Question about Viper Security and Remote Start System (basic install included)
Parking lights stay on when i use the remote to lock or start trk
I had a new alternator put on and now my parking lites stay on when i use the remort start or lock the doors. i can disconnect the batt. for a few seconds and it turns the lites off until i use it again. any ideas?
    Scholar:
  • 89 Answers
I had a transmission wire reversed on mine and it would not shift into 3rd gear, when I used remote start. Seems like a wire may have gotten crossed or the hood safety switch may have come loose and is indicating a safety problem.
Posted on Jan 09, 2009
Hi I have got an Astra car.remort key is not working to open and close the lock.if u can help me plz thanx
Hi there, first things first, have you checked the batteries in the remote? If the batteries are good (you can also check the batteries by seeing if the light on the fob works) then put the key into the ignition and switch it to "on" (but don't start it) and then press the "lock" button. The locks should then cycle locked/unlocked and the key has been reset!
Jul 10, 2013 | Vehicle Parts & Accessories
Reset airbag module on 2002silveado
normally if a car has been in a bump and the air bags deployd a new air bag moduel is needed thats why it cannot be reset
Sep 26, 2012 | 2002 Chevrolet Silverado 2500HD
Driving 2003 f-250 down rd, and all cluster on dash went out then stopped and put trk in park then trk died... Tried starting and everything was dead... Jumped trk off and started up drive for a few miles...
Was the alternator tested off the truck on a bench tester or on the truck with the engine running?
If bench tested check the fusable links at the starter switch and make sure one has not blown. It will stretch like a rubber band if it is blown.
Feb 29, 2012 | 2003 Ford F250
I just pruchased a 2000 cv p/i and droves it appx 230 miles back to my home with no problems at all now I shut it off and it won't turn over I have power lights horn power locks etc etc we charged the...
Just a guess Mike, but that has all the symptoms of a security system thinking you are stealing your new car-try locking/unlocking the car with the keyless remote fob, or the door key pad (if you have one)-make sure it is in park, if that doesn't work, put it in neutral and try to crank it-Hood, trunk is shut, right? Call the former owner and ask questions, use a voltage meter (digital) and check the battery voltage (should be at least 12.5)-
Apr 08, 2011 | 2000 Ford Crown Victoria
Battery lite came just replaced the battery and chkd alternator (it was good). I jump the battery and trk stays running about 10 mins and dies. Could it still be the alternator?
i might be a bad altinator but i would double check your battery. a bad battery will kill a new altinator. does the battery light stay on? if the battery light on the dash is not on you may have another problem...
Nov 20, 2010 | 2003 Ford Expedition
My 2000 silverado is locked in park i have checked fuses (ok) brake lights work it will not shift with switch in on position and truck not running i know there is a switch that locks shifter but don't know...
Have you tried turning the steering wheel left then right while you are trying with the key to get the trk. out of park I had an old truck that the steering wheel didn't lock, had to call the dealer when I got a new trk and that's what he said to do. It worked. If you call the service they might know what to do.
Sep 03, 2010 | 2000 Chevrolet Silverado 2500
No power whatsoever to 2002 PT Cruiser, no lights, remote door lock doesn't work, nothing when I turn the ignition key. Just parked it yesterday and it worked fine. Had the battery replaced about a month...
Start by checking the battery even if it's new. If the alternator is not charging it, it will go dead even if it's new. If a recharge gets it started, then get the alternator checked. Once running a simple check of the Alt. is to put a voltmeter across the battery terminals and see if you have 14v which usually indicates it's OK. If the Alt. is OK look for a battery drain. Something staying on all the time even when the engine is off.
Mar 19, 2009 | Mitsubishi Diamante Cars & Trucks
Alert 450R - Lights Won't Flash Anymore
is your parking light wire, wired positive or negative. If positive check the fuse on the input wire for the parking lights on the remote start. If thats not the problem check the connection of the parking light wire,should be a whiite 16 gauge wire, to your car lights. If thats not the problem then they output for the lights is bad and you'll have to get a new brain.
Feb 19, 2009 | 450-R Deluxe Remote Starter with Keyless...
Headlight switch 1998 chevy s10 exended cab 4x4
try putting the emergency brake on and then put the head lite switch to the park lite position, if the head lites do not cme on then they are your daytime running lites. as for a larger altenator this depends on what amperare of one you have now, but in most cases you can get a higher amp. altenator. you will have to find out what amp yours is and any parts store will be able to get one for you.I assume you want the bigger altenator for charging an auxillary battery, ( camper, trailer, or you have lots of extralites on your vehicle ).
hope that you find this to be helpfull.
Oct 14, 2008 | 1998 Chevrolet S-10 Pickup
Open Questions:
Viper 4806v won't program I am trying to install a viper 4806v two-way remote start/keyless entry in my automatic 2004 toyota camry LE 4cyl. I got the lock/unlock, horn, lights to work, and trunk pop to work. I can't seem to get the remote start to work. When I press the remote start button on the remote keypad, the car does not start and the headlights flash 7 times. Troubleshooting says 7 flashes mean a manual transmission mode error. This means I have to enter programming menu 3 and change the starter to automatic mode. When I follow the directions to get to menu 3, nothing happens because I cannot get to menu 3 when I hold down the control button after turning the ignition off. In other words, the control button is not working. The neutral switch is on like it is supposed to be. Kind of bummed about this. Could use some guidance. My wiring goes accordingly and this car does not have an immobilizer because I used a regular metal key to start it. This car has no alarm, just a stock keyless entry, trunk release, and panic button. Again, the problem is :The remote start comes in default manual transmission mode so I have to switch it to automatic transmission mode but I can't seem to enter programming. When I try to enter programming with the procedure followed using the control button, nothing happens. It does not chirp and the LED does not blink. I also cannot enter valet mode using the control button. When the car is locked, the LED blinks and stop blinking if car is unlocked ignition is turned on. I do not understand what is going on. VIPER 4806V Wires --->Camry Wires Main Harness 6pin connector H1/1 Red 12volt input (+) --> (+) White/Red at ignition Harness H1/2 Black Chassis Ground (-) --> Car Frame (-) H1/3 Brown 200mA Horn Output (-) --> Green/Black (-) at steering column H1/4 White/Brown Light Flash Isolation Wire --> NOT USED H1/5 White Light Flash --> Hazard Light Flash Relay Lt. Green Black wire (-) H1/6 Orange Ground when armed --> NOT USED Door Lock 3 pin connector 1 Blue 500mA Unlock Output (-) --> Blue Wire (-) white connector at driver kick panel 2 Empty --> NOT USED 3 Green 500mA Lock Output (-) --> Blue/Yellow wire (-) blue connector at driver kick panel Auxillary/Harness 24 Pin Connector 1 Pink/white 200mA Ignition 2 output/ Flex output (not used) --> NOT USED 2 Blue/White 2nd Status/Rear defogger output (-) --> NOT USED 3 Red/White 200mA Trunk Release Output (-) --> 5pin Relay Pin 85 (86 & 87 to +12V, 87a White/blue trunk wire toward dash, 30 white/blue trunk wire toward trunk) 4 Black/yellow 200mA Dome light Output (-) --> NOT USED 5 Dark Blue 200mA Status Output (-) ---> NOT USED 6 White/Black 200mA Aux 3 Output (-) ---> NOT USED 7 White/Violet 200mA Aux 1 Output (-) ---> NOT USED 8 Orange/Black 200mA Aux 4 Output (-) --> NOT USED 9 Gray Hood Pin input (-) ---> Installed at hood and Switch is open when hood is closed 10 Blue Horn input (Jumper set (-)) --> Green/Black (-) at steering column 11 White/Blue Activation Input --> NOT USED 12 Violet/White Tachometer Input --> Black/Orange wire on the Datalink Connector 13 Black Neutral safety/Parking Brake Input (-) ---> (-) Ground to metal frame of car. 14 Green/Black 200mA Factory Alarm Disarm Output --> NOT USED 15 Green Door Input (-) --> Red/Black Wire (-) (Door open indicator on dashboard) 16 Empty --> NOT USED 17 Pink 200mA Ignition 1 Output (-) --> NOT USED 18 Violet Door Input (+) ---> NOT USED 19 Violet/Black 200mA Aux 2 Output --> NOT USED 20 Brown Brake Shutdown input (+) --> Green/White Wire (+) at brake switch above brake pedal 21 Violet/yellow 200mA Starter Output (-) ---> 5 pin Relay pin 85 (Pin 86 & 87 is +12volts, Pin 30 black/yellow starter wire (+) at pin 8 in ignition harness) 22 Gray/Black Diesel wait to start Input (-) --> NOT USED 23 Orange 200mA Accessory Output (-) --> NOT USED 24 Green/White 200mA Factory Alarm arm output (-) --> NOT USED Remote start 8 pin Connector 1 Red/black 12v Constant Input for Acc and starter relay (+) ---> White/Red wire 12v (+) at ignition harness 2 Pink/black Flex relay input 87A key side (+) --> NOT USED 3 Pink/white Ignition 2/ Flex Relay output (+) --> Black/yellow pin 4 at ignition harness 4 Red 12V constant input for ignition 1 Relay (+) -->White/Red wire 12v (+) at ignition harness 5 Violet Starter Output (+) --> Black/White wire (+) at ignition harness 6 Accessory Output (+) --> Blue/Red (+) at ignition harness 7 12v Constant input for ignition 2 and flex relay (+) ---> White/Red wire 12v (+) at ignition harness 8 Pink Ignition 1 input/output (+) --> Black/Red wire (+) at ignition harness.
Oct 20, 2014 | Viper Security and Remote Start System...
See all Viper Security and Remote Start System (basic Questions
Viper Security and Remote Start System (basic install included) Logo
111 people viewed this question
Top Viper Home Security Experts
Will Halftowaite
jason
Kevin Daniels
Are you a Viper Home Security Expert? Answer questions, earn points and help others
