Question about Hoover F5810 SteamVac Upright Vacuum
Assembling a steam vac handle part
I dont have the manual, i took handle off to clean my machine but i cant figure out how the clips inside the handle go on
  • 294 Answers
When the machine comes new the way it is installed is to put the upper handle on the lower handle, install the bolts & nuts (tighten) and then to pull the trigger and press the surge button (if this model has one). you will feel them snap together. the clips on the rods should be at 90 degree's from each other. one will be a u type channel and the other a v type and will connect.
Posted on Jan 20, 2009
Install upper control rod
Hi, it's Jeremy from Crucial Vacuum.
To attach the upper handle to your Hoover Steam Vac remove the clean solution tank (upper tank) from the deep cleaner. Then, attach the upper handle to the lower handle by pushing the upper handle down onto lower one. Use the provided bolts to secure the handles. Push the bolts into the accompanying holes on the front of handle. If the bolts do not go through the holes easily, your handle is not pushed completely down. When the handle sections are completely together, squeeze the trigger on the upper handle to snap the trigger rod into place.
If you require further help with your assembly, you can find a step-by-step manual at: http://www.searspartsdirect.com/partsdirect/user-manuals/f5865900-hoover-parts-steam+vac-manual
You can also purchase all of your Hoover Steam Vac replacement parts from Crucial Vacuum with free shipping and an exclusive 10% coupon for Fixya.com readers, use code: FIXYA10
http://www.crucialvacuum.com/catalogsearch/result/?q=hoover+steam+vac
I hope this was helpful. If you would like further assistance, please feel free to give us a call at 877.750.9239. We have helpful and friendly customer care representatives on the line ready to assist you.
Jeremy Lerner
Crucial Vacuum Customer Care
Jun 10, 2014 | Vacuums
Hoover steam vac model 5853-900 has 5 brushes/cleaning dispensers, am only getting 2 small trickles of fluid when I dispense fluid onto carpet
The brushes come off, they are clipped on as an assembly if you look at the bottom of the machine you can see where the cover for the vacuum slot that brings up the water clips on too. If you remove that you can see the clips that hold the brush unit better
Feb 20, 2013 | Vacuums
Had infamous extra part once I put my steam cleaner back together
Steve, The o-ring goes inside the turbine assembly on the metal shaft.
Mar 20, 2009 | Hoover F7220900 SteamVac V2 Upright Vacuum
Spin brush removal
Brush Disassembly Hoover STEAM VAC Owners Manual F9514-900 (F9514900) does not
explain how to take the brush assembly apart. The instructions are as
follows:
Figure 1 shows the key
features. There are two
clear plastic outer pieces
which are held onto the
white inner piece with 3
tabs each. The clear
plastic tabs go underneath
the corresponding white
extended tabs on the white
plastic inner piece.
Figure 2 shows where the
screwdriver is inserted
(flat blade) and gently
pushed down while pulling
the clear plastic outer
piece away from the inner
white piece.
Figure 3 shows assembled
unit. Note extended brush
axle goes in center, which
fits into the female drive
unit on the shampooer.
I used the hose nozzle out
on the lawn to direct high
velocity water stream
trying to get the hair out
of the brushes. Hair and
fuzz remarkably entrained
in brushes, but I got 90% of it out.
Oct 19, 2008 | Hoover SteamVac F5914-900 SpinScrub...
Brushes do not spin
The manual suggests cleaning the filter screen near the brush assembly. This is located on the bottom of the unit. In cleaning this it did not successfully help. I then proceeded to take the cover (blue) off the motor an brush drive and worked my way to the gear assembly. This is where I found the actually problem.
The problem: The brushes are driven by a turbine wheel operated with suction from the vacuum. In my unit the turbine and bearings became loose or slipped to the point that the worm gear lost contact with the additional gears that drive the brush. When resetting the assembly so that ample contact is established the unit began to operate fine.
This can be complicated to explain and illustrate therefore taking the unit in for repair is recommended. If you are confident in repairing the unit yourself then go for it.
Jul 28, 2008 | Hoover F7452-900 SteamVac Upright Vacuum
Hoover Steam Vac Spin Scrub Carpet Cleaner won't suck
http://geeksquad.fixya.com/ThreadView.aspx?prdid=618767&thid=728884
Hoover Steam Vac Spin Scrub Carpet Cleaner won't...
Posted by hoofbeats1 on Jul 01, 2008
My machine is a little more than a year old. I have used it about 5 times. It started leaking the third time I used it. The fourth time I took it out, the brushes would not spin (I did clean them and rinse them after use each time).
Now the engine screams and won't **** anything up. Do you have any suggestions? My last Hoover Steam Vac was great and lasted for 3 years! Hi,
I have a Hoover Dual V SteamVac F7425-900 that the brushes won't spin. The lint screen is clean & the brushes switch is in the on position.
It dispenses & sucks up the cleaning solution & water; just no brush action. Help
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. The only thing that I can recommend is that you may have a bad switch, some vacs may have a broken belt or the drive mechanism inside the Hoover Dual V SteamVac F7425-900 in or by the brush assm section and is need of repair. Please check the trouble shooting section of the owner’s manual if you’re needing help and to save money. If you don’t have one then contact the Hoover factory cust serv. So, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://www.hoover.com Telephone
Contact our Customer Service Department at 1.330.499.9499
Monday through Friday
8 a.m. - 7 p.m. EST
Thanks, Don the Vac Man
Go Ahead. Use Us.
Jul 01, 2008 | Hoover SteamVac Carpet/Upholstery Deep...
Manual for model f5853-900
I need a mnual for the Hoover Steam Vac Model F5853
Jun 25, 2008 | Hoover SteamVac Carpet/Upholstery Deep...
Hoover steam vac, brushes won't rotate, have cleaned filter by brushes, removed brushes and they rotate okay when off steam vac, tried to ajust level for carpet cleaning and brushes still don't move
Check to see if the shaft on the brush block hasn't broken off. Otherwise it is the turbine that drives the brushes and is either clogged up inside or needs to be replaced.
Jun 07, 2008 | Vacuums
Cleaning brush assembly on steamvac
Yes this does come apart. The clear plastic pieces clip into the black plastic piece, flat tip screw driver inserted into the gap can release the clips and allow for cleaning.
Nov 10, 2007 | Hoover F7425-900 SteamVac V2 Widepath...
Hoover F5810 SteamVac   Upright Vacuum Logo
82 people viewed this question
Top Hoover Vacuums Experts
Roger Potts
Mike Cairns
Mike Cairns
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
