What motherboards will fit my dell 4600 mid tower
  • 10,515 Answers
The best that fits wld be :)
asusm2n4-sli am2
Thanks.
Posted on Jan 07, 2009
Computer case fan for Gateway Performance, mid-tower case
Case fan size is typically measured in mm. Common sizes include 40, 60, 80, 92, 120 and 140 mm. OEM cases can have proprietary fan sizes as well.
Jun 12, 2012 | Gateway Computers & Internet
I need to replace the motherboard battery on this Dell Dimension 4600 tower. How do I open the casing ?
All the PC are more or less the same thing...
Here's a video tutorial of how to open it.
Aug 24, 2011 | Dell Dimension™ 4600C PC Desktop
I need a motherboard that will fit in a Raidmax ATX1072BP Mid Tower ATX Computer Case!
Most desktop computer cases have a range of standard mount holes, standard offs.
I suggest you select a motherboard that suits your requirements.
To be sure that the motherboard will fit your case, take the motherboard mount base with you to the computer shop and place the motherboard of your choice on the base to see if the mounting holes line up.
You may need to upgrade the switch mode power supply to a higher power unit if the total power requirements is near the maximum the existing unit can deliver.
Dec 03, 2010 | RaidMax ATX1072BP MID TOWER ATX COMPUTER...
My monitor has gone to Power Save Mode
If your monitor is going in Power save mode it can be cause by following reasons.
>Check the data cable going from monitor to your Dell Dimension 4600 Tower is connected properly.The connector will be blue or white in colour.
>If the Dell Dimension 4600 Tower is powering on.
If still in power save mode then try to shutdown Tower and monitor,disconnect power cable from tower and monitor.Hold the power button on tower for 15 seconds.Then again try to connect monitor and check,if still nogo,and if tower has no lights then issue with motherboard or video card or power supply.If possible try connect spare known good monitor.
Thankyou
Sep 09, 2010 | Dell Dimension 4600 PC Desktop
How to soft boot a dell 4600
I used the reset button on my last one whenever ctrl/alt/del failed to soft boot
my computer.
Here is what Dell Chat tells me to do if ctrl/alt/del doesn't work:
Turn off the system from the power button. Remove the plug to the
power supply from the back off the system tower.Then hold the power
button on the tower down for 10 secs ( with the power cord removed).
Reconnect the power cord and then restart the system.This time do a
normal shutdown.
Regards,
Pp
Dec 02, 2009 | Dell Dimension 4600 PC Desktop
Front Panel help for Dell Dimension 4600
Go to dell site and query for *********** board specs. Then query for the pinouts on the board. Or goodle dell optplex+motherboard+hardwire connections. good luck
Jun 17, 2009 | Dell OptiPlex 170L PC Desktop
Dell Dimension 4600 Won't Boot Up, Steady Amber Light is on tower
I have seen with some of the small form factor dell's that there can be a motherboard problem; my expirence with the regular towers and the steady amber light have been power supplies. I have a dimension 9100 that is three years old now and I am on my fourth power supply. I am not sure that you would have one laying around, but in my past expirence its been teh power supply. On the ones that I have seen where it was the motherboard you could clearly see on the chipset where it was damaged from heat (it was burnt). Hope that helps
Nov 19, 2008 | Dell Dimension 4600 PC Desktop
Dimension 4500
ALMOST ALL OF THEM .contact dell support here...http://support.dell.com/.RICHARDM69
Nov 09, 2008 | Dell (KN900) ATX Mid-Tower Case
Computers & Internet Logo
59 people viewed this question
David Payne
David Payne
