Question about Samsung AW1291M Air Conditioner
"KACHUNK?" My air conditioner (Model #: AW1291M) works fine for about five minutes and then gives out with a loud "KACHUNK" and switches to just the fan. What causes this, and is there anything I can do if I take the unit out of it's chassis? Thanks.
  • 236 Answers
Either its the thermostat or the compressor itself, you need a qualified technician with this problem.
Posted on Apr 07, 2008
Hi I keep getting a ch 67 after the unit starts fine and runs for like five minutes fan on all units work during that five minutes any thoughts would be greatly appreciated
Low freon pressure switch is turning it off. As the coils cool down the pressure drops. As time goes on it will run shorter and shorter cycles. In warm weather freon 22 low pressure should be near 70 lb
410A freon about 150 on the low side
May 02, 2015 | Heating & Cooling
Air conditioner shudders, stops blowing cold, then resets every 5 mins
Cleaned the filter this AM and closed the door but now a red
light keeps flashing.
Jul 19, 2013 | Sharp Cv-p12lx 11500 Btu Portable Air...
When I switch it on from cold it goes to come on them goes on standby so I switch it off then on again then it comes on why is this pls
Air conditioners or refrigerators do not like to be switched on and off in a short period of time. You should allow a minimum of three to five minutes between switching either on or off or from heating to cooling.
Nov 18, 2009 | Heating & Cooling
AC Unit is not cooling.
hi...
Every air conditioner has a motor called a compressor. The compressor provides the cooling capacity for the air conditioner. If the compressor or its electrical controls are defective the compressor may try to start, fail, and create an electrical overload. If the unit does create an overload, every compressor circuit is also equipped with an overload safety switch. The safety switch is designed to protect the compressor from burning out. The safety switch will cut the power to the compressor for a certain length of time and then reset itself. When it resets it will allow the electricity to flow to the compressor once again. If the compressor then starts, the unit should function normally. If the compressor doesn't start when the overload resets, the overload will again cut the electricity to the compressor. This cycle will continue indefinitely. (Always allow three to five minutes before restarting the compressor.) If this situation is occurring, unplug the air conditioner and get help from a qualified repair technician. This problem is often fatal to the air conditioner because the cost of repair often exceeds the price of a new air conditioner...
hope this will give u a clear idea..
thank u
rate me!!!!
Aug 24, 2009 | Heating & Cooling
Wont blow out cold air anymore?
hi...
thank u
rate me!!!!
Jul 19, 2009 | Pelonis Heating & Cooling
Noisy Amana Quiet Zone air conditioner
The compressor sounds like the springs inside are bad. You can live with this are get the compresor eplaced if it is over five years old buy a new unit. Compressor will cost more than a new unit. Russ
Jul 18, 2009 | Amana Quiet Zone 12M12TA Air Conditioner
Making a loud noise...
I requested clarification for your problem and did not receive a response. Please re-post your question if you would like help. Thank You
Jun 12, 2008 | Ruud UAMB Air Conditioner
Ruud air conditioner unit
sounds like you have a fan blade out of balance or one that is bent which when the unit winds down it becomes out of balance use a straight edge across the blades to see if any are bent.
Samsung AW1291M Air Conditioner Logo
59 people viewed this question
Top Samsung Heating & Cooling Experts
gbob59
billconfused
Ezewudo Onyekachi
Ezewudo Onyekachi
Are you a Samsung Heating and Cooling Expert? Answer questions, earn points and help others
