Question about Dynex Keyboard/Optical Mouse DX-CKB102
Dx-kbom2 keyboard wheni pu th c key a double cc is typed, when i i press m mh appears when i press v vg appears what is wrong with the keyboard?
  • 34 Answers
I don't know if this helps, but it sounds like something was spilled into the keyboard.  I have seen a lot of things like this, especially with the multiple keys hit off of 1 keypress.  Usually non-diet soda or coffee with sugar does wonders for the keyboard!
To try to see if we can get it working...if it is actually worth a lot of your time since you can get good keyboards for under $20, try the steps below.
1.  Turn keyboard upside down and shake vigorously.  I have seen everything, including paperclips, pencil leads, metal shavings, and staples inside keyboards.  Try to get everything you can out of there.
2.  Blow dust/dirt out with an aerosol duster.  Make sure to run the airstream along/around all the keys, not just the ones that are giving you problems.
3.  This one is for experts, but if you want to give it a whirl.  Use a partially opened paperclip to get under keycaps and lift them straight upwards from keyboard.  First do only the keys that are giving you problems.  Check in/around the contacts, or if microswitch keyboard, check that the little switch actually clicks when pressed.  If it is a capacitive keyboard, look for stains and such from spills.
I hope that this helps you out.  I would only go through steps 1&2 myself.  I abuse the hell out of keyboards, so I always have a couple of cheapies on the shelf waiting.  If you check WalMart or some of the other stores like that, you can find decent enough keyboards in the $5-$10 range.  With me, they all last about the same, about 6 months, before I have to replace them, regardless of the price I paid for it.  If it isn't going to last too long, cheaper is better!
Good luck,
Posted on Jan 07, 2009
The number keys to the right will not work, even after pressing number lock. suggestions?
Please open Device Manager and uninstall what is showing under "Keyboards". If you're unsure on how to perform these steps, follow this link:
Once you have uninstalled the keyboard driver, restart your notebook and it should automatically reinstall for you.
Let me know if this resolves the issue.
  • If the keyboard is not working in Windows, continue with these steps to uninstall and reinstall the keyboard software in Device Manager.
  • Click Start , then click Control Panel.
    Control Panel opens.
  • Click Hardware and Sound.
  • Click Device Manager under Devices and Printers.
    Device Manager opens.
  • Click View, and select Show Hidden Devices.
  • Double-click Keyboards, right-click the keyboard name, and then click the Uninstall button to remove the device from Windows.
  • Restart the computer.
  • The keyboard should now work correctly.
  • Your computer comes with several software programs that can test the keyboard for key or hardware failures. For more information, see the HP Support document Testing for Hardware Failures.
  • Notebook key presses are slow to respond
    If there is a short delay from the time a key is pressed to the time the character displays on the screen, the Filter Keys function might be activated. The Filter Keys function provides a greater range of key press options to fine-tune key delays and prevent inadvertent key presses. To disable Filter Keys and return to the default keyboard behavior, use the following steps:
    1. Click Start , and type keyboard in the Search box. Then select Change how your keyboard works under Control Panel.
    2. Remove the selection from Turn on Filter Keys. Then click Set up Filter Keys.
    3. Remove the check next to Turn on Filter Keys when SHIFT is pressed for eight seconds.
    4. Click Apply, click OK, and then close the Ease of Access Center.
      The keys should be more responsive.
    Pressing a notebook key once types several characters
    If two or more characters appear when pressing a key, use the following steps to adjust the key repeat delay:
    1. Click Start , and type keyboard in the Search box. Then click Keyboard under Control Panel.
      The Keyboard Properties page opens.
    2. Set the Repeat delay slider to Long. Click Apply, and then click OK.
    Notebook beeps while typing
    If the computer sometimes beeps while you are typing, Toggle Keys or Sticky Keys is active. Toggle Keys causes the computer to emit a beep when the Lock keys are pressed. Sticky Keys causes the computer to emit a beep when the Ctrl, Alt, Shift, or Lock key is pressed. Use the following steps to disable Sticky Keys and Toggle Keys:
    1. Click Start , and type keyboard in the Search box. Then click Change how your keyboard works under Control Panel.
    2. If selected, remove the check next to Turn on Sticky Keys. Then click Set up Sticky keys.
    3. Remove the check next to Turn on Sticky Keys when SHIFT is pressed five times.
    4. Click Apply, and then click OK to return to the Make the keyboard easier to use page.
    5. Remove the check next to Turn on Toggle Keys.
      If selected, remove the selection from Turn on Toggle Keys by holding down the NUM LOCK key for five seconds.
    6. Click Apply, click OK, and then close the Ease of Access Center.
      The beeps no longer sound.
    Wrong characters appear when typing, changing keyboard language, or Dvorak
    If the wrong characters appear when you are typing, or you are trying to use a different keyboard, use the following steps to synchronize Windows to the type of keyboard you are using:
    1. Click Start , and type region into the Search field. Click Region and Language from the search results.
    2. Click the Keyboards and Languages tab, and then click Change Keyboards.
      The Text Services and Input Languages page opens.
    3. Click Add.
    4. Select the keyboard you want to use, and click OK.
    5. From the Text Services and Input Languages page, select the new keyboard in the list and click Move up until it is first in the list. This makes it the default keyboard.
    6. Click OK. You can now use the new keyboard.
      If you find that the new keyboard service works correctly and you do not want to use the other keyboard, repeat these steps and Remove the keyboard service that you do not need.
    HP Notebook PCs Notebook Keyboard Troubleshooting Windows 7
    Aug 23, 2015 | HP Computers & Internet
    I dont know how to sync my wireless keyboard
    if its a wireless mouse and keyboard make sure the batteries are securely seated and fully charged the battery panel should be on the underside of your mouse keyboard as would be the on off switch
    click start control panel keyboard hardware make sure the right type of keyboard is selected
    click start control panel keyboard hardware troubleshoot or click start control panel administration tools computer management device manager scroll to keyboard you could see a yellow question/exclamation mark ? ! or red X a new driver will need to be installed
    right click to install drivers
    hope this helps
    Jun 29, 2012 | Computers & Internet
    Lost USB for DYNEX MODEL: DX-KBOM2 is there a compatible receiver?
    do you currently have a keyboard receiver
    not completely sure about a compatible receiver but if you are having trouble with your keyboard receiver
    had a look on Ebay they all look very expensive and you might need to buy the keyboard
    you could get this on Ebay if you dont have an account you will need to create one
    Add Email adress
    Add Bank Acc
    Add Credit Card
    also add your postal adress
    also add a paypal account
    when you get to the paypal login page at the bottom you will see new to paypal sign up tab
    paypal to create an account
    paypal registration password ,bank card /credit card,phone numbers home/mobile ,email adress and a postal adress
    be very specific when you type in the search
    always ask questions? before you make a purchase and keep the email/s for security reasons if the item arrives and its not as described
    you will even see the pictures of your item so you cant make a mistake and get them home delivered
    hope this helps you
    hope this helps
    Nov 11, 2011 | Dynex DX- KBOM2 Keyboard and Mouse
    Looking for operators manual
    Hi. You can find the manuals here
    Direct Download link to the PDF Files
    Mar 05, 2011 | Dynex DX- KBOM2 Keyboard and Mouse
    1.When I try to type @ symbol by pressing th **** and 2 keys, the symbol " comes up. @ comes up when **** and ' keys are pressed 2. Hash symbol does not come up when **** and 3 are punched, instead £...
    It sounds like you have another keyboard layout set as your default.
    In Control Panel, double click "Regional and Language Options". Click the Languages Tab and then the Details button. Make sure that English-US is selected as the Default Input Language.
    If another keyboard layout is listed below and you don't need it there, you can remove it to make sure it doesn't switch itself again.
    Note: this is for XP. Vista will be similar, but I don't have a vista machine so I can't tell you exactly what the options will be called.
    I hope this helps. Good Luck.
    Jun 10, 2009 | Dell Spacesaver USB Keyboard J4624 SK-8115...
    The keyboard characters does not correspond to what appears on sc
    Does it type " by any chance when you press the @ key? if so this is usually because keyboard input is set to the wrong language in the regional & language settings are wrong in the control panel. try pressing the left alt key & shift at same time first this is a quick key to change between input languages.
    Feb 27, 2009 | Dell Inspiron 500m Notebook
    Key stroke problem
    Go to Control Panel/Regional and Language Options/Languages/Details and make sure you have the following: English (United States)
    Everything else, remove it.
    Nov 01, 2008 | HP CPQ175KB Keyboard
    Keyboard problem
    Do the following steps:
    1. Press and Hold Fn then Press Numlock/Scroll lock, if it works then good.
    2. otherwise Press and Hold Shift Key then Press Numlock/Scroll lock.
    If still problem just Ask me
    Apr 12, 2008 | IBM ThinkPad T30 2366 Notebook
    Keyboard problem
    yaa its nothing wrong. You have enabled your key for Numlock.
    Hold Down Fn key (See bottom row, Left side of the keboard) and press Numlock key. Then your numlock will be off and Pressing K will type K.......etc.
    Please don't forget to rate this solution........ofcource Fixya
    Thanks for using fixya
    Mar 31, 2008 | Acer Aspire 5670 Notebook
    Computers & Internet Logo
    181 people viewed this question
    Top Dynex Computers & Internet Experts
    Prashant M
    Prashant M
    micky dee
    Are you a Dynex Computer and Internet Expert? Answer questions, earn points and help others
