Question about Refrigerators
Freezer compartment gets hot
I noticed the bottom ( inside) of my freezer ( i have a side by side kenmore) gets hot and actually it looks like a coil is glowing red. Is this dangerous? Is this normal?
  • 115 Answers
That is very much normal that is the defrost heater glowwing it is ok please rate!
Posted on Jan 07, 2009
I have a Kenmore Elite side by side refrigerator, the problem is the unit is not cooling at the top area of both the freezer and refrierator? the bottom areas are OK, I notice there is no air flow in the...
Is your fan inside the freezer compartment back wall towards the bottom is working. (Evaporator fan motor) ?
No fan... No circulation.
Fan may have failed or another common thing is failed defrost system has clogged up the evaporator coil and fan blade with frost. In this latter case, you will see white frost build up in the freezer back wall towards the bottom in freezer compartment.
Better call a local service technician. Little bit technical and hands on job.
Oct 23, 2017 | Kenmore Refrigerators
Condensate drain inside of freezer compartment keeps filling up and freezing and then overflows to bottom of freezer compartment and freezes. Have made sure drain line is clear. Problem occurs about every...
The drain in the freezer behind back lower panel
needs opening. You can see it at the bottom of the back panel
underneath the evaporator coils. (The cold coils)
Run Hot water in the drain until it clears or use a hairdryer.
When the defrost melts the water it goes down the drain
If the drain is clogged with Ice or ? The defrost water
overflows into the ref. or freezer or on floor
Also check fan undernearh Ref in the rear
Clean condenser coils underneath
.I'm including my article on Refrigerator Repair for your help and convenience.;
Please click or copy and paste into browser for Article
http://www.fixya.com/support/r5816737-fix_refrigerator_psychologically
If you need more help GO HERE:
http://www.applianceaid.com/procedures.html
Thanks for using fixya
Leo Ponder
imufo2
Please VOTE FOR ME IF THIS WAS HELPFUL
Sep 22, 2011 | Kenmore Side by Side Refrigerator
GE side by side refrigerator GSHF5KGXECWW MS
Ok.. Just a bit of info for you if you have to sometime in the future do a parts search. This unit is the same as the Hotpoint HSS25GFTWW
Now for the icemaker problem.
When ice makers start making less ice it is usually a sign of some other problem.
1. Ice build up on the evaporator coils in the back of the freezer.
2. A slow or not functioning evaporator fan.
3. Dirty condensor coils in the back or the unit
4. A condensor fan that is running slow or not turning.
5. An automatic defrosting problem (most common problem)
If you have ice cream you probably notice that it is softer than usual. Or things in the freezer just are not as stiff as they usually are. When you notice this the freezer is warming up but the fresh food compartment is fine.
1st.. check to make sure the control panel settings are set to "0" for the freezer and "37" for the fresh food compartment.
2nd.. look for any obvious signs of ling build up in the bottom and back of the unit.
3rd .. Listen to the evaporator fan in the freezer compartment.
a. must be running full speed
b. should not sound like it is striking anything
4th.. Is the chassis near the doors hot to the touch? (should be warm not hot)
a. if hot to the touch the condensor is not getting rid of the heat due to lint build up, or slow / stuck / failed condensor fan.
5th.. there is always the very rare chance that there is an actual problem in the ice maker. (thermostat)
Parts reference: http://www.appliancepartspros.com/partsearch/model.aspx?model_id=5203104&diagram_id=24933028#d24933028
Thanks for using FixYa.
Kelly
Jun 18, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
New fridge freezer isgetting very hot on both
This heat is normal. The refrigerator you have in your kitchen will have the condenser coils which get very hot on the bottom or back of the frig. A deep freeze has the condenser coils inside the walls of the freezer. Hot temps are normal when it is running.
Try to leave an inch or so of space around it for air flow and that will help.
Apr 24, 2010 | Kenmore 14.8 cu. ft. / 419 liter Chest...
MY FREEZE DOES NOT FREEZ BUT IS COOLD DOES IT NEEDS GAS
When the compressor is running, two fans should be running. One inside the freezer compartment that moves air over the evaporator coils. The other is under/behind the fridge that cools the condenser coils.
If the fan on the condenser coil (the one under/behind the fridge) stops working, the system cannot dissipate the heat from those coils, and thus cannot sufficiently cool the inside of either the freezer nor fresh food compartment.
On mine, when the condenser fan failed, I noticed right away. The front face of the wall separating the compartments became very hot. Extremely hot.
Apparently the refrigeration system is designed so that waste heat keeps condensation from forming where the magnetic gaskets on the door need to seal. When the condenser fan failed, there was too much waste heat (because no heat was being dissipated from the condenser coils by the fan), thus making that gasket-sealing area very hot.
If it is your condenser coil fan, you can relieve the problem temporarily by removing the bottom back panel from the fridge and aiming a box fan (a regular room or window fan) at the condenser coils. This will circulate air over the coils, thus removing heat from the coils.
Jul 29, 2009 | GE GSH25JFR Side by Side Refrigerator
Kenmore refrigerator problem
It sounds like you have a plugged defrost drain line. This is where the water goes to in the bottom of your freezer when it goes through the defrost (removal of ice from the freezer coil) cycle. It sounds like that hole is plugged and now the water/ice has now frozen in the vent that lets air circulate down into your refrigerator compartment. What I usually do in this case is to unplug the refrigerator, empty out the freezer compartment. Usually I also end up either pulling off the back panel or the bottom panel (in the freezer compartment) Looking for that defrost drain hole and actually I use a hair dryer. I can sometimes do this also by pouring small amounts of HOT tap water onto it and then sopping/absorbing it away with a sponge or dishcloth. I repeat this until I get the water to go down the drain tube. Do this and all will be back to normal..
Regards,
Sai.
Jun 12, 2008 | Kenmore Refrigerators
Fridge not working but freezer does
It sounds like you have a plugged defrost drain line. This is where the water goes to in the bottom of your freezer when it goes through the defrost (removal of ice from the freezer coil) cycle. It sounds like that hole is plugged and now the water/ice has now frozen in the vent that lets air circulate down into your refrigerator compartment. What I usually do in this case is to unplug the refrigerator, empty out the freezer compartment. Usually I also end up either pulling off the back panel or the bottom panel (in the freezer compartment) Looking for that defrost drain hole and thawing it out with a heat gun (be careful of melting plastic) or actually I use a hair dryer. I can sometimes do this also by pouring small amounts of HOT tap water onto it and then sopping/absorbing it away with a sponge or dishcloth. I repeat this until I get the water to go down the drain tube
Mar 26, 2008 | Kenmore 44103 Side by Side Refrigerator
Kenmore 5842 side by side crapped out - approx. 9 years old - garage fridge
I can offer a suggestion. It sounds like you have a plugged defrost drain line. This is where the water goes to in the bottom of your freezer when it goes through the defrost (removal of ice from the freezer coil) cycle. It sounds like that hole is plugged and now the water/ice has now frozen in the vent that lets air circulate down into your refrigerator compartment. What I usually do in this case is to unplug the refrigerator, empty out the freezer compartment. Usually I also end up either pulling off the back panel or the bottom panel (in the freezer compartment) Looking for that defrost drain hole and thawing it out with a heat gun (be careful of melting plastic) or actually I use a hair dryer. I can sometimes do this also by pouring small amounts of HOT tap water onto it and then sopping/absorbing it away with a sponge or dishcloth. I repeat this until I get the water to go down the drain tube
Mar 12, 2008 | Kenmore 58422 / 58429
Kenmore 50222000 help me please
Oct 19, 2007 | Kenmore 50522 / 50524 Side by Side...
Refrigerator freezes up
PLEASE DISREGUARD GUEST FIXYA SOLUTION,FREEZER PROBLEM PROCEDURE IF NOT DEGITAL,FIRST CHECK IF ICE ON BACK FREEZER WALL. STEPS-FIND DEFROST TIMER,BOTTOM FRONT ,BOTTOM BACK, INSIDE FRIG.ON CONSOLE,LISTEN TO SEE IF FAN IS RUNNING IF SO TURN THE DEFROST TIMER CLOCKWISE TILL YOU HEAR A CLICK SEE IF FAN TURNED OFF IF SO YOUR FREEZER IS IN DEFROST,FREEZER WILL COME OUT OF DEFROST IN 20-30 MINUTES IF IT DOES AND THE FAN COMES ON YOU HAVE ELIMINATED DEFROST TIMER&FAN,NEXT REMOVE BACK PANEL TO FREEZER IF THERE IS ICE FORMING REMOVE BOTH LEADS TO HEAT AND CHECK WITH VOLT METER ON OMES,IF YOU GET ANY READING THE HEATER IS GOOD,IF NO READING REPLACE HEATER AND CLIPON TEMINATOR,IF HEATER IS GOOD DEFROST COILS WITH HAIR DRYER TOP TO BOTTOM AND THIS WILL ALSO CLEAR THE DRAIN,IF EVERYTHING CHECK OUT GOOD DEFROST TIMER ,FAN ,HEATER, DRAIN, YOU NEED ONLY TO REPLACE THE LITTLE ROUND CLIP ON TERMANATOR,LET ME KNOW-MIKE
Oct 13, 2007 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Refrigerators Logo
175 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
