Question about Taylor 7321 400 Pound Lithium Scale
Our taylor scale is saying err when we step on. it isn't that old does it need new battery already it clear with the chrome and goes to 400 or 450 # i think
  • 74 Answers
This link provides a place to ask the company troubleshooting questions...I hope this helps.
http://www.taylorusa.com/advantage/root/contact.html
Posted on Jan 07, 2009
When you get onto the scale (Taylor Lithium 7506), the numbers just keep cycling and never stop. We tried changing the battery, even though the scale is less than three months old, but it still does the...
Turn it over - take out battery and check with multimeter to ensure it is still workable - let sit for 10 to 15 seconds - replace battery - set it on level surface and step on and back off. Step on it again and it should now work.
Sep 16, 2011 | Taylor 7506 Precision Tech Lithium Battery...
I have a Taylor Led scale #9876B ...I purchased maybe 2 mo ago , This is my 2nd one . The first one stopped reading my weight , and will say err. so I took it back , got a new one same kind , now this one...
I have the 9876 also. After 2-3 yrs it quit. W/ new battery it does the walking o's, then ERR1. I opened it and found that it uses a strain gauge, read by an MCU. The wires leading to the strain gauge were crushed between the top of the gauge and the plastic top cover. If I wiggle the wires I get a reading , but inaccurate. Then when they lose connection, there's no reading. Considering the slop in the metal links to the strain gauge, I don't consider it repairable.
Mar 29, 2011 | Taylor Health & Beauty
The taylor lithium electronic scale says 00 and then ERR. there is no ERR2. should i change the batteries? it never said lo.
If you get an "Err" or "Error" message, you will need to step off of the scale, wait a few seconds and then step back onto the scale.
Aug 10, 2010 | Taylor & Digital Scale Lithium Scale
How can I fix the Taylor LIthium Scale?
take it to were you got it or instuctions show u
Feb 09, 2010 | Taylor "TAYLOR" 73304072 LITHIUM BATH...
I have a Taylor body fat analyzer and scale model #5563 that keeps showing Err 2. It won't read any weight whatsoever... it just goes stratight to the Error message. Do you know what that means and how I...
From the Taylor Site http://www.taylorusa.com/faq-scales
Here are the basic ERR messages and their meanings:
  • Error 0: Initialization
  • Error 1: Instability (scale is on an uneven surface ex: carpet)
  • Error 2: Unit may have been jarred or unit was overloaded (customer went over the maximum weight capacity)
  • Error 3: Contact error (Feet were not wet for Body fat reading, feet aren’t big enough to reach sensors)
  • Error 4: Body fat is out of range
  • Error 5: Water is out of range
I got an ERR2 message and now the scale doesn’t work. What should I do? The following reset procedure is used when the scale shows an err2, err, 0.0, inaccurate weight, or some other unusual error.
  1. Remove the battery from the scale.
  2. Sit the scale on a hard surface floor.
  3. Step up onto the scale, stand still for about 5 seconds and step off the scale.
  4. Re-install your battery.
  5. Place the scale back on a hard surface floor.
  6. With one foot only, place just enough weight on the scale for the display shows zero’s or dashes. Once you see zeros or dashes remove your foot.
  7. Wait for the scale to turn off again.
  8. Step up onto the scale for a weight.
If the reset is successful, you should receive a weight right away. If you continue to receive one of the error messages above please call our Customer Service department or contact us via email. You can also try the reset procedure a 2nd time. Sometimes the reset procedure will work the second time.
Jan 15, 2010 | Health & Beauty
How to calibrate a taylor scale 5571
The following reset procedure is used when the scale shows an err2, err, 0.0, inaccurate weight,to calibrate, or some other unusual error.
If the reset is successful, you should receive a weight right away. If you continue to receive one of the error messages above please call our Customer Service department.You can also try the reset procedure a 2nd time. Sometimes the reset procedure will work the second time.
Jun 13, 2009 | Taylor Body Fat Analyzer & Scale, Model...
Err 1 message on Taylor Lithium Elec Scale model 7346
This is a reply I received from Taylor customer support. I have followed this procedure enough times to wear out the original battery and still get the Err 1 message. You may have better luck.
Thank you for your e-mail. The reboot below may clear the error from
your scale. You may need to do this several times to completely reboot
the system. Please let us know if you have any questions or continue to
display the Error.
2. Set the scale on the floor without the battery in place.
3. Stand on the scale for 10 seconds (still without the battery)
4. Carefully replace the battery without turning the scale on.
5. Using only one foot, tap the scale or apply just enough pressure to
turn on the display. (It should show dashes or zero's) IMMEDIATELY
REMOVE YOUR FOOT.
6. Let the scale turn off
7. Step on the scale for a weight reading
Regards,
Linda DLT
Consumer Relations
Taylor Precision Products
& Salter Housewares
2220 Entrada del Sol, Suite A
Las Cruces, NM 88001
Toll free - 800-289-0944
866-843-3905
Direct - 575-526-0944 ext 3172
Feb 11, 2009 | Taylor & Digital Scale Lithium Scale
Taylor Scale 7532s - not working
This link allows you to trouble shoot directly with the company....I hope this helps.
Dec 19, 2008 | Taylor 7532 Ultra Thin Glass Digital Scale
Taylor Lithium Scale Model 7000
This link allows you to trouble shoot directly with the company... I hope this helps. http://www.taylorusa.com/advantage/root/contact.html
Oct 29, 2008 | Taylor Chrome & Glass Lithium Digital...
Taylor 7321 400 Pound Lithium Scale Logo
238 people viewed this question
Top Taylor Health & Beauty Experts
Ankit Chandel
Ankit Chandel
Are you a Taylor Health and Beauty Expert? Answer questions, earn points and help others
