothes come out too wet and it would be nice to spin and drain them again without...
just add another drain and spin cycle and start it up again with the completion of the first cycle. Washing some items like sleeping bags takes forever because they are so darned absorbent and hold more water than a tiger's sieve of a bladder. Another drain and spin cycle should solve the problem.
Apr 20, 2010 | GE WBVH6240F Front Load Washer
My frontloader starts out fine , but when time to drain, it spins and only a small amount of water comes out,the spin cycle is so load and moves the washer while spinning also the cycle ends and the...
check water pump , from your discription i beleive you have a blockage before the pump this would account for the small amout of water removal
NEVER OPEN MACHINE CASE WITH REMOVING POWER PLUG FROM THE MAIN POWER SUPPLY
Jan 16, 2010 | Frigidaire ATF6000ES Front Load Washer
Maytag washer top loading leaks water seems to be coming from the tub itself 7 years old thank you mija
does unit leak constant or only when spinning ther are 2 screws done low on front panel fill unit with water and watch center shaft there is a seal below basket
inside washer changing seal is a little difficult have also had this style of washer leak when starting spin cycle if water has not drained out fast enough
http://www.repairclinic.com/Washing-Machine-Top-Load-Maytag-Style-Appliance-Diagram
this page has a break down of normal maytag top load machine part at center is called boot and seal have also had thi type unit leak where bolts go through tub
good luck ron
Dec 12, 2009 | Cameras
The drain/spin cycle always adds water
It's normal if it just adds a little bit of water. It does this so your drain pump impeller doesn't run dry which could damage it. If it's filling right up, there could be a malfunction with the control board, the pressure switch or the inlet valve .
You could try shutting off the water supply at the taps before you start the drain/spin cycle.
Feb 08, 2009 | Whirlpool GHW9400 Front Load Washer
Drum doesn't move or spin
kenmore tumble action washer model#417.44152400,
Washer is approximately 3 years old. Will not drain or spin. When it tries to spin, clicking noise heard inside of unit. Would a clog insie the lines disable the spin cycle ?
Oct 18, 2008 | Kenmore 43142 Front Load Washer
Washing Machines Logo
20 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
