Question about Quinny ZAPP Stroller
Tihten up loose parts
How do I tighten up the bar across the middle of the handles,as mine is slightly collapsing in the middle?
  • dclarky Mar 03, 2008
    my bar has snapped any ideas how to get a new one???? email at dloughlanuk@yahoo.com
  • Marianne Leverington
    Marianne Leverington May 11, 2008
    my quinny zapp is a year old but i have only used the maxi car seat and the middle bar between the handles is weak and the whole frame is making alot of noise. any solutions
Pull the bar towards you until the two joints click into place
Posted on Jul 30, 2007
How to tighten loose handles on the 2 handle Delta Vessona kitchen faucet model #21925LF
usually have a setscrew in them!! mine are allen heads very small
Feb 11, 2015 | Delta Plumbing
After you install bar,chain,and brake cover(tightened)the chain wont turn.
Tighten the adjusting screw with the two nuts loose but snugon the middle of the chain on the top of the bar. Tighten the chain screw until the chain is loose enough to raise the chain up about 1/2 inch then tighten the mounting nuts tight. Then see if it is ok.
Terry
Jan 07, 2015 | Husqvarna 338xpt 14" Gas Chain Saw Husky...
GE dishwasher model GLD5868V15SS handle loose
This model comes with two types of doors. One with a single panel with integrated control on top or a two part door with control unit in front. The handle varies.
If you have a single door panel with handle bar across from right to left then you need to carefully unscrew the back panel screws and free up the front panel. the handle is screwed to the front panel from inside. Once you tighten carefully put the back door panel in and tighten. Take photos along the way to make sure you get back where you started. Also unplug dishwasher before working on it.
If you have a two part door with front control then handle and access to it is different. See diagram on this website for blow up of the panel and location of handle (part 713).
ESCUTCHEON DOOR ASSEMBLY Diagram Parts List for Model GLD5868V15SS GE...
You can magnify the image or take a full screen view for clarity.
Aug 29, 2014 | Dishwashers
Handlebars won't stay upright
The part that holds the handle bars on is called the Head-set this should have adjustment screw/screws they may have a small plastic cover over them to prevent rust. They are usually require an Allen wrench to tighten them. If they become loose again then get some locktight and use this on the handle bars and the threads of the bolts before you tighten them up.
Oct 31, 2013 | Specialized Crossroads
Handle bar cable
The same has just happened to mine, I've tried to contact icandy but no success !! Have you managed to fix yours yet?
Apr 26, 2013 | iCandy Peach Stroller
What is causing the chain to loosen after little use?
Two things. 1 Make sure the adjustment pin is up against the slot in the bar and 2 Make sure the bare is getting oil. The oil lubricates the chain and cools it down, as the chain cuts it heats up causing the chain to stretch.
Aug 28, 2012 | Homelite Garden
The handle bar on our mutsy is wobbly, have tried to tighten screws on the top of bar but makes no difference. Please help!
The harware on the top of the handle bar are rivets, there is no way to really tighten these. It is possible that there is a broken mechanism in the handle bar causing it be loose. The only solution for that is replacing the handle bar. If you need assistance getting a replacement part please email me directily at monica@kastelinternational.com
Jul 17, 2011 | Mutsy 4 Rider Single Spoke Stroller with...
Right hand handle bar has slight movement
Are the forks bent in any way? slight dents will cause bars to not tighten as will over tightening the allens on the bars. Remove the allen clamps that go around the fork and check for damage. If you need to remove be careful as to how you remove throddle cable and grip. Allens or screws and label. Then you can raise the bar over the end of fork. My bet would be a striped tread or dent and not the drop bar.
Mar 29, 2010 | 2006 kawasaki ZX-6R
Tricycle loose handle bars.
You need to install a shim so the bolt has more to clamp on. To do this, loosen the bolt you have been tightening enough that you can pull the handlebars out, then about 3 or 4 more turns. Get an empty soda can and with a pair of scissors, stab into the side of the can near the bottom and cut off the bottom end. Then cut about 2 inches up and cut around the can so you have a roughly 2 by 5 inch strip of aluminum. This is your shim (you may have to trim some length if it doesn't fit). Wrap it around the bottom part of the handlebars where it will go back into the part where the bolt is. Make sure you wrap it tight or it will be hard to put in. Slide the handle bar with the shim on it back into the other tube and tighten the bolt. The end.
Jul 13, 2009 | Huffy Cycling
Amana, model # AFD2535DES, bottom drawer freezer handle loose
sure , if you look underthe handle is there perahps a small screwhole in which you can tighten handle??this may be prior year in which case if there are no screw holes present you need to grab hold of handle and with a "brisk" pull to the right it will come off hiddenclips, the clips can be t ightened and resecure by snapping back the oppisite way the handle pullled off
Feb 12, 2009 | Amana AFD2535DES French Door Refrigerator
Quinny ZAPP Stroller Logo
323 people viewed this question
Top Quinny Baby Gear Experts
Jennifer Rock
Jennifer Rock
Oloyede Monsuru
ray gallant
Are you a Quinny Baby Gear Expert? Answer questions, earn points and help others
