Question about Seagate FreeAgent Pro - 500GB, 7200 RPM, USB 2.0, eSATA, External 500 GB Hard Drive
279GB free space in a Seagate 320GB will not take a 5GB pst file
I have a 320GB Seagate external hard drive. I have 279GB free space. Tried to drag and paste a 3 GB pst file for storage and it says that there is no space. Tried to defragment it - says I am not authorized.
a. how to use the free space
b. how to remove the authorization restriction.
This is my home computer.
Thanks.
YY
    Scholar:
  • 65 Answers
First of all HI :)
The main problem you have is that the file system of your hard drive is FAT32 not NTFS. You need to change it to NTFS in order to work. Here is how.
>> Copy all your data (the 50+GB you used) on to another hard drive
>> Now from My Computer
>> RIGHT CLICK
>> CHOOSE FORMAT
>> CHOOSE NTFS FILING SYSTEM
>> instead of FAT32 and
>> give your hard drive a nice full FORMAT
This will take a while and WARNING you will LOSE all your DATA so DOUBLE CHECK BEFORE YOU START THAT YOU COPIED EVERYTHING.
Hope that this Fixya Helps you :)
Best Regards
(please take some time to rate solution thanks)
Posted on Jan 07, 2009
Seagate Freeagent external Hard drive won't increase free space when files are deleted?
How are you deleting the files? If you're simply moving them to the trashcan/recycle bin then they're still taking space on your drive. Try emptying the trashcan/recycle bin.
Mar 21, 2013 | Seagate FreeAgent Computers & Internet
How do I get everything from my external hard drive onto my Mac and then completely clear the ehd?
The problem you really face is a lack of space on the Mac. The movement of files from the Seagate to the Mac is easy. Plug in the drive and open it, then select the items you want to transfer from the Seagate and drag them to the location on the Mac where you want to store them. Job Done. When the files have all been transferred you just need to "Format" the external drive.
May 09, 2012 | Seagate FreeAgent 2TB GoFlex Desktop USB...
My Seagate portable 320gb external hard drive fell on the floor now my computer and laptop don't see it( won't let me get in to the hard drive) , how do I fix this , Important files on it Help please
Since this external hard drive is USB powered and felt on the floor, you could have a broken USB connector or interface card, both located inside hard disk case, you should contact Seagate technical support or repair service, or if you have electronics skills, you could open and check hardware by yourself.
Feb 18, 2011 | Seagate 320GB Portable External Drive ...
If the Hard drive is 320gb then why does it show up on my computer as 298gb?
This is called file system over head. When you "format" a drive in Windows for example, the operating system uses a certain portion of the space for allocating the file system, Master File Table, and partition information. So, the 298 you see, is the formatted capacity. The larger the drive, the more "reserved space" is used. If you find this helpful, please leave positive feedback.
TechRx, Inc.
http://techrxgb.com
Aug 26, 2010 | Seagate FreeAgent Pro Desktop - 320GB -...
How to I reallocate my 500 gb external hard drive so I have more space for my laptop - I have 250+GB space avilable for my destop but I am getting "disk full" for the laptop.
you should be able to connect the external hard drive to your laptop and the drive should show up under my computer. Then just drag and drop or cut and paste any files you want to move to the external hard drive.
hope this helps.
May 21, 2010 | Seagate FreeAgent Go 250 GB USB 2.0 Hard...
My seagate freeagent go (320gb) is not recognised by my pc (XP), also, when connect the My Computer function doesn't work, it just opens a window and freezes and doesn't display the drives. All my music is...
try reading it in slax linux, mite get some of the data, i got same thing, tried in another shell, no dice, slax can read it for a bit and then gets stuck, i unmount it then mount again, works a little , gets stuck, etc
i booted off usb stick , slax has 200 mb tar file unzip to usb and run bat that makes it bootable
Jan 20, 2010 | Seagate FreeAgent Go 250 GB USB 2.0 Hard...
Problem removing write protect from seagate free agent drive
The problem is because Mac cannot write to NTFS formatted drives. You will have to reformat the drive in Mac. You will loose all the data :( Here is a link for the how to:
http://seagate.custkb.com/seagate/crm/selfservice/search.jsp?DocId=174395
Jan 24, 2009 | Seagate FreeAgent Pro Desktop - 320GB -...
Seagate 320GB will not accept a 5GB file despite ample space
First of all HI :)
I posted this on your other thead as well but for some reason it is not getting through. The main problem you have is that the file system of your hard drive is FAT32 not NTFS. You need to change it to NTFS in order to work. Here is how.
>> RIGHT CLICK
>> CHOOSE FORMAT
Hope that this Fixya Helps you :) With reference to the you do not have permission message it means that you are not logged in as administrator. Best solution is to clean it up on a computer on which you are the administrator to make full use of it.
Best Regards
Jan 07, 2009 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
How to transfer files to a hard drive
if they are on the drive... drag and drop them to the spare drive... for downloads you can choose where you want a file to download
Jan 03, 2009 | Iomega Silver Series 320GB 3.5 External -...
Free agent desktop
installed a new 500 seagate now the computer says "no hard drive found" any suggestions? thanks
Feb 07, 2008 | Seagate FreeAgent Pro Desktop - 320GB -...
Seagate FreeAgent Pro - 500GB, 7200 RPM, USB 2.0, eSATA, External 500 GB Hard Drive Logo
171 people viewed this question
Top Seagate Computers & Internet Experts
Brian Sullivan
Brian Sullivan
Terry Allen
Terry Allen
Mark Taylor
Mark Taylor
Are you a Seagate Computer and Internet Expert? Answer questions, earn points and help others
