Question about PfaFF Tiptronic 2040
HELP--how to wind bobbin on pfaff 1469
I have no owners manual. I can get the bobbin to wind but the thread is not nice and tight on the bobbin. I don't think I am threading it correctly before winding, since I don't a picture to follow. Please advise how to thread to wind the bobbin. A step by step to follow would be nice. HELP please.
SOURCE: sewing machine has bobbin thread would around winding shaft
If the bobbin is on correctly try crossing the thread before going through the tensioner which should solve this problem and also a more evenly wound bobbin.
Posted on Dec 17, 2008
  • 201 Answers
SOURCE: the bobbin
You need to turn the wheel inside the handwheel to wind a bobbin. You will feel it "release". (I think you turn it towards you - can't remember, sorry!) Don't forget to turn it back when you are done.
Posted on Dec 22, 2007
bilabon
  • 46 Answers
SOURCE: How to thread upper bobbin on Kenmore 11206
WAY OLD BUT .....slide the bobbin spindle from the left to the right and pull the handwheel out. YOU NEED TO DO BOTH. I never saw this til today hope its not too late!
Bonnie
Posted on Nov 06, 2008
  • 10 Answers
SOURCE: Automatic bobbin winder does not stop when bobbin is full
Simply loosen the screw on the bobbin winder stop, no more than 1 full turn or you will drop the backing nut will fall down into your machine, move the bobbin winder stop slightly to the left then tighten the screw and see if that works. you may have to repeat this step several times until you find the right spot to stop the bobbin at the correct point.
Posted on Jun 30, 2009
  • 2973 Answers
SOURCE: Pfaff sewing machine 1469.
It is not that the thread is not being picked, it is just that the tension of both the top and bottom threads is not equal. That is why the thread at the bottom gets collected because the lower thread is loose compared to the top one. Loosen the top thread by unscrewing the thread tightner a little at a time. The problem will be sorted out when tension get equal or near equal.
Posted on Nov 30, 2009
What is the value of a Pfaff, Creative 1469, please. Thanks.
Depends on a lot of things including the visual and physical condition of the machine, its features, how it's been maintained over the years, the accessories included, the desirability of the machine, and location of the machine. Best way to find out is check with a sewing repair shop or search for machines for sale or recently sold on the internet, ie eBay...
Thread Should buy used Pfaff creative 1469
Pfaff 1469 Sewing Machine review by pinjumper
Pfaff 1469 sewing discussion topic PatternReview com
Jan 15, 2017 | Sewing Machines
HOW DO YOU WIND A BOBBIN ON A PFAFF 2022 SEWING MACHINE
Bobbin winding
1. Place the thread spool on the spool pin in
against the spool.
back to front. Pull the thread clockwise around
the inside to the outside.
4. Place an empty bobbin on the bobbin spindle.
5. Push the bobbin lever to the right to wind.
A pop-up appears on the screen to inform
you that bobbin winding is on. Press the
foot control or the start/stop button to start
winding the bobbin.
When the bobbin is full, the bobbin winding
will slow down and stop automatically. The
pop-up closes. Remove the bobbin and cut the thread
Sep 14, 2016 | PfaFF Sewing Machines
How to thread bobbin 451 Pfaff
Having difficulty even locating a photo of the 451. Assuming this is an older model, perhaps this manual will help. It says its also for the 551, so perhaps the model is close enough that it will help you with your machine:
Pfaff 551 Manual pages 1 viewing
If you are unable to figure out the bobbin winder, you may be able to use a standalone bobbin winder (one brand is called Sidewinder) from the fabric store. They run ~$25-30. Just be sure to bring a bobbin with you to check the fit.
vintage sewing machine bobbin winding Google Search
How to Wind Bobbin and Thread Bobbin Case for Vintage Singer Featherweight...
Jul 14, 2016 | PfaFF Sewing Machines
My bobbin winds unevenly, there is always more thread at the bottom of it than there is at the top. Neither switching to the original pfaff bobbin nor either spool position works.
I always use my finger to guide the thread as the bobbin is winding,the bobbin shouldn't be moving around in the metalcase probably needs tightened.
Aug 29, 2015 | PfaFF Sewing Machines
My Janome 3018 will not wind a nice tight bobbin. They are loose and spongy. This machine is brand new. I have double checked that it is threaded properly and the thread is in the correct place and
You are not exactly threading the machine when you wind the bobbin. So follow the directions for winding the bobbin, make sure the thread fits under the little revolving wheel, and make sure that the stitch part of the machine is disengaged.
Jan 01, 2015 | Janome Sewing Machines
Pfaff 2046 tension problems, needle breaks
Needle breaks
1.the needle is damaged
2.the needle is not correctly inserted
3.wrong size needle for the fabric
4.the wrong foot is attached
5.the needle clamp screw is loose
6. Top tension is too tight--loosen off one letter or number till the stitch
looks normal
7.make sure that every thread guide is used when winding the
bobbin,, so that the bobbin will wind tightly, if this doesn't help,,
then it's possible that the bobbin winder needs adjustment,, it needs
to be taken to a sewing machine shop
Aug 15, 2012 | Sewing Machines
PFAFF Creative 1469 manual doesn't show how to thread it.
try sewusa.com they have some threading diagrams
also try youtube & ehow for video's
Apr 15, 2012 | PfaFF Sewing Machines
Bobbin not winding tightly
BRAND new Janome 1420qdc. New needle, doesn’t need oil. Will NOT wind a bobbin. Used almost an entire spook of thread doing this. At my wits end. HELP!
Mar 28, 2012 | Janome Memorycraft 9700 Computerized...
I'm trying to do shirring?
My machines has a shirring foot, so I don;t have the same machine. However, I do not think that elastic thread will work in the bobbin. Have you tried it the other way around? Do you have your manual?
Aug 07, 2008 | Sewing Machines
Sewing Machines Logo
243 people viewed this question
Top PfaFF Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Irene Tulloch
Are you a PfaFF Sewing Machine Expert? Answer questions, earn points and help others
