Question about GE RP4842 Clock Radio
Alarm I don't have the instruction manual for this radio.Intermittently the alarm goes off - and I simply want to know, how to disable (have it in non alarm mode).The radio works fine, it is just the alarm going off, when I don't want it to. There is a "set" panel on the top/side, with a four positon slide switch - key icon;time;wake1;wake2. There are also wake1 button;wake2 button;cancel button in another cluster on the top. I would appreciate info on how to set the alarm, so it doesn't go off. Thanks.
  • littlemiss Nov 14, 2007
    I can not figure out how to turn the nap function off..
    Any help
While on key push cancel (alarm dots blink) then push wake 1 or wake 2 (which ever one you pushed the light for it should disappear)
Posted on Sep 27, 2007
  • 30 Answers
SLIDE THE SWITCH TO TIME DO NOT PUT ON WAKE 1 OR WAKE 2 THOSE ARE LIKE TWO SEPEATE ALARM TIMES YOU COULD SET PUT ON CANCEL OR JUST TIME.
Posted on Jun 30, 2007
SOURCE:
I have a Timex T311 clock radio. How do I shut off alarm and radio everyday. As I no longer need to wake in the am.
On the Timex T311, to disable the radio alarm, press the Radio Alarm button once. The Radio Alarm Indicator light should go out and the radio alarm won't sound. If you press the Radio Alarm button once more, the radio alarm will toggle to on and that indicator light will come on. Similarly, press the Buzzer Alarm button once to enable the buzzer alarm and press it again to disable the alarm.
See page 9 of the manual to see the directions to toggle these alarms on and off. The manual is available from Timex Audio on the product page: https://timexaudio.com/support/product/T311/ . The direct link to the manual is https://timexaudio.com/media/uploads/product/files/T311IB57574_35.pdf .
I hope this helps.
Nov 15, 2017 | Timex Audio Players & Recorders
My alarm goes off intermittently
Try resetting the alarm, using the instructions given at the link below. I'll also copy the text here.
  1. Insert the ignition/door key in the door lock on the driver's- side door of your Mountaineer.
  2. Turn the key to the lock position.
  3. Turn your key to the unlock position.
  4. Turn your key to the lock position.
  5. Turn your key to the unlock position. Your alarm is now disabled. If your key fob works, you can also press the unlock or alarm-disable button on the fob.
  6. Start the Mountaineer's engine and allow the vehicle to run for at least 10 minutes. This will allow the alarm to relearn the default settings. You must make sure that you have disabled the alarm first, however, before you attempt to start the vehicle, so that the alarm will reset itself.
http://www.ehow.com/how_5978302_reset-mercury-mountaineer-alarm.html
If these instructions don't work, you can try resetting the car's computer by unplugging the battery for half an hour. However, that will reset the keyless entry code, as you can see in the fixya article I link to at the bottom
http://www.fixya.com/cars/t4755856-we_bought_it_used_and_we_dont_know_the_k
Jun 10, 2015 | 2003 Mercury Mountaineer
Car alarm goes off intermittently for no reason
Save yourself a big headache and disable the alarm system.
Jan 25, 2014 | 2003 Lincoln Town Car
How to turn off alarm on GE radio Model 7-4853c
The manual says to "DISABLE THE ALARM PERMANENTLY" you should:
"Press and hold WAKE 1 or WAKE 2 until the green indicator disappears."
I did this and the light indicator to the right of the clock digital readout went out after a few seconds. I won't know until tomorrow if the alarm is permanently disabled.
Jan 17, 2012 | GE Audio Players & Recorders
How do I disable the alarm on Bose AWR1-1W? Thanks
Hello
To cancell the alarm mode is described in it user manual [page 21]. It is very difficult to type thos symbols here by this window. Just follow the manual. It says, press alarm mode button either on its control panel or on the remote control until the display shows 'no alarm mode' indications. If you don't have the manual send your email address to me by FixYa. I'll send a copy of it to you by return mail. OK.
Jun 24, 2011 | Bose Wave Radio
I have lost the instrucions and do not know how to operate the alarm. I never use the alarm but every night at 12pm the alarm goes off even if the radio is unplugged. Please help! Can I get the...
You can download the complete user manual by clicking this link
  • You'll require Adobe PDF Reader installed on your computer to view this manual. If it is not already installed on your computer, download it free from: http://get.adobe.com/reader/
Hope this solves your problem. Thanks for using FixYa
Mar 03, 2010 | RCA RP5430 Clock Radio
Looking for fuse to disable toyota corolla alarm,please help!!
Remove fuse labelled "dome" on engine compartment fuse box. unfortunately this also isolates the radio. I have found when re connecting battery alarm goes off. remove "dome" fuse and then replace it. all ok then.
Feb 26, 2010 | 1996 Toyota Corolla
How do i shut off the alarm mechanism on the mini 300 world band reciever
Here's a link to the eton site where you can download and print the manual for your radio. Instructions for the alarm function are on page 7:
http://www.etoncorp.com/upload/contents/307/Mini300_Manual_0107.pdf
Bill B.
San Antonio
Apr 10, 2009 | Grundig Mini 300 AM/FM/SW Radio
GE RP4842 Clock Radio Logo
349 people viewed this question
Top GE Audio Players & Recorders Experts
Racki123
Level 1 Expert
john1959ny
john1959ny
Rob Hill
Rob Hill
Are you a GE Audio Player and Recorder Expert? Answer questions, earn points and help others
