Question about Mintek MDP-1815 Portable DVD Player
DVD won't spin or play.
When you turn on the unit and insert a DVD and close the cover the unit won't spin. The screen indicates that the door is still open. So I understand why it won't start to spin the DVD. Can you tell me where the door switch is? Is it part of the door latch or is it twords the back of the cover? I think once I can clear the open door message it will work.
  • Anonymous Dec 01, 2007
    I have a similar problem. The unit has never worked. The DVDs I put in won't spin, as the player indicates an open message at all times. The striker-pin that enters the hole to indicate that the lid is closed is fine, and I have tried simulating the action with a blunt toothpick, but the message still reads "open." Any help?
  • fedup1inmc Mar 31, 2008
    When I turn on the DVD Player, the screen indicates that the tray is OPEN which it is not. The DVD doesn't even at least spin anymore which, at least, it used to! I too would like to know if it is possible to clear this problem inside the player maybe. Tried calling Mintek Digital Inc in Anaheim CA and both 800 and local # are no longer in service. Gee I wonder why!
5 Suggested Answers
  • 3422 Answers
SOURCE: Mintek MDP-1760
MAY BE THERES A PROBLEM WITH YOUR POWER SUPLLY TRY TO GET A NEW POWER SUPPLY, IF THERES NOTHING HAPPEN MAY BE YOUR BOARD HAS THE DEFECT.
One of the minitek technician suggested this method you can try it out:
With the power turned off, open the lid and then open the hatch where you put the DVD into. Locate the laser lens and notice that the laser lens is attached to an assembly that moves diagonally outward in a slot. First, slide this assembly outward. Second, slide it back inward. Now repeat, slide out then back in. Next, put in a music CD and let it play all the way through. (This re-calibrates the laser head assembly movement.) When the music CD is done playing, put in a DVD, and amazingly, you'll have a working unit again.
Now coming to the disc reading problem you can call the toll free no.of minitek (866-709-9500)
they will help you fix this if the above method doesnot work..
Goodluck..
Posted on Feb 22, 2008
SOURCE: Mintek 10.2 MDP-1060
where can I buy a power cord for the car adapter for this product?
Posted on Mar 06, 2008
  • 1509 Answers
SOURCE: GMC Envoy 2004 XUV tailgate
Two things happen. One the latch is already latched and therefore it's closed before the gate shut, When you try to close it you might notice that the door don't close all the way. This doe'snt have to be thwe case. the other thing that happens if the lock mechanism is working, You here it click? The latch is stuck as the opener is stuck. You might get lucky and spray the latch with Blaster or other rust buster type penatrant. Theres angles though the opening of the latch . Spray on several angles and repleatly close the door trying to vibrate the Penatrant into the stuck area. Looking at the latch use a screw driver to move the latch and see if you can cycle it though it's positions to see if you can latch and unlatch it with the tool and reopen by pullung the handle ( you may need to try ther inside handle too and even the remote openner if you have one. Ussaaaly you need to push the button twice to open the rear hatch so it may take a few trys and spraying to get it to come loose.. Some vehicals stay closed a long time and stuck is the way to think.. But if the door is used often the linkage inside the door mayh have come off the the latch is closed and the linkage doesn't open the laTCH AND THE THING MANAGED TO GET CLOSED WITHT THE DOOR OPEN.
Posted on May 09, 2011
ercupa190
  • 12223 Answers
SOURCE: The DVD keep spinning but won't play
see the next steps and fix it. God bless you
Clean a DVD disc:
  1. Hold the disc by its central hub and outside edge.
  2. Blow dust from the bottom surface with a can of compressed air.
  3. Clean dirt and fingerprints from the bottom surface with a lint-free cloth dampened with CD/DVD-cleaning fluid or denatured alcohol, wiping from the center outward.
  4. Clean the objective lens:
  5. Remove the housing and lift the hold-down clamp to expose the lens.
  6. Remove dust with canned air or soft brush. If needed, use a foam swab or a camera-lens tissue dampened with lens fluid.
Posted on Oct 03, 2012
Portable DVD player won't recognize door is closed.
My guess would be that the switch inside that the tray hits to tell the dvd player it's closed is broken.
Aug 23, 2012 | Philips portable dvd player phillips...
It won't press the button even though the power is on
Since you don't indicate what you mean by "won't work", let me provide a few possibilities:
1) You close the door and you can hear the DVD spin, but no reaction on the screen other than some type of "loading" message. This indicates that the optics are attempting to read the DVD but are having difficulties. The operation may ultimately be successful and the DVD may start, but the movie will be unwatchable because of freezes etc. In this case, try cleaning the lens using a cotton swab and alcohol. A dirty lens can cause this.
2) You close the lid and do not hear the DVD spin. In this case, the optics can not even determine that a disc is in the machine. Again attempt to clean the lens. If that fails to at least cause the disc to spin, the optics have failed and need to be replaced.
3) Try a music CD. If that plays OK, but a DVD does not, then the optics are defective and need to be replaced. DVDs require a more powerful laser and will typically fail sooner than CD levels.
Hope this helps,
Dan
Jul 10, 2008 | Audiovox Televison & Video
WHY MY PORTABLE DVD WON'T PLAY
It won't play for one of two reasons:
1. There is something inside the DVD player, which keeps it from playing.
2. The DVD player's battery has run out of juice and can no longer play, meaning the player needs to be replaced.
Aug 06, 2012 | Curtis Sylvania SDVD7037 7-Inch Portable...
My Samsung DVD/VHS recorder the DVD won't close after playing DVD
Never force it, just use the remote.
If it won't stay in, unplug the unit and wait a while.
I think we get viruses from the TV signal which might be temporary (hopefully).
Apr 24, 2012 | Samsung DVD-VR330 VCR and DVD Recorder
Disney D7500PDD Portable DVD Player doesnt spin DVD
Very Good Daniel,
if you are good with a srewdriver.. you could use a DVD from a computer and swap it to disney
Does the door to DVD slides out or pop the lid.
You still can swap if you are careful and you know what you are doing
I've done a few times.
Let me know in the future, if you can't, you can send to me for repair
Jul 25, 2010 | Disney D7500PDD Portable DVD Player
Error code HO2 appears after inserting dvd panosonic NV-VP30EB
To my knowledge, most H02 errors on a Panasonic DVD player would indicate a spindle error, that is the central motor that spins the disc. Normally, this would require an in-shop repair as electronics is involved, however, you could still try:
  • close the tray with no disc inside;
  • press on the back skip, pause, and play buttons simultaneously and hold for about 4 seconds;
  • when the screen blanks and then "initializing" appears, release the buttons.
Alternately, you can try:
  • remove the top cover;
  • clean the spindle motor with compressed air;
  • manually turn the spindle counter clockwise and then clockwise numerous times to exercise the motor;
  • power on the player, insert a disc and manually assist the disc to start turning.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Sep 20, 2008 | Televison & Video
Not recognizing DVD player
i would say for some reason your dvd player is not compatible from now on with that brand of blank dvd!
get the firmware update from the brand website all you do is download the file burnit on a cd and put it in the dvd player should fix most and eventual problems
Jan 14, 2008 | Panasonic DMR-EH75VS DVD Recorder/VCR/HDD...
Koss KD365 DVD - Says No Disc
Make sure the disc is spinning. This might sound crazy but try turning the whole player upside down and see if it plays.
Jan 02, 2008 | Koss KD365 DVD Player
23HCV87 DVD problems
May be dirty lens get a cleaning disc for cd player and insert to clean then try player again. If you can take cover off insert disc see if disc spins,if not spinning you need a motor drive.
Nov 24, 2007 | NAD C320 2-Channel Amplifier
DVD player
Its posibal your dvd not rogins the informations is tiping of dvd
May 04, 2007 | Panasonic PV-DF2004 20 in. TV/VCR/DVD...
Mintek MDP-1815 Portable DVD Player Logo
47 people viewed this question
Top Mintek Televison & Video Experts
Jaime Hernandez
Are you a Mintek Televison and Video Expert? Answer questions, earn points and help others
