Question about Logitech diNovo Edge 9676850403 Keyboard
My keyboard worked with my PS3 when I used my Belkin PS/PS2 USB 2.0 adapter but now I switched to another adapter (simpler design) and my keyboard no longer works. Any suggestions?
    President:
  • 8,637 Answers
Normal 0 Press the Receiver button (and the lights will start flashing.
Then if the Keyboard isn't working, press the small RESET/CONNECT button on the back of the board to connect the keyboard to the receiver.
Hope this helps. Bud
Posted on Jan 25, 2009
How do I connect a usb mouse and keyboard to ps2 kvm switch?
usb to ps2 converter, the sell them for like 30$ but you can go to radioshack and buy a keyboard for that with the little adapter
Mar 30, 2013 | Belkin F1DL102P 2-port KVM Switch
I am wanting to connect a Gateway keyboard to a Dell PC but I need an adapter from female to male usb port. What adapter do I need? Will I need to download any software for this?
amm udont need an adapter, the keyboard once usb will plug right in,, if its circular,means its a ps2 port and you need ps2 to usb. No no drivers needed. Or usb to ps2 ,, depends on your needs, But all Usb are standarad stuff.
May 06, 2011 | Dell Computers & Internet
I have a dell inspiron desktop that has no ps2 port, only USB. From my older computer I would like to use my microsoft ergonomic keyboard that has a ps2 plug. I bought a PS2 to USB adapter but when I...
The adapter you purchased is for use with a PS/2 mouse only. The only keyboard adapters will have keyboard and mouse in a "Y" adapter. The single adapters will not work for keyboards because they do not have the conversion electronics to go from PS/2 to USB, mice can work on either one. Do a google search for "usb to PS2 dual port adapter" you can get them for around $2 plus shipping.
I hope this helps, if so please rate our solution.
BuddyMc
Dec 23, 2010 | Computers & Internet
I have iogear miniview kvm (gcs62) keyboard works but mouse conn does not. Mluse is usb mouse with ps/2 adapter. Direct connection via usb works. used to also work with adapter but having tried it with kvm...
USB mouse with PS/2 adapter is not guaranteed to wok with GCS62. This KVM switch is designed to work with PS/2 keyboards and mice only.
When the USB mouse with PS/2 adapter is used in a computer directly, it will surely work, because the USB port can give enough power for the mouse to work. And it can easily convert the signal.
Unlike in KVM switch, the switch serves as a bridge between the mouse and the computer. And the computer does not easily recognize the mouse.
I would suggest to use a regular PS/2 mouse. Or if you want to use USB keyboard and mouse, you need to have a USB KVM switch. Model GCS632U.
Thank you and good luck!
Jan 21, 2010 | IOGear MiniView GCS62 2-port KVM Switch
USB Keyboard and mouse wont work with PS2 KVM with adapter
Have you tried rebooting once it is connected? Not sure if it makes a difference, but I know you can not hook up PS2 peripherals without rebooting.
Nov 03, 2009 | Dell OptiPlex GX280 PC Desktop
Belkin wireless keyboard receiver won't work with my laptop
Yes and no...
"Wireless enabled" means you do not need a separate adapter to connect to a wireless NETWORK or computer, not a peripheral device.
I assume the two connectors are PS/2- plugs - one pink, the other one green. What you need is a PS/2- -to-USB adapter that should have come with your keyboard. PS/2-in, USB-out, either with or without the cables (see picture)
Dec 18, 2008 | Belkin Wireless Keyboard/Optical Mouse...
Belkin 2-Port KVM Switch
It is compatible with a wireless mouse, as long as it is a PS2 mouse.  if it is USB you could try using a converter, but it may not work.
Nov 04, 2008 | D-Link AirPlus G DWL-G122 802.11g/b...
USB mouse not recognized
I have similar problem. 2 inland KVM's (both have PS2 inputs, one has USB outputs) do not light or recognize my usb mouse with a PS2 adapter. They do recognize a PS2 ball mouse on the KVM's however. One of the computers (Sony vaio 1.5 GHz) does recognize a usb mouse with adapter on 2 other KVM's (Old Belkin and a Trendnet) (the second computer I have not tried in those configurations). Next I will try an optical mouse with a PS2 fitting. That did work with a fifth KVM at an auto business last week.
Feb 18, 2008 | Dell (582RR) 16-port KVM Switch
Tekram K7KX-A PS/2 keyboard will not work. Get Adapter
the only thing I can suggest in this scenario, is to go through your BIOS again, and check for options to enable/disable your PS2 ports, and that's the best-case outcome.
worst case outcome is that when you were swapping your hard drives, an improper circuit was made, and static (ESD) killed a component on your motherboard. Did you use a grounding strap, or ground yourself when you had the case open? another thing to check for, is if the wires connecting the ports are whole, and not bent or loose.
if this doesn't help, i'd definatly go with the USB adapter, to see if that works. if not, there is a possibility you might have to buy a new motherboard, in itself.
Dec 30, 2007 | Tekram K7KX A Motherboard
Logitech diNovo Edge 9676850403 Keyboard Logo
82 people viewed this question
Top Logitech Computers & Internet Experts
micky dee
Are you a Logitech Computer and Internet Expert? Answer questions, earn points and help others
