Unable to turn on receiver,marantz sr8002
Fast blinking standby red light
  • 1,199 Answers
First unplug check all consctions in the back of the unit and make sure none of the wires are touching together or touching any metal in back of unit! (speaker wires crossed is the main cause of thie) If this does not fix it it will have to be serviced by a pro!
Hope this does it for you!
Please rate my responce to your question.
Thank you!
Posted on Jan 07, 2009
SOURCE: Blinking Standby
just hold down the enter key and advanced surround key and it should reset!
Posted on Aug 06, 2007
  • 67 Answers
SOURCE: Marantz SR6001 AV Surround Receiver - Blinking Standy Light
This unit went into protect either due to overcurrent or dc detect. There is no way to disable protection that Marantz or Authorized servicers are allowed to give out. The early versions of this model all you had to do was unplug for a few minutes then plug back in and unit if it did not have blown amp unit would powerup and work fine. But if amp had failure it may cause more parts to fail so they changed software to not allow users ability to disable protection. Send to Marantz Authorized servicer for them to check for amp failure or mayby they just have to disable Protect Mode.
Posted on Feb 16, 2008
  • 1114 Answers
SOURCE: marantz SR8001fail to standby mode, will not reset
Test all your speaker impedances and check for shorts on both wiring and speakers. Use a digital multimeter. If you still have an issue, disconnect all speakers and test receiver. If you still have a problem, post a comment and I can help some more.
Posted on Aug 09, 2009
SOURCE: red light blinks and it shuts off after starting
I had the exactsame problem. I took it to an authorized repair place in Houston and they quickly diagnosed it and replaced the power supply.
Posted on Sep 18, 2009
I have a SR7001 with that problem. I found 2 shorted amp NPN & PNP transistors. Part #'s SAP17NY & SAP17PY.
Posted on Feb 08, 2011
All of a sudden stopped working and won't turn back on. been 12hrs. when power is pressed, it turns on for 2 seconds and then standby lights blink again and it turns off
This could be caused by a direct short circuit on the speaker outputs. Try disconnecting all the speaker connections at the back of the receiver and then power back on. You can also try a factory reset by holding the surround mode + clear button for 3 seconds.
Feb 14, 2016 | Marantz SR7005 Receiver
My sr5004 marantz receiver has gone into standby with the indicator is blinking how do i get ride of it
If the red led is blinking fast (8x/second) the power supply is likely damaged and the unit will need to be serviced. If blinking slow, the most likely cause would be a shorted speaker connection. To help find the cause, unplug everything including the power and speakers. Connect only the power and try to turn the unit on. If the light doesn't blink, you know you have a shorted connection. Power off and connect the inputs and then power back on. If the light is not blinking, you know the problem is with an output connection. Just find the bad connection by process of elimination.
Sep 27, 2014 | Marantz SR5004
What can i do to stop the red light blinking for marantz sr5007?
Turn off the power using X.
2 Press X ON/STANDBY while simultaneously pressing PRESET CH + and PRESET
CH -.
3 Once the display starts flashing at intervals of about 1 second, release the two
Aug 09, 2014 | Marantz SR5007 Home Theater AV Receiver
Marantz SR-7200 volume -29dB blinking
Check Speaker connections at BOTH ends and double check to see that they are on the right terminals.
If you need a manual . the Marantz site will have one . PLus they may have FAQ notes for that receiver
Mar 01, 2014 | Marantz SR-7200 Receiver
Marantz sr5600 reciever click and goes to blinking standby
I have the same problem. Earlier it got sorted out itself and now it has started coming up again.
Feb 26, 2012 | Marantz SR-5600 Receiver
The power light blinks red! it can't turn On!
"If your 8002/7002 goes into protective mode (red power light flashing at two times per second) the receiver will not operate until it is reset. First try the reset procedure on the bottom right corner of page 81 in the manual.
If that doesn't work, press and hold the following three buttons on the front panel until the unit resets:
Pure Direct
7.1 Ch input
This latter procedure is not in the manual and I can't fathom why, as it can save the inconvenience of a trip to the service center."
Feb 03, 2011 | Marantz SR8002 7.1 Channels Receiver
SR5004 amp on standby mode (red light blinking twice a second) / cant get it out of stand by mode
I am having the same issue as well. If you press "clear" "exit" and "surround mode" all at the same time, it will come back on. It seems to be an overheating issue. If you put a fan on it, it helps, but does not fix permanently. Anyone have any ideas for a permanent fix?
Sep 20, 2010 | Marantz SR5001
Marantz sr8001: standby light blinks rapidly,
Hello there Ed.
For anyone that has ever had such an issue with a MARANTZ SR series (6001. 7001. 7002. 8001...etc...) issue a question and I do HAVE the answer.
I could be just anything, or just the low quality binding posts used by MARANTZ for that.
Please describe to me in details how you've connected your speaker wires at the back, and give me description when and how did this problem came up.
Kind regards
Oct 17, 2009 | Marantz SR8001
Goes to standby with fast blinking red light after 5 seconds
From my experience you need to replace the Hi power module
Sep 11, 2009 | Denon AVR-1905 Receiver
For resetting sr6001: When power lights blinking, press "clear" + "pure direct" + "7.1 ch input" simultaneously for 3 seconds.
Nov 10, 2008 | Marantz SR-7200 Receiver
1,123 people viewed this question
