Question about NetGear RangeMax Dual-Band Wireless-N Router with 4-Port Ethernet Switch
I just bought a netgear switch 5 port 1 gbps and installed it to the router. i am able to get one computer which was already one the router to work however the other two i have connected will not connect to the internet. I get limited or no connectivity and i am unable to renew the IP add. to try and troubleshoot this problem. I would think if it was the switch no comp. would connect...Any ideas..Ps. i have also pinged the comps and they are fine??????
  • sean_belk Jan 08, 2009
    Well i figured i had an address issue however i am really not that ip literate LMAO. I only knew to check the ping as i have had tech support with cable modem before. i will try this with the ip address however i am unsure what to do if they do not match as generally windows can repair connection issues with this type of problem. The switch i am using is only a 5 port net gear 1gb switch it will not assign only clone the same ip the router is putting out rite? Is ther an easy way to fix DHCP issues without sitting on the phone witing for netgear for half the day??? LOL and ty for any help i greatly appreciate it.
  • Carl Navarro
    Carl Navarro May 11, 2010
    If you can't release and renew the IP address, it means the router does not give out DHCP or you are not using DHCP. When you PING the other computers, are you in the same domain (ie
    Get the IP address of the first computer that works, unplug it, plug in a second computer alone and get it's IP address. If it's not similar, you have DHCP issues. But you probably knew that :-)
  • 538 Answers
You should have DHCP enaibled
Posted on Mar 20, 2009
What's the difference between the Cisco 3850 and 3750-X series switches?
The difference between them as below, hope can help you to choose the best switches on your business.
1.Stacking bandwidth: 3750X for 64 Gbps while 3850 for 480 Gbps
2.Cisco IOS software wireless controller: 3750-X has none while Catalyst 3850 has
3.Queuse per port: 3750 has 4 while 3850 has 8
4.Quality-of-service model: 3750 with MLS while 3850 with MQC
5.Uplinks: 3750 be equipped with 4 x 1GE2 x 10GE NM4 x 1 GE or 2 x 10GE SM
3850 be equipped with 4 x 1GE2 x 1/10GE4 x 1/10GE(on 48 port model)
If you still have any question, you can log in
to know more about the datasheet and specification about the Cisco switches.
Jul 31, 2014 | Cisco Computers & Internet
I've got a BT HomeHub which works fine with a 4-port Ethernet switch to give me a small home network of 1 Mac Pro, 1 Laptop and 1 printer. I have an older Netgear RO318 Router - with 8-ports. But when...
When you use the older Netgear RO318 Router, make sure you don't use the WAN/Internet port, only use the numbered switch ports of the router.
Jul 31, 2017 | NetGear RO318 Router
Hi I would like o hook up a netgear prosafe 8port gigabit switch to my pc and run an ethernet cable which is allready hardwired to my sony bluray player so I can enjoy netflix
It would be much easier to use a simpler device, namely any Netgear 10/100 wireless router.
Cable-modem (or DSL-modem) --> Router's WAN port
Router's LAN port #1 --> your desktop computer
Router's LAN port #2 --> your Sony player
Router's wireless adapter --> your iPod Touch's WiFi adapter
Since the cable-modem (or DSL-modem) is only delivering 5 to 25 Mbits/second to your router,
unless you are paying a _lot_ of money per month to your ISP,
there's no need to buy/use expensive "gigabit" equipment.
Jun 06, 2011 | NetGear ProSafe GS108 8-Port Gigabit...
How to manually set up the router from Netgear?
To log into a NETGEAR router:
  1. In your Web browser, navigate to the router login page. By default, one or all of the following URLs should work:
    • or
    • or
    Note: You can sometimes find the login URL on a sticker on the bottom or back of the router.
  2. Enter the username (admin) and the password.
    • The default password is password, or for older routers, 1234.
    • If you have already changed the default password, use the password you assigned the router. Passwords are case sensitive.
    • If you have already changed the password and do not remember it, you have to reset the router to factory defaults in order to use the default password. Resetting a router to factory defaults erases all changes you have made to the router's configuration files.
Jun 05, 2011 | NetGear MBR624GU Wireless Router
I just bought a laptop computer and I already had a desktop. My internet provider is Hugesnet Satelite. I bought a Netgear N600 wireless dual band router thinking I could just hook it up to my desktop...
The HN9000 should have an ethernet port. You will require two ethernet cables to connect the desktop to the router.
1. Connect the ethernet cable from the Modem to the Ethernet Input port on the Router (It is generally placed away from the other ports on the back of the router.) 2. Connect another ethernet cord from one of the output ports on the router to the desktop computer. 3. On the laptop, turn on your wireless card. The process for this differs from computer to computer. If you were to provide the model of laptop, I could provide you specific instructions. 4. The network setup should be complete.
If you need more help, let me know by replying to this solution. Thank you for using FixYa!
Apr 01, 2011 | NetGear Computers & Internet
I got a NETGEAR router and I have been trying to get my Motorola SURFboard to recognize it. I had the USB connection installed and the NETGEAR uses ethernet, so I tried to install the ethernet but my...
The Cable modem must be disconnected from the computer. You cannot use USB and Ethernet at the same time.
1. Turn off power to the Cable Modem and the Netgear Router. Do the same with the computer.
2. Connect an ethernet cable from the modem to the router's WAN (Internet) port.
3. Connect another ethernet cable from one of the remaining 4 LAN ports on the router to the computer's ethernet port.
4. Now power on the Cable Modem ONLY. Wait for the modem to sync up with your service provider
5. After about 2-5 minutes power up the router and wait about 1-2 minutes.
6. Now power on your PC.
Check and see if you have internet access. If not you may have to uninstall any cable modem software related to USB connection. if this is the case, then you may have to repeat steps 4-6.
Since most cable internet providers do not use proprietary connection settings, your internet connection should be up and running without changing any settings in the router or modem.
If this does not resolve your issues, we can continue to work with you.
Nov 29, 2010 | Arris SURFboard® SB5101 Cable Modem
No install CD needed with valid working internet with modem. First you need to turn off your computer then connect the working hsi modem to the Netgear router with the ethernet cord (looks like a thicker telephone wire) connect the ethernet cord from the back of the modem to the first single port on the Netgear not the ports labeled 1-4. Then with another ethernet cable snap one end into one of the 4 ports available and the other end snap into your computers ethernet port. Then unplug the MODEMs power cord for 30sec plug it back in wait for modem to boot back up with all of its lights and turn the computer back on. After install is finished you can now go and download your routers firmware from Netgear. In your address bar where it reads http://.........go ahead and highlight this and backspace it all until it clears to blank. Type in and then hit enter. A window will pop up asking for username and password. For username type in "admin" for password type in "password" this is default and will always work unless someone has changed the username and password already on your home network, in which case contact netgear support. But if it does work the you will get Negear Smart Wizard. Here is where you can click on "Setup Wizard" and follow the prompts to download latest firmware and then Finished. Close down the netgear page and happy wireless internet surfing.
Apr 25, 2010 | NetGear WGR614 Wireless Router
I bought a netgear FS605 swtich and it doesn't work on the ps3.
Yes you must by a router my friend.
The problem is your ISP will not give out extra Ip addresses for additional clients. The router will have a dhcp server built in and that will fix the problems at hand.
Feb 20, 2009 | NetGear FS605 - 5-Port 10/100 Network...
Do i need a disk to install a netgear wireless?
You need a network cable (cat5e) to connect the cable modem to the wan or Internet port on the router. Then another network cable to connect the router port(1-4) to the computer's network (NIC) port. If you are going wireless, you do not need to connect the second cable.
You do not need a disk. just power down the cable modem,router and computer.
Hook it all up, then power up the cable modem first, wait 30 seconds, then power up the router, wait 30 seconds, then power up the computer. You shold be able to get online.
Unless: you are using DSL
and unless the original owner had an encryption key on the router.
Dec 16, 2008 | NetGear DG834G Router
NetGear RangeMax Dual-Band Wireless-N Router with 4-Port Ethernet Switch Logo
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
