Question about Honeywell Programmable Thermostat Heater
Honeywell Chronotherm IV Plus - heat goes off and comes back on
My thermostat is set to run at 69 heat, it will run for awhile and go off and come back on within 1-2 minutes.  The temp on the thermostat has not changed.  Is there a way to keep this from happening?  Can you set the temp to be more than 1 degree from the actual setting?
    Genius:
  • 1,199 Answers
This sounds to me like your thermostat is bad and will need replaced! this is not normal~
Please rate responce,
Thank You!
Posted on Jan 07, 2009
Honeywell Chronotherm iv Plus power cuts on and off
There's a trouble shooting guide here, you need to check for the presence of 24V when it goes blank, and trace back to where it's disappearing (I assume it is losing the 24v, if not you'll need to go through the installer setup or read on...
My first thought would be to check the wiring which has been touched last if it started doing that after you had coil replaced.
As an aside I'm not sure which model you have but if it has batteries you should replace them (I don't think it does have batteries but not seen a model iv so I'm unsure)
https://customer.honeywell.com/resources/techlit/TechLitDocuments/69-0000s/69-1410.pdf
May 12, 2014 | Honeywell Programmable Thermostat Heater
Chronotherm 4 plus
change the batteries in the thermostat
Mar 21, 2014 | Honeywell Heating & Cooling
I can't turn my Chronotherm IV plus off! Can anyone help me. It is going to cost a fortune
Depends what model number you have. The older models had problems. So Honeywell upgraded the model several times. When you say, cant turn it off. If that means the heat will not shut off then you have no choice to replace it, also if the heat,cool, off,switch will not work it is not repairable. Go to Home depot or menards and pick up a thermostat. Find somebody with some handy man skills and they can replace it for you.
Nov 28, 2011 | Honeywell Programmable Thermostat Heater
Honeywell Chronotherm iv fan keeps running even when heat and cool turned off. How do I turn it off?
To turn the fan off, press the "fan key" until it says "auto". This will turn the fan off. When the programs scheduled, changes, the fan will go on again. You have to repeat the fan to "auto" each time the schedule changes.
May 12, 2010 | Honeywell Programmable Thermostat Heater
Assuming you have the fan switch of your thermostat in AUTO, it sounds like a stuck Fan Relay. If the fan relay is stuck, your fan will continue to run as long as there is line voltage being fed to your unit. This relay could be an independent component or it could be an integral part of your control board. Have an experienced, qualified service technician check it out.
Mar 19, 2010 | Honeywell Programmable Thermostat Heater
My Honeywell chronotherm IV Plus thermostat intermittent problem
The Chrono Therm 3 and 4's were some of the worst products that honeywell has EVER put out. I would suggest switching to the Vision Pro 8000, please consult your local HVAC company for more information regarding the change over.
May 11, 2009 | Honeywell Programmable Thermostat Heater
Fan Honeywell Chronotherm IV T8600
sounds like the fan has been programmed to come on during that time. run through your programming settings and make sure the fan is set to auto for all the times.
Nov 11, 2008 | Honeywell Programmable Thermostat Heater
There are no batteries on an 8600-8601-8602 series
Feb 17, 2008 | Heating & Cooling
Heating & Cooling Logo
401 people viewed this question
Top Honeywell Heating & Cooling Experts
Bill Long
Paul Carew
vance jones
Are you a Honeywell Heating and Cooling Expert? Answer questions, earn points and help others
