Question about Samsung PCL541R 54" Rear Projection Television
Sound and no picture.
TV came into my posession with blown fuse.I replaced the fuse and it worked fine for about 20 min.I heard the same fuse pop(jumped the bjeasome out of me).I replaced it again and the tv worked fine all evening.Turn it on the next evening and no picture but has sound.Visually i can see the bottom half of tubes dimly lit but nothing through the lenzes.Any ideas/suggestions? tgoose
Thanks Bill,Your right.it`s beyond my knowledge and i`ll seek an expert to bring it to.When the solution is at hand,I`ll post it. Terry
Posted on Jun 04, 2007
  • 934 Answers
A blown fuse is only a symptom, not the problem. The problem is somewhere else in the unit... From what you're describing here something is keeping your HV down and that could be any number circuits... This type of problem is a challenge even for the best of technicians and not something you're going to resolve with less than several thousand dollars worth of test equipment at hand and one heck of a lot more experience than I've ever seen on this board... No disrespect intended... That said, I would start by testing the regulator circuit. Look for any signs of heat stressed components. Test the HOT for short and check the FBT and splitter. Something in the B+ line is the culprit. But my best advice is take it to a reputable shop and get an estimate before any repairs are done. If you don't understand ask for explanations. If that isn't doing it ask different shop or get a second opinion. Good Luck Bill
Posted on Jun 03, 2007
Sound no picture
Try connecting TV to cable direct also try unplugging both converter and TV for wile like 5 mins plug both back in see if TV and converter sync.
But if it still doesn't work...
More than likely this will be down to your Y Sustain board has gone faulty, when the back is off your TV it is on the left hand side and will probably have a fuse that has blown, replacing the fuse will not solve the problem as it is the IMP under the heatsink that has gone faulty.
You should get the part number of the board and Google or Ebay for a replacement.
Hope this help
Jun 11, 2010 | Samsung LE40R73BD 40 in. HD-Ready LCD...
RCA 32V550T Posessed
This tv is know to have circuits burn out
If you still have the warranty, use it
Otherwise a repair will cost about $150
580-634-0151 support number for rca
If you need anything else, please ask, thank you and I hope you fix your problem
Mar 27, 2008 | RCA 32V550T 32" TV
No picture or sound on some channels
we cannot get a picture or sound on several channels. Otherwise the TV works fine. Any solutions? as you get p&s on several channels so your ser is ok the problem 1 loose contact near tuner or it is defective. 2 tuner signal line .
Sep 16, 2007 | Toshiba 20AF44 20" TV
LG plasma have an amber light when turning on then green then red
After all the research I found out that the IC on the Z board is bad and new board was ordered and replaced. The plasma work fine after that and picture is excellent with the new board. This forum is great, without this I couldn't fix it myself. Thank you.
Sep 30, 2009 | Zenith P42W46X 42 in. Plasma EDTV
Pop sound then no picture, just sound
I assume this is a plasma TV? You will have a fuse blown on either the Y or Z sutain board, there is also a possibility one of the driver IC's has blown on the buffer board, this will shut down the screen & leave the audio working normally. You can check these boards which sit on the left & right hand sides of the screen.
Sep 23, 2009 | Televison & Video
50 inch vizio, no picture but theres sound!!
check y-sus board(top left with 2 white fuse)
check z-sus board(right small board with 2 white fuse)-view from back
blown fuse? replace that board. partstore.com or discount-merchant.com
Aug 05, 2009 | V, Inc. Vizio P50HD Plasma Television
Lg plasma 42PC3D no picture with sound
I know you already replaced the board, this is for future searchers. If you heard a popping sound, then the picture went out, there is a 32 pin Sanyo module that goes bad on the board. That's probably what caused the fuse to blow. Replace the module, then replace the fuse. The module is less than half the cost of a used board. Since this was a popular model TV, there are lots of replacement boards on the used market.
Mar 15, 2008 | LG 42PC3D 42 in. Plasma Television
Still posessed!
These tv does have loose of audio problems im concern about looseing picture . Try unplugging tv for 5 minutes it will reset tv very common fix for audio. Tv that are less then a year old are sometimes covered under new warr call manufacture on that.
There is a microprocessor on these that lockup and when you unplug it. it resets it.
I have a tv shop and have helped customers get exchanges under a year especially if you complain
good luck i hpe i helped Thanks DOCTOR VIDEO
Dec 31, 2007 | RCA 32V550T 32" TV
Power
  • Sorry but it can't be fixed without knowing how a tv works on the inside. The problem is on the inside possibly in the horizontal section and should be taken to a repair shop
Dec 31, 2007 | JVC AV-32730 TV
Toshiba tz50v51 popping sound
Possible problems: * The TV set may be unplugged. * A fuse or circuit breaker may be blown or switched off. * The remote control unit (RCU) may be disabled. Solutions: * Make sure the TV/VCR are plugged in and the wall switch is on. * Check the fuse or circuit breaker. Test the outlet with a lamp. * Replace the RCU's batteries: if this fails exchange the unit.
Jan 18, 2006 | Toshiba TZ50V51 50" Rear Projection...
Samsung PCL541R 54" Rear Projection Television Logo
61 people viewed this question
Jerry Greenberg
Jerry Greenberg
Demonic-2011
Demonic-2011
