Question about Indesit W 123 Front Load Washer
Replacing door seals
Have a WG113 with a leaking door seal, which I have refitted but can't get the final wire tensioner on to the seal on the actual external door part. Can anyone tell me how to do it? There is a piece of wire with a loop at either end to fit into a recess but I can't get it in place. Very many thanks for any help
    Sergeant:
  • 236 Answers
Put it together and push a small screwdriver into each spring hole. streach the spring outwards and ease the wire around slowly.
Posted on Jun 01, 2007
Replacing door seal front loader bosch
This video will show you how to change a door seal on this bosch
Apr 04, 2010 | Kenmore HE2 Plus Front Load Washer
Replace LG washing machine seal
Hi
When you open the machine door, you will see a manufacturer's badge. Record the model number and call around to order the door seal from your local parts vendors. Have the replacement seal ready when you are changing the seal. If you remove the seal and then go to source it, then you might not remember how it was put on initially.
To replace door seal, First turn off machine and unplug from its power source.
Next remove top lid. Two screws in the back of the top lid and you can slide the lid back and up to remove. See if you have a clear view of the door seal from above the machine and see how it is joined to the drum mouth. There would be a metal ring holding it in place. Locate the screw which tightens it and unscrew it to loosen the ring.
Next the wire ring which you have already seen on the front of the seal needs to be removed. These are normally spring loaded. Feel around the ring until you get to the spring tensioner. With a flat screw driver, stretch the spring to pull the ring out from around the seal.
Now observe how the door seal is clipped around the front panel of the machine. The seal has a groove which fits snug agains the rim of the front panel. You can now remove the seal by pulling around the edge.
Now go back to the top of the machine and do a similar thing to remove the seal from around the drum. Make sure you observe how it had fitted on originally, and also observe if there are any differences between the top and bottom of the seal where it sits on the door. There normally is a difference.
When replacing the seal in the reverse manner, make sure you fit the seal correctly around the lips of the drum and the front panel. make sure you also correctly tighten and refit the rings to hold the seal in place.
Once you have finished run a couple of quick cycles without cloths, to make sure there are no leaks and that the seal is fitted properly.
Good luck.
Ash
Nov 09, 2009 | LG Washing Machines
How do I change the door boot seal on a Hotpoint Aquarius WMA31N?
Ok - I will answer my own problem seeing as though I have now fitted it!
1. remove door (2 screws)
2. There is a tensioned wire loop holding the front part of the boot seal in position. - prize off the plastic cap at the 11 o'clock position, all will become clear and you will be able to remove the wire loop.
3. Remove top of washing machine (2 allen screws behind caps at the front.
4. Remove soap dispenser draw and any screws holding the front control panel and top of the door.
5. Remove bottom front plinth (just pull it off) underneath are a couple of screws holding the front panel part of the machine, remove these.
6. Remove front of machine giving you access to the steel band which locks the other end of the boot seal in position. Slacken this band right back using a nut-spinner screwdriver. Pull off the old boot and clean the lip ready for fitting of the new boot.
7. Fit new boot seal using a squirt of washing up liquid as lubricant if needed (mine didn't) to reseat the seal.
8. Refit and tension steel band.
9. Re-assemble front panel, ease boot back into front lip position then refit wire loop using a suitable pair of pliers/molegrips to crimp the retaining plastic cap back in situ.
Oct 05, 2009 | Hotpoint WMA31 Front Load Washer
Advise correct procedure for replacing door seal on aeg lav 72620
Follow these steps to replace your door seal:
Disconnect all power to the machine first!!
1 Locate the outer clamp band securing the seal to the door rim on the washing machine and examine it carefully for holes or tears. Many can be prised off with a flat-bladed screwdriver they have a spring system holding them, but some have a tensioning arrangement that has to be loosened.
2 After removing the outer clamp band, locate the inner one securing the seal to the drum and establish how this is secured. It may be necessary to loosen a clip, or you may be able to prise the band off with a flat-bladed screwdriver. Some are like very large Jubilee clips that you have to undo usually from the top.
3 Once the clamp bands have been removed, use both hands to pull the seal away from the inner drum rim. Some machines have a water spout holes that will have to be lined up. Others have a drain holes.
4 Rubbing a drop of washing up liquid into the groove on the door seal/gasket that locates on the drum makes fitting the new seal easier.
5 the new washing machine door seal should be fitted by locating the drain holes at the bottom of the seal first then push it on with both hands working opposite directions towards the top. This is quite hard if you have never done it before.
6 refit the inner band remembering this must be tensioned correctly for it to be water tight.
7 now fit the outer band and the test the machine for any leaks,
All washing machine spares featured in this article are available at apart4u with more video help in our tutorial section.
Information provided is a guide only. aPart4u accepts no liability for any problems occurring whilst attempting any advice shown. If in any doubt about fixing your appliance, always contact a qualified repairer.
May 18, 2009 | AEG Lavamat 72640 Front Load Washer
Replacing door seal rubber boot
Hi its just a peice of wire with a spring tensioner just pull the door seal free" towards side of machine not forward" it will come .....then you will see wire ! you will kick yourself when you see.... it i did lol
Tommy-B-
Oct 26, 2008 | Hotpoint Aquarius WF000 Front Load Washer
Replacing door seal
For all Free appliance repair videos visit our VIDEO TUTORIALS
Sep 15, 2008 | Zanussi FLE1416W Front Load Washer
WMA46 Door Seal
turn off at mains
remove clamp that holds door seal to cabinet. peel door seal off cabinet.
remove worktop
undo clamp that holds seal to tub. pull seal away from tub.
to refit
lubricate slot in seal that goes on tub rim with washing up fluid
starting at top, fit groove in seal onto rim and work your way round in both directions pushing seal on to tub rim - requires patience and you amy not suceed first time round.
refit inner clamp
fit seal rond cabinet -0 this part is easy
refit outer clamp.
test for leaks on rinse as the water level is higher
Sep 07, 2008 | Hotpoint WMA46 Front Load Washer
Fitting door seal
this is general for fittying door boots.
on cabinet, door boot is usuallyn held by a wire ring tensioned by a small spring. prise it out with a screwdriver.
on tub, door boot is held usually by a giant hose clip for want of a better description. unscrew the tensioning screw and remove.
door boot will then pull off - just pull it off in one place then go round the circle.
to refit.
lubricate the groove in the door boot that fits on the tub with washing up liquid. insert groove on tub at any convenient place and force into position by running thumbs round it in opposite directions. this is a knack i have to say.
when on, replace the giant hose clip and tighten.
slip the outer part of the door boot on the cabinet - this is usually easy. replace the holding clip.
put onto rinse cycle to test for leaks
good luck
Jun 24, 2008 | Washing Machines
How do i fit a new door seal???
disconnect from mains not that easy first time. undo clip holding seal to cabinet. peel off seal and push inside drum remove top.i remember seal is held to tub by a giant jubilee clip but varies with model. undo clip and remove seal complete. fitting is more difficult lubricate slot that fits flange of tub with washing-up fluid - essential start at top fit an inch or so of slot onto tub flange. work in both directions forcing slot onto flange with thumbs as you go round. refit giant jubilee clip. refit seal to cabinet and refit cabinet clamp. test for leaks on rinse as water level is higher. this job is a knack so persevere
Mar 28, 2007 | Candy CN126 Front Load Washer
Water leaking from front
tear in the door seal, will probably need new seal - had this a few times, apparently usually caused pulling large loads out in a clump pulls and tears at the seal
Oct 24, 2006 | Hotpoint Ultima WF860 Front Load Washer
Indesit W 123 Front Load Washer Logo
199 people viewed this question
Top Indesit Washing Machines Experts
shaun taylor
Marvin
Marvin
Are you an Indesit Washing Machine Expert? Answer questions, earn points and help others
