Question about Audiovox MMD70 Car DVD Player
Scrambled LCD screen
My Audiovox MMD10 drop down DVD player's screen is scrambled. When I turn it on, the DVD screen is scrambled, it also won't play the disc inside and the sound is not transmitted over the car radio. It was working perfectly fine then my kids touched it and now it's not working...please help Thanks
  • jurodz1203 Jan 09, 2009
    i have veritical lines going down the screen
SOURCE:
techman
  • 3130 Answers
SOURCE: Multiple vertical colored lines on DVD player screen
check this out http://www.techlore.com/forum/thread/12629/
Posted on Sep 26, 2006
  • 15 Answers
SOURCE: Bad Disc Error
TAKE A LOOK ON YOUR LENS MAYBE IT WAS NEED A CLEANING CLEAN IT W/A COTTON BUDS CAREFULLY OR OBSERVE CENTER MOTOR IF ONCE YOU ON YOUR VE700 IF IT SPIN ALITTLE BIT IT REQUIRED YOU TO CONCENTRATE ON LENS AND MAYBE YOU TO REPLACE IT
Posted on Aug 27, 2007
SOURCE: Audiovox D1708ES Car Dvd
Try his I found on Ebay
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&Item=300219186223&Category=15055&_trksid=p3907.m29
May or may not fix your problem.
Posted on Apr 26, 2008
SOURCE: Audiovox D1020 DVD player won't read DVD anymore
I have the same problem! The only way to fix this is to replace the motor that spins the DVD. if you take it apart and spin the DVD the movie will play. The motor is just wore out and has no torque to start the play process. I am still looking for a replacement motor for it and haven't found anyone that carries the motor required. Only Audiovox so far and they want 180 to send in and fix.
Posted on Jan 16, 2009
ja_nakia357
SOURCE: Audiovox 7''dual screen mobile dvd system will not play the dvd's
try grounding the pink wire
Posted on Apr 14, 2009
DVD won't play
The DVD player appears to have more than one problem, I recommend it be replaced "far cheaper"
Mar 18, 2012 | Audiovox Televison & Video
How do you unlock an Audiovox D1788?
Hello
Enter the Menu screen, select, preference, select default, and OK.
If the problem is with password forgot, the default passord of this unit is [ 3308]. Enter this password on the first screen. Sometimes the unit won't accept this passord for the first time to cheat you, enter this pasword again. After that, you can enter your own passord. OK.
Nov 17, 2011 | Audiovox D1788 Portable DVD Player
I have great sound on my Audiovox portable dvd player but no picture. Can you help?
  • Check that the A/V IN/OUT Switch on the side of the player is set to the OUT position.
  • Check the small switch near the hinge at the back of the unit, if one is installed there. It turns off the LCD screen when the panel is closed. This switch sometimes sticks in the down position and the screen remains off. When the screen is opened, the switch is supposed to pop up. If it is still in the down position, try to free it with the ends of a toothpick or paper clip.
  • If both switches are correctly set and the screen remains blank, the unit should be sent to Audiovox for service.
May 16, 2011 | Audiovox D1708 Portable DVD Player
Audiovox portable dvd PVS6360 unlock codes
Audiovox code hack for DVD players
1. Turn the DVD player on
2. Go to the main setup page
3. In the main set up page press the numbers 9653
4. In the new menu go to region press enter
5. In region use the up and down arrow to select the region
6. Turn the DVD player off and turn it on
7. You now should have changed to the region of choice.
This hack was found on the internet. I hope this information helps you with your problem.
Dec 13, 2008 | Audiovox D1210 Portable DVD Player with...
Audiovox DVD overhead Monitor
the power supply amperes might be too low try using car batt as your power source
Nov 09, 2008 | Audiovox VOH8512 Overhead LCD Monitor Car...
Screen got really hot and now it won't play DVD's
I was going to see if you DVD player has a reset button on it but it isn't popping up on Audiovox website.
If you open up the player see if there is a reset button on it. Hold it down for about 5 seconds and see if that works.
Unplug power from the unit and remove the battery as well. Put them back in.
Try a different DVD in case its warped or damaged.
If those don't resolve the issue you should take it in and have someone look at it.
Jun 17, 2008 | Audiovox DT102A
Audiovox D1812 disc loads & plays but VERY dim screen
Sounds like the backlight isn't working, could be the flourescent tube or the inverter that powers it. At least those are the likely suspects in other LCD monitors that have similar problems.
Apr 01, 2008 | Audiovox D1812 Portable DVD Player
DVD/VHS PLAYER 5 YRS OLD...WHEN TRYING TO PLAY A DVD, IS SCRAMBLED
The laser is failing. It's called "digital drop-out". A replacement laser runs around $60, but you're better off just replacing the unit.
Nov 21, 2007 | Sony SLV-D350P DVD Player/VCR
Sep 26, 2006 | Audiovox D2010 Portable DVD Player with...
Audiovox MMD70 Car DVD Player Logo
172 people viewed this question
Top Audiovox Car Audio & Video Experts
xxxxxx xxx
Jaime Hernandez
Marvin
Marvin
Are you an Audiovox Car Audio and Video Expert? Answer questions, earn points and help others
