Question about Kenmore 96212 / 96214 / 96219 Electric Kitchen Range
Element does doesn't switch off.
The element on my ceramic top Kenmore sometimes stays on even though the control has been turned off.
  • pasiemens Jan 10, 2009
    I'll try this, thanks for the help.
  • 318 Answers
By staying on do you mean the "hot" light stays on or do you mean the burner is still glowing red when you shut the switch off?
if it is just the hot light then the sensor on the burner has failed and will need to replace the entire burner and sensor, comes together as one piece.
if it is still glowing then you will have a stuck contact in the selector switch and that switch should be replaced.
Posted on Jan 07, 2009
    Scholar:
  • 58 Answers
What your going to have to do is replace the infinate control for that burner. ( thats the control you turn to sw it from high to low heat )
good luck
Kenmore oven C880 676239J2 is not heating up... is the only fuse the one located under the light on top of the control panel?
I doubt that fuse is used for the heating element. If you can unplug the element in the oven, an ohmmeter should show you if it has opened up (burned out) on you. Turn off the 220 breaker in the breaker box before doing this even though there should be no voltage with the controls turned off. (There usually will still be 110 to the top of the unit.)
Jun 05, 2017 | Kenmore Microwave Ovens
Kenmore 11086180100 heating element stays on even when dryer is off
The control relay is bad. Internal contacts are most likely welded together. Replace the relay.
Oct 22, 2016 | Kenmore Dryers
Ceramic stove top large element on high and won't shut off until turned all the way off
The range surface burner control switch, that the knob is attached to, needs to be replaced. The link is an example, as I don't know the model. They are mostly similar between manufacturers.
Range Surface Element Infinite Switch Part Number 3148952 SAME DAY SHIP...
Feb 03, 2016 | Frigidaire Kitchen Ranges
Hi there Have recently moved into a house with a Belling 626 white, electric cooker and the grill doesn't seem to be working. It has a mian oven, top ovem and "dual grill". The main oven...
ISOLATE THE MAINS POWER BEFORE CHECKING THE APPLIANCE
Run your fingers along the grill element, in this model it is accessible, check for raised areas or small hole or roughness not food burnt, if visible, it should be Black Grey colour at the blemish, you can obtain parts from www.whitegoods.co.uk you will need the model and serial numbers.
The grill elements come out but when unsrewed sometimes the ceramic holders crack, remove element before ordering as you may have to replace the element holders.
Hope this has been helpful
john
May 31, 2011 | Belling Ovens
I have a Kenmore electric ceramic top range. While
We provide free diagnostic information when you tell us what brand and model number you are having issues with.
We are available from 7 AM – 7 PM CST. We also provide part removal/installation instructions for our customers when parts are purchased through us.
It is our goal to get you back up and running again ASAP, so please contact us when you need us to help you.
We look forward to hearing you and hope that you have a terrific day. Thank you, Ella
http://www.fixya.com/repair/d499389-accurate_appliance_repair_service
Mar 10, 2010 | Kenmore 95002 / 95004 Electric Kitchen...
Kenmore electric stove with glass/cermanic top. Element on light indictor light stays on all the time even though no burners have been turned on for 5 hours. None of the burners are hot when you run your...
Tony, this sounds like you may need to have a new burner switch installed, it is called an infinite switch. If it is for the dual burner, make sure you tell the appliance parts store this so they can order you a dual infinite switch.
Nov 08, 2009 | Kenmore Ovens
Ceramic top temperature control
This would be a faulty switch. Hope this helps!
Mar 08, 2009 | Whirlpool GR465LXLS Electric Kitchen Range
The inner right front element will not heat up on our Kenmore Elite ceramic stove top. The middle and outer elements on the right front work fine. Why is this happening?
inner element burned out. Either burner needs replacing or control switch is bad. Take out burner and see if coil has a break in it. IF not, then switch is bad. I cannot see your repyl due to some tech issue w/ the site, so it may be a day or so before I can reply again. Please leave feedback for me if appropriate. Thanks
Nov 28, 2008 | Kenmore Kitchen Ranges
Frigidaire ceramic top self cleaning stove
Have you thought about reading the manual, it states that the heat goes off and on to maintain the proper heat while cooking, You should turn the burner off a few minutes before done because even on off the burner is still cooking while it is cooling down to go off. And you do not need to have as high of heat to cook that's what so great about this ceramic tops you save time and energy.
Jun 26, 2008 | Kitchen Ranges
Kenmore 96212 / 96214 / 96219 Electric Kitchen Range Logo
350 people viewed this question
Top Kenmore Kitchen Ranges Experts
Dan Webster
Dan Webster
Sal De
Are you a Kenmore Kitchen Range Expert? Answer questions, earn points and help others
